Hi I’m running nextcloud 18.3 with nginx as a frontend on freebsd. All is well and things are running with SSL certs.
What I’m trying to do is stick an nginx reverse proxy in front of my nginx/nextcloud installation – and well this is where things are not working.
I tested the reverse proxy and ensured it can serve up a simple webpage (prior to adding the proxy_pass statements) so I’ve verified the reverse proxy is reachable and can server a simple web page.
My test setup is a VM running an nginx reverse proxy known as test.example.com that proxies to https://nextcloud.example.com
My reverse proxy (which is running in a separate VM than nginx/nextcloud) is configured like this for proxy_pass to nextcloud:
location / {
proxy_ssl_verify off;
proxy_ssl_verify_depth 2;
proxy_pass https://nextcloud.example.com;
I’m not sure if I was supposed to change the nextcloud config file but I added the following:
'trusted_proxies' =>
0 => 'localhost',
1 => 'test.example.com',
2 => '10.0.1.86',
The ip address of test.example.com is 10.0.1.86
I can’t even get to first base on my setup — I get to the actual nextcloud page (which is good), but when I try to login I’m rejected with wrong username/password.
Perhaps I’ve tried so many times "I’ve banned myself since I see this in the logs:
n","message":"Login failed: nc_admin (Remote IP: 10.0.1.184)","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:75.0) Gecko/20100101 Firefox/75.0","version":"18.0.3.0"}
`{"reqId":"uOMq1ER1jkgt61lrh2g3","level":1,"time":"April 13, 2020 19:02:49","remoteAddr":"10.0.1.184","user":"--","app":"core","method":"POST","url":"/login","message":"Bruteforce attempt from \"10.0.1.184\" detected for action \"login\".","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:75.0) Gecko/20100101 Firefox/75.0","version":"18.0.3.0"}`
I’m kind of confused where to go now.
