No connection to Nextcloud at <url> Operation canceled
I just want to confirm after enabling the bruteforce app and whitelist my router and isp modem IP address, everything start syncing again
Hi all,
I am having the similar issue but I am not at home right now to double check but I believe this is also something new.
I have Zorin (Ubuntu 16.04) running on the latest version of Nextcloud server. I have done nothing different and server had been running perfect for about 2 to 3 years. Now all of the sudden (I promise except updating Linux and I had done nothing). My nextcloud server will be offline and I cannot access it fro Linux or Web or Windows desktop. But if I reboot the linux server and it will start working again for a while and then stop.
Has anyone encounter the same thing? (this started in the last two weeks) and now I cannot connect to my cloud at all and sync all the changes as I go alone. Any suggestions would be greatly appreciated.
Thanks,
Brad
It seems like I have issue with apache2 server but it never happened until last two three weeks. Can someone please help me to read through this? Sorry I am using Windows at the moment (Linux).
[Wed Sep 05 14:21:36.302258 2018] [ssl:warn] [pid 27181] AH01906: e52ae06211359775e7e39613bdeec8b1.a9b1bbf4d64fb2c3a21536e8544133d9.acme.invalid:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Sep 05 14:21:36.371975 2018] [ssl:warn] [pid 27182] AH01906: e52ae06211359775e7e39613bdeec8b1.a9b1bbf4d64fb2c3a21536e8544133d9.acme.invalid:443:0 server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Sep 05 14:21:36.380911 2018] [mpm_prefork:notice] [pid 27182] AH00163: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g configured – resuming normal operations
[Wed Sep 05 14:21:36.380960 2018] [core:notice] [pid 27182] AH00094: Command line: ‘/usr/sbin/apache2’
[Wed Sep 05 14:21:43.361887 2018] [mpm_prefork:notice] [pid 27182] AH00171: Graceful restart requested, doing restart
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 127.0.1.1. Set the ‘ServerName’ directive globally to suppress this message
[Wed Sep 05 14:21:43.462679 2018] [mpm_prefork:notice] [pid 27182] AH00163: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g configured – resuming normal operations
[Wed Sep 05 14:21:43.462706 2018] [core:notice] [pid 27182] AH00094: Command line: ‘/usr/sbin/apache2’
[Wed Sep 05 14:21:46.382281 2018] [mpm_prefork:notice] [pid 27182] AH00171: Graceful restart requested, doing restart
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
[Wed Sep 05 14:21:46.428163 2018] [mpm_prefork:alert] [pid 27182] no listening sockets available, shutting down
[Wed Sep 05 14:21:46.428170 2018] [:emerg] [pid 27182] AH00019: Unable to open logs, exiting
[Wed Sep 05 14:22:00.860918 2018] [core:warn] [pid 27286] AH00098: pid file /var/run/apache2/apache2.pid overwritten – Unclean shutdown of previous Apache run?
[Wed Sep 05 14:22:00.866136 2018] [mpm_prefork:notice] [pid 27286] AH00163: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g configured – resuming normal operations
[Wed Sep 05 14:22:00.866175 2018] [core:notice] [pid 27286] AH00094: Command line: ‘/usr/sbin/apache2’
[Wed Sep 05 14:22:01.179020 2018] [mpm_prefork:notice] [pid 27286] AH00169: caught SIGTERM, shutting down
[Wed Sep 05 16:55:23.438189 2018] [mpm_prefork:notice] [pid 6186] AH00163: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g configured – resuming normal operations
[Wed Sep 05 16:55:23.438948 2018] [core:notice] [pid 6186] AH00094: Command line: ‘/usr/sbin/apache2’
[Wed Sep 05 17:36:31.098823 2018] [mpm_prefork:notice] [pid 6186] AH00171: Graceful restart requested, doing restart
[Wed Sep 05 17:36:31.175499 2018] [mpm_prefork:alert] [pid 6186] no listening sockets available, shutting down
[Wed Sep 05 17:36:31.175505 2018] [:emerg] [pid 6186] AH00019: Unable to open logs, exiting
[Wed Sep 05 17:36:45.294836 2018] [core:warn] [pid 9744] AH00098: pid file /var/run/apache2/apache2.pid overwritten – Unclean shutdown of previous Apache run?
[Wed Sep 05 17:36:45.300268 2018] [mpm_prefork:notice] [pid 9744] AH00163: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g configured – resuming normal operations
[Wed Sep 05 17:36:45.300325 2018] [core:notice] [pid 9744] AH00094: Command line: ‘/usr/sbin/apache2’
[Wed Sep 05 18:12:26.957363 2018] [mpm_prefork:notice] [pid 9744] AH00169: caught SIGTERM, shutting down
[Wed Sep 05 18:13:58.283337 2018] [mpm_prefork:notice] [pid 13784] AH00163: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g configured – resuming normal operations
[Wed Sep 05 18:13:58.283427 2018] [core:notice] [pid 13784] AH00094: Command line: ‘/usr/sbin/apache2’
[Wed Sep 05 18:14:56.813378 2018] [mpm_prefork:notice] [pid 13784] AH00169: caught SIGTERM, shutting down
[Wed Sep 05 18:15:58.405671 2018] [mpm_prefork:notice] [pid 13942] AH00163: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g configured – resuming normal operations
[Wed Sep 05 18:15:58.405763 2018] [core:notice] [pid 13942] AH00094: Command line: ‘/usr/sbin/apache2’
[Wed Sep 05 18:16:38.802050 2018] [mpm_prefork:notice] [pid 13942] AH00171: Graceful restart requested, doing restart
[Wed Sep 05 18:16:38.872330 2018] [mpm_prefork:alert] [pid 13942] no listening sockets available, shutting down
[Wed Sep 05 18:16:38.872335 2018] [:emerg] [pid 13942] AH00019: Unable to open logs, exiting
[Wed Sep 05 18:16:56.032956 2018] [core:warn] [pid 14198] AH00098: pid file /var/run/apache2/apache2.pid overwritten – Unclean shutdown of previous Apache run?
[Wed Sep 05 18:16:56.037560 2018] [mpm_prefork:notice] [pid 14198] AH00163: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g configured – resuming normal operations
[Wed Sep 05 18:16:56.037606 2018] [core:notice] [pid 14198] AH00094: Command line: ‘/usr/sbin/apache2’
[Wed Sep 05 18:17:49.357087 2018] [ssl:error] [pid 14289] [client 64.41.200.103:39344] AH02042: rejecting client initiated renegotiation
[Thu Sep 06 07:36:24.812923 2018] [mpm_prefork:notice] [pid 14198] AH00171: Graceful restart requested, doing restart
AH00112: Warning: DocumentRoot [/var/lib/letsencrypt/tls_sni_01_page/] does not exist
