Habe die Server beidseitig als Trusted hinterlegt, Federated Sharing aktiviert.
Beim Hinzufügen eines Circles vom jeweils anderen Server kommt folgende Fehlermeldung:
A link to * name_of_the_circle@host_of_the_cloud* could not be initiated: Passing in the “body” request option as an array to send a POST request has been deprecated. Please use the “form_params” request option to send a application/x-www-form-urlencoded request, or the “multipart” request option to send a multipart/form-data request.
Any hints on how I can solve this despite not having a deeper knowledge on it?
This feature is currently not maintained and should not be used in its current state. I will remove any link to it from the Admin Interface in the next release of the app.
Please note that the concept of sharing to multiple users from multiple instances of Nextcloud is already available when using Global Scale and a Lookup Server.
While I cannot give you any future date for this, the Circles will helps you sharing on multiple instances of Nextcloud but with a better implementation of the feature and without Global Scale setup nor Lookup Server.
