Not able to delete from Remote Storage location (Locked Files)
    • Nextcloud Hub 9 (30.0.4)
    • Ubuntu 24.04
    • 2.4.58-1ubuntu8.5
    • replace me
    • 8.3.6
    • Yes
    • When I tried to delete a file
    • VM
    • Yes - Cloudflare
When I try to delete a file from either of 2 remote TrueNAS Scale remote storage locations, I am unable to do so.
  1. Create a test Document, Text file on remote storage
  2. Try to Delete, Get error
{"reqId":"zTRxKO30qOJFIhiHWBcx","level":3,"time":"2024-12-18T16:03:41+00:00","remoteAddr":"10.0.0.203","user":"Dino","app":"webdav","method":"MOVE","url":"/remote.php/dav/files/Dino/Remote%20Missions%20Team%20Share/Missions%20Photo%20Memories/Untitled.docx","message":"\"Remote Missions Team Share/Missions Photo Memories/Untitled.docx\" is locked, existing lock on file: 2 shared locks","userAgent":"Mozilla/5.0 (iOS) Nextcloud-iOS/6.1.9","version":"30.0.4.1","exception":{"Exception":"OCP\\Lock\\LockedException","Message":"\"Remote Missions Team Share/Missions Photo Memories/Untitled.docx\" is locked, existing lock on file: 2 shared locks","Code":0,"Trace":[{"file":"/var/www/nc.wisdomtechnow.com/lib/private/Files/View.php","line":756,"function":"changeLock","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/apps/dav/lib/Connector/Sabre/Node.php","line":133,"function":"rename","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/3rdparty/sabre/dav/lib/DAV/Tree.php","line":171,"function":"setName","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":612,"function":"move","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpMove","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/remote.php","line":146,"args":["/var/www/nc.wisdomtechnow.com/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nc.wisdomtechnow.com/lib/private/Files/View.php","Line":2001,"Previous":{"Exception":"OCP\\Lock\\LockedException","Message":"\"files/19e74fda73df86af9327ff88e1dc96d4\"(\"Missions Photo Memories/Untitled.docx\") is locked, existing lock on file: 2 shared locks","Code":0,"Trace":[{"file":"/var/www/nc.wisdomtechnow.com/lib/private/Files/Storage/Wrapper/Wrapper.php","line":614,"function":"changeLock","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/lib/private/Files/Storage/Wrapper/Wrapper.php","line":614,"function":"changeLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/lib/private/Files/Storage/Wrapper/Wrapper.php","line":614,"function":"changeLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/lib/private/Files/View.php","line":1992,"function":"changeLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/lib/private/Files/View.php","line":756,"function":"changeLock","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/apps/dav/lib/Connector/Sabre/Node.php","line":133,"function":"rename","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/3rdparty/sabre/dav/lib/DAV/Tree.php","line":171,"function":"setName","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":612,"function":"move","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpMove","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/remote.php","line":146,"args":["/var/www/nc.wisdomtechnow.com/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nc.wisdomtechnow.com/lib/private/Files/Storage/Common.php","Line":766,"Previous":{"Exception":"OCP\\Lock\\LockedException","Message":"\"files/19e74fda73df86af9327ff88e1dc96d4\" is locked, existing lock on file: 2 shared locks","Code":0,"Trace":[{"file":"/var/www/nc.wisdomtechnow.com/lib/private/Files/Storage/Common.php","line":764,"function":"changeLock","class":"OC\\Lock\\MemcacheLockingProvider","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/lib/private/Files/Storage/Wrapper/Wrapper.php","line":614,"function":"changeLock","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/lib/private/Files/Storage/Wrapper/Wrapper.php","line":614,"function":"changeLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/lib/private/Files/Storage/Wrapper/Wrapper.php","line":614,"function":"changeLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/lib/private/Files/View.php","line":1992,"function":"changeLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/lib/private/Files/View.php","line":756,"function":"changeLock","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/apps/dav/lib/Connector/Sabre/Node.php","line":133,"function":"rename","class":"OC\\Files\\View","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/3rdparty/sabre/dav/lib/DAV/Tree.php","line":171,"function":"setName","class":"OCA\\DAV\\Connector\\Sabre\\Node","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":612,"function":"move","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpMove","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/apps/dav/lib/Connector/Sabre/Server.php","line":43,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/apps/dav/lib/Server.php","line":371,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/apps/dav/appinfo/v2/remote.php","line":19,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nc.wisdomtechnow.com/remote.php","line":146,"args":["/var/www/nc.wisdomtechnow.com/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nc.wisdomtechnow.com/lib/private/Lock/MemcacheLockingProvider.php","Line":126}},"message":"\"Remote Missions Team Share/Missions Photo Memories/Untitled.docx\" is locked, existing lock on file: 2 shared locks","exception":[],"CustomMessage":"\"Remote Missions Team Share/Missions Photo Memories/Untitled.docx\" is locked, existing lock on file: 2 shared locks"},"id":"67637a3adf13e"}
PASTE
PASTE HERE
  'instanceid' => '',
  'passwordsalt' => '',
  'secret' => '',
    0 => 'nc.wisdomtechnow.com',
  'datadirectory' => '/var/www/nc.wisdomtechnow.com/data',
  'version' => '30.0.4.1',
  'overwrite.cli.url' => 'https://nc.wisdomtechnow.com',
  'dbname' => 'nextcloud',
  'dbhost' => 'localhost',
  'dbuser' => 'nextcloud',
  'dbpassword' => ',
  'default_phone_region' => 'US',
  'mail_domain' => 'comcast.net',
  'mail_from_address' => 'whitedinotech',
  'mail_smtpmode' => 'smtp',
  'theme' => '',
  'loglevel' => 2,
  'mail_smtpauth' => 1,
  'mail_smtpname' => '',
  'mail_smtppassword' => '',
  'app_install_overwrite' =>
    0 => 'news',
    1 => 'maps',
    2 => 'officeonline',
    3 => 'occweb',
  'mail_smtphost' => 'smtp.comcast.net',
  'mail_smtpport' => '587',
  'memories.db.triggers.fcu' => true,
  'memories.exiftool' => '/var/www/nc.wisdomtechnow.com/apps/memories/bin-ext/exiftool-amd64-glibc',
  'memories.vod.path' => '/var/www/nc.wisdomtechnow.com/apps/memories/bin-ext/go-vod-amd64',
  'enabledPreviewProviders' =>
    0 => 'OC\\Preview\\Image',
    1 => 'OC\\Preview\\HEIC',
    2 => 'OC\\Preview\\TIFF',
    3 => 'OC\\Preview\\Movie',
  'memories.exiftool_no_local' => true,
  'redis' =>
Does no one have any input? Am I giving enough info?
