There’s no delete button when I try to delete an existing auto upload entry on android.
Hi @DraconPern
Just disable auto upload for this entry and the app will no longer upload new files that are added to this folder.
Deleting entries is not possible, afaik, and even if it was, chances are they would come back because the app automatically detects folders on your device containing media files and adds them to the list.
