I have been able to successfully install nextcloudpi on a raspberry pi and on an intel mac using docker. However, I have not been able to successfully install nextcloudpi on a new M1 mac.
The logs show āinit doneā and that everything is running, however, when I go to https://localhost:443 to activate Nexcloudpi, either nothing happens, or the browser complains that the site is not secure and doesnāt let me proceed. This is doubly strange, because if I try to go the insecure http://localhost:443, the browser complains that the site is ssl-enabled. I have done my best to get the browser to use the self-signed certificate, but nothing worksā¦
Does anyone have any ideas on what is going on? Given that Iāve gotten this to work on an intel mac and Pi, Iām pretty sure that Iām not doing anything dumb, but to be honest, I rarely use docker.
For info, running the x86 version on the same M1 mac DOES work, but of course you get a warning that it will be run in emulation mode with a decrease in performance
docker run -d -p 4443:4443 -p 443:443 -p 80:80 -v ncdata:/data --name nextcloudpi ownyourbits/nextcloudpi-x86 10.179.249.107
WARNING: The requested imageās platform (linux/amd64) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
This seems to indicate that there is something wrong with ARM64 docker container on M1 macs.
This is because you are using a self-signed certificateā¦ all browsers show a warning when a self signed certificate is used but on some you have the possibility to continue on the site.
Thanks for the response, but that is not the problem: Accessing the activation page works fine when installing the x86 version on an M1 mac.
Yes, my browser does warns me that the site uses a self-signed certificate, and I am given the option to proceed. When using the x86 container on an M1, after clicking āokā, I arrive at the activation page. Using the ARM64 container on an M1, after clicking āokā, nothing happens.
