NFS mount issue after updating to AIO 10.5.0
  • Nextcloud AIO version (e.g., 29.x.x):
    • 10.5.0
    • 30.5.0
    • Ubuntu 22.04.5
    • yes
    • After the update to 10.5.0
    • AIO - docker-compose - Portainer
The nextcloud server is running and the interface is reachable, however, there is no Nextcloud application data anymore (e.g. Profile Pictures, Appdata, etc)
Error Log from the nextcloud interface:
Error	no app in context
GenericFileException
Exception thrown: OCP\Files\GenericFileException
18.02.2025, 16:01:23
Error	PHP
file_get_contents(/mnt/ncdata/appdata_ocomx0ntiv1d/appstore/apps.json): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#296
Error	index
18.02.2025, 16:01:06
Error	PHP
file_get_contents(/mnt/ncdata/appdata_ocomx0ntiv1d/avatar/Lucas/avatar.64.png): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#296
Error	index
Error	PHP
file_get_contents(/mnt/ncdata/appdata_ocomx0ntiv1d/avatar/Artl/avatar.64.png): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#296
Error	index
18.02.2025, 16:01:05
Error	PHP
file_get_contents(/mnt/ncdata/appdata_ocomx0ntiv1d/avatar/Fred/avatar.64.png): Failed to open stream: No such file or directory at /var/www/html/lib/private/Files/Storage/Local.php#296
18.02.2025, 16:00:02
Error	PHP
Docker Compose:
# https://github.com/nextcloud/all-in-one/blob/main/compose.yaml
services:
  nextcloud:
    init: true
    restart: always
    labels:
      tsdproxy.enable: "true"
      tsdproxy.name: "next"
      tsdproxy.container_port: 11000
    volumes:
    network_mode: bridge # add to the same network as docker run would do
    ports:
    #  - 80:80 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      - 8080:8080
    #  - 8443:8443 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      - dns= "1.1.1.1"
      # - AIO_DISABLE_BACKUP_SECTION=false # Setting this to true allows to hide the backup section in the AIO interface.
      # - AIO_COMMUNITY_CONTAINERS: # With this variable, you can add community containers very easily. See https://github.com/nextcloud/all-in-one/tree/main/community-containers#community-containers
      - APACHE_PORT=11000 # Is needed when running behind a web server or reverse proxy (like Apache, Nginx and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      - APACHE_IP_BINDING=0.0.0.0 # Should be set when running behind a web server or reverse proxy (like Apache, Nginx and else) that is running on the same host. See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      # - APACHE_ADDITIONAL_NETWORK: frontend_net # (Optional) Connect the apache container to an additional docker network. Needed when behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else) running in a different docker network on same server. See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      # - BORG_RETENTION_POLICY=--keep-within=7d --keep-weekly=4 --keep-monthly=6 # Allows to adjust borgs retention policy. See https://github.com/nextcloud/all-in-one#how-to-adjust-borgs-retention-policy
      # - COLLABORA_SECCOMP_DISABLED=false # Setting this to true allows to disable Collabora's Seccomp feature. See https://github.com/nextcloud/all-in-one#how-to-disable-collaboras-seccomp-feature
      - NEXTCLOUD_DATADIR=/nfs/nextcloud/data # Allows to set the host directory for Nextcloud's datadir. See https://github.com/nextcloud/all-in-one#how-to-change-the-default-location-of-nextclouds-datadir
      - NEXTCLOUD_MOUNT=/nfs/nextcloud/ # Allows the Nextcloud container to access the chosen directory on the host. See https://github.com/nextcloud/all-in-one#how-to-allow-the-nextcloud-container-to-access-directories-on-the-host
      # - NEXTCLOUD_UPLOAD_LIMIT=16G # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-upload-limit-for-nextcloud
      # - NEXTCLOUD_MAX_TIME=3600 # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-max-execution-time-for-nextcloud
      - NEXTCLOUD_MEMORY_LIMIT=1024M # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-php-memory-limit-for-nextcloud
