Hello!
I created the following docker compose file:
version: “3.8” # Specify Docker Compose file version
services:
nextcloud:
init: true
restart: always
ports:
- “80:80”
- “8080:8080”
- “8443:8443”
volumes:
but I get the next error message: Named volume “nextcloud_aio_mastercontainer:/mnt/docker-aio-config:rw” is used in service “nextcloud” but no declaration was found in the volumes section.
I thought: “Maybe if I add that volume in the ‘volumes’ section, it will run!” but it didn’t. I got the same error message. I’m a noob at all of this, so I’m sorry if this is really basic, or I did something else wrong. Thanks in advance.
