I downloaded the last version of Nextcloud for Odroid, wrote it to sd-card, made a “touch ssh” in the root-folder and started the machine with it. I get into the web-interface and can work there. SSH is not enabled and if I try to enable it, I get the message, that root has the standart-password and that’s a security-issue and therefore SSH will not be enabled.
Login to the machine direct via keyboard and monitor: with pi and raspberry I get incorrect login. Login with ncp and his password works - I get the login-berry-image, but that ends immediately with a logout.
What can I do?
Spielmops
Found it myself:
login user: root, password: 1234
