nextcloudaio (apache) does not listen to port 11000
    • Nextcloud AIO v11.4.0
    • Debian GNU/Linux 12 (bookworm) (raspberrypi)
    • Apache/2.4.63
    • caddy v2.10.0
    • PHP 8.4.10
    • Yes
    • When I use Caddy as reverse-proxy running at a different server
    • AIO
Installation of nextcloudaio on server 1 was successfull.
After starting Caddy on server 2 nextcloudaio couldn’t be connected via port 11000.
AIO Interface (port 8080) works fine.
  1. Nextcloudaio installation with docker was successfull. After opening the ports 80 and 443 in the router nextcloud clients could connect to nextcloud using mydomain.ddns.net
  2. Installation of caddy (docker) on server 2 (ports in router configuration were updated)
  3. New start of nextcloudaio was successfull (all containers are running), but clients cannot reach it.
  4. Test on server 2 (with caddy) to connect to AIO server:
curl -vvv http://192.168.0.93:11000
*   Trying 192.168.0.93:11000...
* connect to 192.168.0.93 port 11000 failed: Verbindungsaufbau abgelehnt
* Failed to connect to 192.168.0.93 port 11000 after 44 ms: Couldn't connect to server
* Closing connection 0
curl: (7) Failed to connect to 192.168.0.93 port 11000 after 44 ms: Couldn't connect to server
  1. docker list (no port 11000)
b68c04f258ad   ghcr.io/nextcloud-releases/aio-apache:latest        "/start.sh /usr/bin/…"   3 hours ago   Up 3 hours (healthy)   80/tcp, 0.0.0.0:443->443/tcp, 0.0.0.0:443->443/udp, [::]:443->443/tcp, [::]:443->443/udp                                                  nextcloud-aio-apache
8ac98bf09cb9   ghcr.io/nextcloud-releases/aio-whiteboard:latest    "/start.sh"              3 hours ago   Up 3 hours (healthy)   3002/tcp        nextcloud-aio-whiteboard
d019338c72cd   ghcr.io/nextcloud-releases/aio-notify-push:latest   "/start.sh"              3 hours ago   Up 3 hours (healthy)        nextcloud-aio-notify-push
4a074ae2a8c5   ghcr.io/nextcloud-releases/aio-nextcloud:latest     "/start.sh /usr/bin/…"   3 hours ago   Up 3 hours (healthy)   9000/tcp        nextcloud-aio-nextcloud
449430fbe9d1   ghcr.io/nextcloud-releases/aio-imaginary:latest     "/start.sh"              3 hours ago   Up 3 hours (healthy)        nextcloud-aio-imaginary
1c026c2f919e   ghcr.io/nextcloud-releases/aio-redis:latest         "/start.sh"              3 hours ago   Up 3 hours (healthy)   6379/tcp        nextcloud-aio-redis
485eb44df6d6   ghcr.io/nextcloud-releases/aio-postgresql:latest    "/start.sh"              3 hours ago   Up 3 hours (healthy)   5432/tcp        nextcloud-aio-database
b2fff0e72cda   ghcr.io/nextcloud-releases/all-in-one:latest        "/start.sh"              9 days ago    Up 9 days (healthy)    0.0.0.0:80->80/tcp, [::]:80->80/tcp, 0.0.0.0:8080->8080/tcp, [::]:8080->8080/tcp, 0.0.0.0:8443->8443/tcp, [::]:8443->8443/tcp, 9000/tcp   nextcloud-aio-mastercontainer
docker logs nextcloud-aio-mastercontainer
Trying to fix docker.sock permissions internally...
Creating docker group internally with id 991
Initial startup of Nextcloud All-in-One complete!
You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
E.g. https://internal.ip.of.this.server:8080
⚠️ Important: do always use an ip-address if you access this port and not a domain as HSTS might block access to it later!
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443
[Thu Jul 17 11:33:37.707572 2025] [mpm_event:notice] [pid 145:tid 145] AH00489: Apache/2.4.62 (Unix) OpenSSL/3.3.4 configured -- resuming normal operations
[Thu Jul 17 11:33:37.707715 2025] [core:notice] [pid 145:tid 145] AH00094: Command line: 'httpd -D FOREGROUND'
[17-Jul-2025 11:33:37] NOTICE: fpm is running, pid 150
[17-Jul-2025 11:33:37] NOTICE: ready to handle connections
{"level":"info","ts":1752752017.7728226,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1752752017.7736895,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":3583704268,"previous":9223372036854775807}
{"level":"info","ts":1752752017.7738748,"msg":"using config from file","file":"/Caddyfile"}
{"level":"info","ts":1752752017.7809124,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1752752017.8081563,"msg":"serving initial configuration"}
Total reclaimed space: 0B
Deleting duplicate sessions
NOTICE: PHP message: 404 Not Found
Type: Slim\Exception\HttpNotFoundException
Code: 404
Message: Not found.
