I use my Nextcloud-System for editing files with the macOS- and iOS-Client and I edit files over SSH-connection on the server. All worked fine, I like it.
Today I wanted to edit a PDF with the iOS-App PDF Expert and tried with webDAV by .../remote.php/dav/files/USER
and by .../webdav/
. It didnāt work and I find a solution by using a ftp-connection. But after editing a PDF in PDF Expert the synch did not start. I had to open the browser interface, open the PDF and then macOS was synching the file.
Okay, thatās the pre-problem.
But now both of my iOS-Clients do not work anymore (iPad and iPhone). They both do no synch and there isnāt a real error but on German āZeitĆ¼berschreitungā (time exceeded). But nothing more ā¦
I didnāt change something in config.php or in the settings. Do you know about this problem? What happened? Is there a solution?
I work with Nextcloud 13.0.1 because in the past I had lots of problems with updates and this is a wonderful system working til today ā¦
Thanks for your help!
EDIT: Itās crazy. At the moment I think itās based on WLAN!? But I didnāt change anything with the WLAN. But the iOS-App works with mobile data. And with WLAN there is no connection possible to macOS-/iOS-Client but to the Browser-Client!?
