Hi All,
I am not able to mount my samba share in nextcloud. And there is no exception in output log also. It’s showing only red mark in the front of share. I have installed both the client such as php-smbclient and samba client but gatting the same isssue. Kindly find my samba setting also:
Hi - having the same problem. I used to be able to mount the shares, but no longer can do so. I used to use the nextcloud login name and password - have also tried user entered name and password using donmain\username and just username.
In the Samba logs I am getting
[2018/02/02 09:47:20.134662, 0] ../source3/auth/auth_domain.c:226(domain_client_validate)
domain_client_validate: unable to validate password for user GUEST in domain RNET to Domain controller NSDC-SERVER.RNET.DUCKDNS.ORG. Error was NT_STATUS_WRONG_PASSWORD.
eg: seems to be trying to log into samba as a guest instead of the user.
Just upgraded to 12.0.5, and can now log in with Nextcloud login credentials.
