Hi, I love love this nextcloud server stuff. I use it with nextcloudpi (raspberry pi). Unfortunately, i have tried using a USB drive 5TB to save stuff and also use it as my storage device for my home network (family, son, etc), but I have been unable to set it to work as a drive.
However, I dont have access to my USB drive, it seems there is a permission issue. I am not proficient or know linux, I am an enthusiast and play with this as a hobby.
Can you help with the commands to use so that all the stuff is save on my EXT4 drive. I am not using BTRFS (since I know MAC / windows - cant read the files. I want to use EXT4 in case my pi goes down or it breaks.
When i go to media.
/media/USBdrive
i dont see any of the cotent,
I want to be able to see my drive contents within nextcloud and also as a shared place.
Any help is appreciated, more specifically with commands, I dont know the commands.
thank you
Below is my configuation.
| NextCloudPi version | v1.49.0 |
| NextCloudPi image | NextCloudPi_08-16-22 |
| OS | Debian GNU/Linux 11. 5.10.92-v8+ (aarch64) |
| automount | yes |
| USB devices | sda |
| datadir | /media/USBdrive/ncdata/data |
| data in SD | yes |
| data filesystem | ext2/ext3 |
| data disk usage | 2.7G/30G |
| rootfs usage | 2.7G/30G |
| swapfile | /var/swap |
| dbdir | /var/lib/mysql |
| Nextcloud check | ok |
| Nextcloud version | 24.0.3.2 |
| HTTPD service | up |
| PHP service | up |
| MariaDB service | up |
| Redis service | up |
| HPB service | up |
| Postfix service | up |
| internet check | ok |
| port check 80 | open |
| port check 443 | open |
