Since about August 2018 I run a NextCloudPi instance. After a few weeks after installation, I changed from 16 GB internal SD usage to 240 GB SSD usage and activated the following features using the NCP GUI:
- auto NC updates
- auto NC apps updates (I don’t use any, though)
- data dir at: /media/SSD240GB/ncdata
- database dir at: /media/SSD240GB/ncdatabase
- auto backups at: /media/SSD240GB/ncp-backups
With these settings, I successfully managed to avoid hitting any SD write cycle limitations for about 2,5 years with no issues so far.
One thing just kept bothering me, though: when I changed from internal SD usage (16 GB) to USB SSD usage (240 GB) back in 2018, the “available” amount of storage memory didn’t change from 16 GB to 240 GB within the NCP settings and status menus. I was not concerned, though, as I thought it might update some time in the future.
Now, after uploading a set of “big” pictures on one of the clients, I managed to hit the former SD storage limitation of ~15 GB. And the connected client refuses to upload the files, issuing the simple message:
Connection closed
within the Client’s GUI.
DETAILS / SETTINGS
The NCP status page shows:
NextCloudPi version: v1.35.0
NextCloudPi image: NextCloudPi_03-04-19
distribution: Raspbian GNU/Linux 9 \n \l
automount: no
USB devices: sda
datadir: /media/SSD240GB/ncdata
data in SD: yes
data filesystem: ext2/ext3 (the SD is ext4)
data disk usage: 14G/15G
rootfs usage: 14G/15G
swapfile: /var/swap
dbdir: /media/SSD240GB/ncdatabase
Nextcloud check: ok
Nextcloud version: 20.0.2.2
HTTPD service: up
PHP service: up
MariaDB service: up
Redis service: up
Postfix service: up
internet check: ok
port check 80: open
port check 443: open
IP: 192.162.1.93
gateway: 192.168.1.1
interface: eth0
certificates: …
NAT loopback: no
uptime: 30days
OS: Linux 4.19.66-v7+ armv7
Prozessor: ARMv7 Processor rev 4 (v7l) (4 cores)
PHP Version: 7.2.34
Database: mysql, v10.1.48, size: 92,3 MB
- upload any file with about 20 MB size on any client
[ the protocol does not finish loading using NCP GUI ]
