Nextcloud version: Unknown, but installed fresh 2 weeks ago (roughly 5/22?)
Operating system and version: Raspbian stretch (I don’t know version number, sorry)
Apache or nginx version: Unknown - installed via docker
PHP version: Unknown
Cannot navigate to any web interfaces after power outage.
Unfortunately I’m not much of a software guy so I’m not sure how to get some of the requested info. But to describe my situation: 2 weeks ago I decided to install nextcloud on my raspberry Pi. I installed the then latest version of raspbian and a friend mentioned docker might be a good idea for Nextcloud installation. I configured fstab to automount a 1TB USB drive and partitioned it with space for the docker container and space for the data to be stored separately. I’m pretty sure I have a wrong understanding of how these are segmented and how docker works, but that’s how I configured it. I do have the command’s I’ve run saved so here they are:
pi@hostname:~ $ curl -sSL get.docker.com | sh
pi@hostname:~ $ sudo usermod -aG docker pi
pi@hostname:~ $ newgrp docker
pi@hostname:~ $ sudo nano /lib/systemd/system/docker.service
#edit ExecStart=/usr/bin/dockerd -g /media/USB/NCapp/Docker -H fd://
pi@hostname:/mnt $ docker run -d -p 4443:4443 -p 444:443 -p 8080:80 -v /media/USB/NCstorage/ncdata:/data --name nextcloudpi ownyourbits/nextcloudpi-armhf cloud.[domain].[tld]
You’ll note I’m not using all standard ports as I have a VPN to my home network as well as pihole running on my pi as well, so I wanted to leave 80 and 443 alone. I have a nat translation rule in my firewall so public access is actually over 443 like it should be.
This worked GREAT. Unfortunately while getting a new ISP today I bumped the power cord on my pi and it went down hard. It came back - weird. Pi hole didn’t autostart, but worked after manually starting. I knew I had yet to configure autostart for Nextcloud so I ran
docker start nextcloudpi
and it seemed to start running, but I couldn’t get into any web interface via local network or internet. I tried configuring autostart and also rebooting my pi, but it seems to not be working and I have no idea how to troubleshoot. Any help? For what it’s worth, if there’s a way to just re-install while keeping my client user/data intact this would be fine with me.
Is this the first time you’ve seen this error? (Y/N): Yes
- Power on pi
- Run docker ld and verify nextcloudpi is “up”
- attempt to navigate to https://[local-network-IP]:4443 (or 444 or https://[publicdomain].[tld])
- get a 404 on your browser
Is this from the web interface? I can’t get there.
Given that I’m using docker, I’m not sure how to do this. Sorry.
