So I have been installing multiple nextcloud installations on subdirectories i.e domain.com/a001, domain.com/a002 and so on.
in nginx configuration file to deal with carddav and caldav warning, I am adding following block per subdirectory as suggested in documentation.
return 301 $scheme://$host:$server_port/a001/remote.php/dav;
this works for a001 but when I use the same for a002 the location block duplication error comes in nginx and it fails which is the correct response from nginx.
Is there any workaround to have it setup for multiple nextcloud installation in subdirectories.
I will really appreciate all the help and thanks a lot for your time in advance.
[/details]
Nextcloud version: 18.0.2
Operating system and version: kubernetes, Docker
Docker image: nextcloud:latest
- install multiple nextcloud installation in subdirectories i.e domain.com/a001, domain.com/a002
* Your web server is not properly set up to resolve "/.well-known/caldav". Further information can be found in the [documentation](https://docs.nextcloud.com/server/18/go.php?to=admin-setup-well-known-URL).
* Your web server is not properly set up to resolve "/.well-known/carddav". Further information can be found in the [documentation](https://docs.nextcloud.com/server/18/go.php?to=admin-setup-well-known-URL).
No log related to this.
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'passwordsalt' => 'weeicwufhewoifigerugnv/y5MVFSFJbw',
'secret' => 'DINH+klfjksdfsdjfsdjfkjsdlkfjksdjklf',
0 => 'localhost',
1 => 'domain.com',
'version' => '18.0.4.2',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'a002_db',
'dbhost' => 'proxysql:6033',
'dbuser' => 'exampleu',
'dbpassword' => 'examplepass#',
'instanceid' => 'exampleid',
'overwritewebroot' => '/a002',
'trusted_proxies' =>
0 => 'localhost',
1 => 'domain.com',