File: /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php
Line: 76
Trace: #0 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(62): Slim\Middleware\RoutingMiddleware->performRouting(Object(GuzzleHttp\Psr7\ServerRequest))
#1 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#2 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(177): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
#3 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#4 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#5 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(36): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#6 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(280): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#8 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#9 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#10 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#11 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#12 /var/www/docker-aio/php/public/index.php(196): Slim\App->run()
#13 {main}
Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
and for Apache:
docker logs nextcloud-aio-apache
Waiting for Nextcloud to start...
Connection to nextcloud-aio-nextcloud (172.18.0.6) 9000 port [tcp/*] succeeded!
[Sat Jul 26 10:16:13.986517 2025] [mpm_event:notice] [pid 61:tid 61] AH00489: Apache/2.4.63 (Unix) configured -- resuming normal operations
[Sat Jul 26 10:16:13.986764 2025] [core:notice] [pid 61:tid 61] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
{"level":"info","ts":1753524974.1501505,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1753524974.151454,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":3583704268,"previous":9223372036854775807}
{"level":"info","ts":1753524974.1516895,"msg":"using config from file","file":"/tmp/Caddyfile"}
{"level":"info","ts":1753524974.1588385,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1753524974.276673,"msg":"serving initial configuration"}
PASTE
The output of caddy
[+] Running 1/1
 ✔ Container caddy-caddy-1  Created        0.1s
Attaching to caddy-1
caddy-1  | {"level":"info","ts":1753456389.5231357,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
caddy-1  | {"level":"info","ts":1753456389.5237172,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":3583704268,"previous":9223372036854775807}
caddy-1  | {"level":"info","ts":1753456389.523903,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
caddy-1  | {"level":"info","ts":1753456389.5268323,"msg":"adapted config to JSON","adapter":"caddyfile"}
caddy-1  | {"level":"info","ts":1753456389.530692,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
caddy-1  | {"level":"info","ts":1753456389.5312476,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy-1  | {"level":"info","ts":1753456389.5313275,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv1","https_port":443}
caddy-1  | {"level":"info","ts":1753456389.5313528,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv1"}
caddy-1  | {"level":"debug","ts":1753456389.5314608,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{}]}},"http":{"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{},{}]},"srv0":{"listen":[":1880"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"192.168.0.14:1880"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}},"srv1":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"192.168.0.93:11000"}]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
caddy-1  | {"level":"info","ts":1753456389.5350697,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x400060c380"}
caddy-1  | {"level":"debug","ts":1753456389.5459056,"logger":"http","msg":"starting server loop","address":"[::]:1880","tls":true,"http3":false}
caddy-1  | {"level":"info","ts":1753456389.5459957,"logger":"http","msg":"enabling HTTP/3 listener","addr":":1880"}
caddy-1  | {"level":"info","ts":1753456389.5477989,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
caddy-1  | {"level":"debug","ts":1753456389.5620995,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":false}
caddy-1  | {"level":"info","ts":1753456389.5621684,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
caddy-1  | {"level":"info","ts":1753456389.5630224,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
caddy-1  | {"level":"debug","ts":1753456389.5744505,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
caddy-1  | {"level":"warn","ts":1753456389.5745242,"logger":"http","msg":"HTTP/2 skipped because it requires TLS","network":"tcp","addr":":80"}
caddy-1  | {"level":"warn","ts":1753456389.574535,"logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
caddy-1  | {"level":"info","ts":1753456389.5745435,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
caddy-1  | {"level":"info","ts":1753456389.574558,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["mydomain.ddns.net"]}
caddy-1  | {"level":"warn","ts":1753456389.5763597,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [mydomain.ddns.net]: no OCSP server specified in certificate","identifiers":["mydomain.ddns.net"]}
