NextcloudPi but no NextcloudPi interface
    • 33.0.2.2
    • Pi OS 64 bits based on Debian Bookworm
    • 2.4.66
    • don't know
    • PHP 8.3.30
    • Yes
    • since beginning
    • curl from github
    • don’t think
For the first time, I try to use my Raspberry Pi in order to host my data (cloud for the local network first which could, maybe later , be accessed from outside). Using curl cmd from github/nextcloudpi, I installed NextcloudPi. I can access Pi Wizard, then NextcloudPi or either Nextcloud but the issue is that when I adress Nexcloud, I don’t have the usual NextcloudPi interface and I don’t know why.
  1. even doing https://nextcloudpi.local I still have classic nextcloud interface.
  2. Unit ncp-web.service could not be found.
200 no redirection , domain is nextcloudpi and not nextcloud.com so I expected to see NextcloudPi
later maybe
    0 => 'localhost',
    7 => 'nextcloudpi',
    5 => 'nextcloudpi.local',
    8 => 'nextcloudpi.lan',
    3 => 'nextcloudpi',
'datadirectory' => '/media/myCloudDrive/ncdata/data',
  'version' => '33.0.2.2',
  'overwrite.cli.url' => 'https://nextcloudpi/',
  'dbname' => 'nextcloud',
  'dbhost' => 'localhost',
'tempdirectory' => '/media/myCloudDrive/ncdata/data/tmp',
  'mail_smtpmode' => 'sendmail',
  'mail_from_address' => 'noreply',
  'mail_domain' => 'nextcloudpi.com',
  'logfile' => '/media/myCloudDrive/ncdata/data/nextcloud.log',
Hello and welcome.
Can you access your Nextcloud using its IP address? Of course, the IP address must also be added as a trusted domain for this to work.
In any case, I would add the localhost address 127.0.0.1 as a trusted domain.
It is not clear what you are missing.
https://nextcloudpi.local:4443 ?
Hello ttlb!
My own experience in the past was that it yielded more stable results to use the delivered card images here Release v1.57.0 · nextcloud/nextcloudpi · GitHub
instead of the approach using curl.
Since you just started from scratch it likely doesnt mean loosing a lot to try it this way.
I guess it will be more pain to fix your situation based on what you have.
