Nextcloud version (eg, 20.0.5): 25.0.3
Operating system and version (eg, Ubuntu 20.04): Ubuntu 18.04.4 LTS
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.29
PHP version (eg, 7.4): 8.1
I am having issues with my recent Nextcloud install on a shared hosting solution (dreamhost). I have tried two different shared hosting solutions (shared hosting is important to me due to cost consolidation) and I have seen the issue in both places.
When I try to click on either icon in the far right hand side of my nextdoor webpage, (User and people I assume?) I get no popup or any interaction. Functions just like a standard picture.
- Log in
- Attempt to click buttons
Error PHP Error: file_get_contents(/home/dh_hhr9vu/jasbro85.dreamhosters.com/data/data/appdata_ocnzy376gsfc/preview/4/5/c/4/8/c/c/9/500-500-max.png): Failed to open stream: No such file or directory at /home/dh_hhr9vu/jasbro85.dreamhosters.com/data/lib/private/Files/Storage/Local.php#303 2023-02-10T15:44:26-0500
Error PHP Error: exif_read_data(): File not supported at /home/dh_hhr9vu/jasbro85.dreamhosters.com/data/lib/private/Metadata/Provider/ExifProvider.php#59 2023-02-10T15:08:50-0500
Warning no app in context Could not detect any host in https:///data/data/htaccesstest.txt 2023-02-10T15:07:20-0500
Warning no app in context Could not detect any host in http:///data/data/htaccesstest.txt 2023-02-10T15:07:20-0500
Warning no app in context Could not detect any host in https:///data/data/htaccesstest.txt 2023-02-10T15:06:14-0500
Warning no app in context Could not detect any host in http:///data/data/htaccesstest.txt 2023-02-10T15:06:14-0500
'instanceid' => 'ocnzy376gsfc',
'passwordsalt' => '********',
'secret' => '********',
0 => '********.com',
'datadirectory' => '/home/dh_hhr9vu/********/data/data',
'version' => '25.0.3.2',
'overwrite.cli.url' => 'http://********.com/data',
'dbname' => 'ns_nextcloud',
'dbhost' => 'nextcloud.********.com',
'dbuser' => '********',
'dbpassword' => '********',
'app_install_overwrite' =>
0 => 'extract',
1 => 'apporder',
No access to logs
No access to logs
