Nextcloud version (eg, 20.0.5): 24.0.1snap1 (installed via snap)
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04 (LXC Container hosted on Proxmox)
Apache or nginx version (eg, Apache 2.4.25): don't know (installed via snap)
PHP version (eg, 7.4): don't know (installed via snap)
nextcloud.enable-https lets-encrypt doesn’t seem to work (the commands keeps running but there is no output).
- Deploy LXC Container (Ubuntu)
- Install nextcloud snap package
- Install and configure nextcloud :
nextcloud.manual-install <user> <password>-
nextcloud.occ config:system:set trusted_domains 1 --value=<nextcloud IP>=> At this step, I’m able to log in on Nextcloud webpage. Everything seems to work (through HTTP though) -
nextcloud.enable-https lets-encrypt=> this command keeps running and nothing happens (no output, no error). i’m able to cancel the command (Ctrl+C).
{"reqId":"Y6ZrVLcOTR37bDCeqsKu","level":2,"time":"2022-07-13T14:26:18+00:00","remoteAddr":"192.168.1.42","user":"--","app":"core","method":"GET","url":"/","message":"Trusted domain error. \"192.168.1.42\" tried to access using \"192.168.1.63\" as host.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36","version":"24.0.1.1"}
{"reqId":"ylDCQPhPejqJDeDp4fXV","level":2,"time":"2022-07-13T14:26:23+00:00","remoteAddr":"192.168.1.42","user":"--","app":"core","method":"GET","url":"/index.php/js/core/merged-template-prepend.js?v=83e9abba","message":"Trusted domain error. \"192.168.1.42\" tried to access using \"192.168.1.63\" as host.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36","version":"24.0.1.1"}
{"reqId":"Ufsq0AuqDeFzBzXhtHWQ","level":2,"time":"2022-07-13T14:26:27+00:00","remoteAddr":"192.168.1.42","user":"--","app":"core","method":"GET","url":"/cron.php","message":"Trusted domain error. \"192.168.1.42\" tried to access using \"192.168.1.63\" as host.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36","version":"24.0.1.1"}
{"reqId":"LI97MajkVw8kG69IInVK","level":2,"time":"2022-07-13T14:27:03+00:00","remoteAddr":"192.168.1.42","user":"--","app":"core","method":"GET","url":"/","message":"Trusted domain error. \"192.168.1.42\" tried to access using \"192.168.1.63\" as host.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36","version":"24.0.1.1"}
{"reqId":"yApZJFgzZjHlFyBD3XbP","level":2,"time":"2022-07-13T14:27:06+00:00","remoteAddr":"192.168.1.42","user":"--","app":"core","method":"GET","url":"/index.php/js/core/merged-template-prepend.js?v=83e9abba","message":"Trusted domain error. \"192.168.1.42\" tried to access using \"192.168.1.63\" as host.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36","version":"24.0.1.1"}
{"reqId":"XgAZkS5EvWAbs0Pr2DXG","level":2,"time":"2022-07-13T14:27:08+00:00","remoteAddr":"192.168.1.42","user":"--","app":"core","method":"GET","url":"/cron.php","message":"Trusted domain error. \"192.168.1.42\" tried to access using \"192.168.1.63\" as host.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36","version":"24.0.1.1"}
{"reqId":"06obsJ27MdPr8uJMW2D6","level":2,"time":"2022-07-13T14:34:50+00:00","remoteAddr":"192.168.1.42","user":"--","app":"core","method":"GET","url":"/","message":"Trusted domain error. \"192.168.1.42\" tried to access using \"192.168.1.63\" as host.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36","version":"24.0.1.1"}
{"reqId":"nPZB7MvGJpdApHrWUSaH","level":2,"time":"2022-07-13T14:34:55+00:00","remoteAddr":"192.168.1.42","user":"--","app":"core","method":"GET","url":"/index.php/js/core/merged-template-prepend.js?v=83e9abba","message":"Trusted domain error. \"192.168.1.42\" tried to access using \"192.168.1.63\" as host.","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36","version":"24.0.1.1"}
{"reqId":"XzW8q5dwEPSCxkiP1DIC","level":3,"time":"2022-07-13T14:40:09+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Trying to access array offset on value of type null at /snap/nextcloud/31033/htdocs/apps/dav/lib/CalDAV/BirthdayService.php#306","userAgent":"--","version":"24.0.1.1","exception":{"Exception":"Error","Message":"Trying to access array offset on value of type null at /snap/nextcloud/31033/htdocs/apps/dav/lib/CalDAV/BirthdayService.php#306","Code":0,"Trace":[{"file":"/snap/nextcloud/31033/htdocs/apps/dav/lib/CalDAV/BirthdayService.php","line":306,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/snap/nextcloud/31033/htdocs/apps/dav/lib/BackgroundJob/GenerateBirthdayCalendarBackgroundJob.php","line":70,"function":"resetForUser","class":"OCA\\DAV\\CalDAV\\BirthdayService","type":"->"},{"file":"/snap/nextcloud/31033/htdocs/lib/public/BackgroundJob/Job.php","line":79,"function":"run","class":"OCA\\DAV\\BackgroundJob\\GenerateBirthdayCalendarBackgroundJob","type":"->"},{"file":"/snap/nextcloud/31033/htdocs/lib/public/BackgroundJob/QueuedJob.php","line":47,"function":"execute","class":"OCP\\BackgroundJob\\Job","type":"->"},{"file":"/snap/nextcloud/31033/htdocs/cron.php","line":151,"function":"execute","class":"OCP\\BackgroundJob\\QueuedJob","type":"->"}],"File":"/snap/nextcloud/31033/htdocs/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"MpyWrmcaJWkXVa21JqCM","level":2,"time":"2022-07-13T17:55:11+00:00","remoteAddr":"192.168.1.43","user":"--","app":"no app in context","method":"POST","url":"/index.php/login","message":"Login failed: root (Remote IP: 192.168.1.43)","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36","version":"24.0.1.1"}
The output of your Apache/nginx/system log in /var/snap/nextcloud/current/nextcloud/config/config.php:
'apps_paths' =>
0 =>
'path' => '/snap/nextcloud/current/htdocs/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/snap/nextcloud/current/nextcloud/extra-apps',
'url' => '/extra-apps',
'writable' => true,
'supportedDatabases' =>
0 => 'mysql',
'redis' =>
'host' => '/tmp/sockets/redis.sock',
'port' => 0,
'log_type' => 'file',
'logfile' => '/var/snap/nextcloud/current/logs/nextcloud.log',
'logfilemode' => 416,
'passwordsalt' => 'CENSURED',
'secret' => 'CENSURED',
0 => 'localhost',
1 => '192.168.1.63',
'datadirectory' => '/var/snap/nextcloud/common/nextcloud/data',
'version' => '24.0.1.1',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:/tmp/sockets/mysql.sock',
'dbuser' => 'CENSURED',
'dbpassword' => 'CENSURED',
'instanceid' => 'CENSURED',
'trusted_domain' =>
Thanks a lot for your help!