      # - NEXTCLOUD_TRUSTED_CACERTS_DIR=/path/to/my/cacerts # CA certificates in this directory will be trusted by the OS of the nexcloud container (Useful e.g. for LDAPS) See See https://github.com/nextcloud/all-in-one#how-to-trust-user-defiend-certification-authorities-ca
      - NEXTCLOUD_STARTUP_APPS=deck twofactor_totp tasks calendar contacts notes # Allows to modify the Nextcloud apps that are installed on starting AIO the first time. See https://github.com/nextcloud/all-in-one#how-to-change-the-nextcloud-apps-that-are-installed-on-the-first-startup
      # - NEXTCLOUD_ADDITIONAL_APKS=imagemagick # This allows to add additional packages to the Nextcloud container permanently. Default is imagemagick but can be overwritten by modifying this value. See https://github.com/nextcloud/all-in-one#how-to-add-os-packages-permanently-to-the-nextcloud-container
      # - NEXTCLOUD_ADDITIONAL_PHP_EXTENSIONS=imagick # This allows to add additional php extensions to the Nextcloud container permanently. Default is imagick but can be overwritten by modifying this value. See https://github.com/nextcloud/all-in-one#how-to-add-php-extensions-permanently-to-the-nextcloud-container
      # - NEXTCLOUD_ENABLE_DRI_DEVICE=true # This allows to enable the /dev/dri device in the Nextcloud container which is needed for hardware-transcoding. See https://github.com/nextcloud/all-in-one#how-to-enable-hardware-transcoding-for-nextcloud
      # - NEXTCLOUD_KEEP_DISABLED_APPS: false # Setting this to true will keep Nextcloud apps that are disabled in the AIO interface and not uninstall them if they should be installed. See https://github.com/nextcloud/all-in-one#how-to-keep-disabled-apps
      # - SKIP_DOMAIN_VALIDATION: false # This should only be set to true if things are correctly configured. See https://github.com/nextcloud/all-in-one?tab=readme-ov-file#how-to-skip-the-domain-validation
      # - TALK_PORT=3478 # This allows to adjust the port that the talk container is using.
      # - WATCHTOWER_DOCKER_SOCKET_PATH=/var/run/docker.sock # Needs to be specified if the docker socket on the host is not located in the default '/var/run/docker.sock'. Otherwise mastercontainer updates will fail. For macos it needs to be '/var/run/docker.sock'
    # networks: # Is needed when you want to create the nextcloud-aio network with ipv6-support using this file, see the network config at the bottom of the file
      # - nextcloud-aio # Is needed when you want to create the nextcloud-aio network with ipv6-support using this file, see the network config at the bottom of the file
      - PUID=1000 # Also tried 0
      - PGID=101 # Also tried 0
volumes:
The NFS mount and all data in it is accessible rw on my Ubuntu host
The logs from the Nextcloud Container:
2025-02-18T15:10:06.212074189Z app:update [--all] [--showonly] [--allow-unstable] [--] [<app-id>]
2025-02-18T15:10:06.212079487Z
2025-02-18T15:10:06.934231234Z Config value were not updated
2025-02-18T15:10:07.657088836Z Config value were not updated
2025-02-18T15:10:07.701306569Z + '[' true = true ']'
2025-02-18T15:10:07.701368031Z + '[' 11000 = 443 ']'
2025-02-18T15:10:07.701422504Z + set +x
2025-02-18T15:10:09.196657526Z Waiting for Apache to become available...
2025-02-18T15:10:09.393062880Z [18-Feb-2025 16:10:09] NOTICE: fpm is running, pid 284
2025-02-18T15:10:09.393104765Z [18-Feb-2025 16:10:09] NOTICE: ready to handle connections
2025-02-18T15:10:24.200451659Z Connection to nextcloud-aio-apache (172.20.0.14) 11000 port [tcp/*] succeeded!
2025-02-18T15:10:24.203966141Z Activating Collabora config...
2025-02-18T15:10:25.048850197Z ✓ Reset callback url autodetect
2025-02-18T15:10:25.048884798Z Checking configuration
2025-02-18T15:10:25.048891387Z 🛈 Configured WOPI URL: https://xxxxx
2025-02-18T15:10:25.048896691Z 🛈 Configured public WOPI URL: https://xxxx
2025-02-18T15:10:25.048902187Z 🛈 Configured callback URL:
2025-02-18T15:10:25.048907296Z
2025-02-18T15:10:25.131016736Z Failed to fetch discovery endpoint from https://next.at.dtv.live
2025-02-18T15:10:25.131054055Z Could not create path "/appdata_ocomx0ntiv1d/richdocuments/remoteData/discovery"
