[/details]
Nextcloud version: 16.0.3
Operating system and version: Raspbian Buster
Apache or nginx version: Apache 2
PHP version: 7.3
Hello, I have a problem. I set up a raspberry pi with nextcloudpi and everythings works fine except one thing. I cannot connect to nextcloud through ipv6 using only my dynDNS Domain. It works with the ipv6 IP address though, but in this case it of course shows an error message saying not allowed through this domain.
I use spdyn as a dynDNS and updates the correct IP adresses. Ipv4 through my Router fritz.box and ipv6 through nextcloudpi software itself.
I tried using noip but I have the same problem.
With ipv4 everything works fine.
I think it cant be the router or the firewall because I can connect through the ip.
Can somebody help me?
Below is may nextcloud config.php which I hopefulle sensored correctly
'passwordsalt' => 'uyr',
'secret' => 'QKr',
0 => 'localhost',
11 => '2003:::::::4738',
1 => '192.168.178.100',
5 => 'nextcloudpi.local',
7 => 'nextcloudpi',
8 => 'nextcloudpi.lan',
4 => 'xxx.spdns.de',
3 => 'xxx.ddns.net',
'datadirectory' => '/mnt/Nextcloud/NextcloudData',
'version' => '16.0.3.0',
'overwrite.cli.url' => 'https://xxx.ddns.net/',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'ncadmin',
'dbpassword' => 'uZY=',
'instanceid' => 'ocdj',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'timeout' => 0.0,
'password' => 'GTnmF4=',
'tempdirectory' => '/mnt/Nextcloud/NextcloudData/tmp',
'mail_smtpmode' => 'sendmail',
'mail_from_address' => 'admin',
'mail_domain' => 'ownyourbits.com',
'preview_max_x' => '2048',
'preview_max_y' => '2048',
'jpeg_quality' => '60',
'loglevel' => '2',
'log_type' => 'file',
'logfile' => '/mnt/Nextcloud/NextcloudData/nextcloud.log',