caddy-1  | {"level":"debug","ts":1753456389.5766845,"logger":"tls.cache","msg":"added certificate to cache","subjects":["mydomain.ddns.net"],"expiration":1761206189,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"213ad28d29977852438b5c0bd92554da4f0f7822bc1dad1ff9deb983d3b5d64f","cache_size":1,"cache_capacity":10000}
caddy-1  | {"level":"debug","ts":1753456389.576764,"logger":"events","msg":"event","name":"cached_managed_cert","id":"7fabba8e-395d-4dca-b3c2-02a6f7b0939e","origin":"tls","data":{"sans":["mydomain.ddns.net"]}}
caddy-1  | {"level":"debug","ts":1753456389.5769715,"logger":"events","msg":"event","name":"started","id":"7c73ad3c-e55a-46f0-9c27-42157eb8e621","origin":"","data":null}
caddy-1  | {"level":"info","ts":1753456389.5782452,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy-1  | {"level":"info","ts":1753456389.5784826,"msg":"serving initial configuration"}
caddy-1  | {"level":"info","ts":1753456389.5842605,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"02250a9c-3d83-4b7b-9a82-6438972013bf","try_again":1753542789.5842545,"try_again_in":86399.999997703}
caddy-1  | {"level":"info","ts":1753456389.5845222,"logger":"tls","msg":"finished cleaning storage units"}
caddy-1  | {"level":"debug","ts":1753456390.333207,"logger":"events","msg":"event","name":"tls_get_certificate","id":"4868632b-a947-4285-b683-698cf90393b9","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,49196,49200,159,52393,52392,52394,49195,49199,158,49188,49192,107,49187,49191,103,49162,49172,57,49161,49171,51,173,171,52398,52397,52396,157,169,52395,172,170,156,168,61,60,49208,49206,183,179,149,145,53,175,141,49207,49205,182,178,148,144,47,174,140],"ServerName":"mydomain.ddns.net","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2074,2075,2076,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769,770,1026,1282,1538],"SupportedProtos":null,"SupportedVersions":[772,771],"RemoteAddr":{"IP":"82.212.15.135","Port":53140,"Zone":""},"LocalAddr":{"IP":"172.23.0.2","Port":443,"Zone":""}}}}
caddy-1  | {"level":"debug","ts":1753456390.333464,"logger":"tls.handshake","msg":"choosing certificate","identifier":"mydomain.ddns.net","num_choices":1}
caddy-1  | {"level":"debug","ts":1753456390.3334796,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"mydomain.ddns.net","subjects":["mydomain.ddns.net"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"213ad28d29977852438b5c0bd92554da4f0f7822bc1dad1ff9deb983d3b5d64f"}
caddy-1  | {"level":"debug","ts":1753456390.3334992,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"82.212.15.135","remote_port":"53140","subjects":["mydomain.ddns.net"],"managed":true,"expiration":1761206189,"hash":"213ad28d29977852438b5c0bd92554da4f0f7822bc1dad1ff9deb983d3b5d64f"}
caddy-1  | {"level":"debug","ts":1753456390.3972504,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.0.93:11000","total_upstreams":1}
caddy-1  | {"level":"debug","ts":1753456390.4519954,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.0.93:11000","duration":0.05457977,"request":{"remote_ip":"82.212.15.135","remote_port":"53140","client_ip":"82.212.15.135","proto":"HTTP/1.1","method":"GET","host":"mydomain.ddns.net","uri":"/index.php/204","headers":{"X-Forwarded-For":["82.212.15.135"],"Accept-Encoding":["zstd, gzip, deflate"],"Accept-Language":["de-DE,en,*"],"Accept":["*/*"],"X-Forwarded-Host":["mydomain.ddns.net"],"Via":["1.1 Caddy"],"X-Request-Id":["ed85486f-3095-4e08-8bc7-1714788ffc8e"],"User-Agent":["Mozilla/5.0 (Linux) mirall/3.16.6 (build 31593) (Nextcloud, linuxmint-6.8.0-64-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"","server_name":"mydomain.ddns.net"}},"error":"dial tcp 192.168.0.93:11000: connect: connection refused"}
caddy-1  | {"level":"error","ts":1753456390.4521844,"logger":"http.log.error","msg":"dial tcp 192.168.0.93:11000: connect: connection refused","request":{"remote_ip":"82.212.15.135","remote_port":"53140","client_ip":"82.212.15.135","proto":"HTTP/1.1","method":"GET","host":"mydomain.ddns.net","uri":"/index.php/204","headers":{"Accept-Encoding":["zstd, gzip, deflate"],"Accept-Language":["de-DE,en,*"],"User-Agent":["Mozilla/5.0 (Linux) mirall/3.16.6 (build 31593) (Nextcloud, linuxmint-6.8.0-64-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)"],"Accept":["*/*"],"X-Request-Id":["ed85486f-3095-4e08-8bc7-1714788ffc8e"],"Connection":["Keep-Alive"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"","server_name":"mydomain.ddns.net"}},"duration":0.054950284,"status":502,"err_id":"p42wvje1q","err_trace":"reverseproxy.statusError (reverseproxy.go:1390)"}
caddy-1  | {"level":"debug","ts":1753456396.0087905,"logger":"events","msg":"event","name":"tls_get_certificate","id":"1f703030-8e77-4060-9831-8b848d602a87","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,4868,49196,52393,49325,49162,49195,49324,49161,49200,52392,49172,49199,49171,157,49309,53,156,49308,47,159,52394,49311,57,158,49310,51],"ServerName":"mydomain.ddns.net","SupportedCurves":[23,24,25,29,30,256,257,258,259,260],"SupportedPoints":"AA==","SignatureSchemes":[1025,2057,2052,1027,2055,1281,2058,2053,1283,2056,1537,2059,2054,1539,513,515],"SupportedProtos":["h2","http/1.1","http/1.0"],"SupportedVersions":[772,771,770,769],"RemoteAddr":{"IP":"82.212.15.135","Port":53146,"Zone":""},"LocalAddr":{"IP":"172.23.0.2","Port":443,"Zone":""}}}}
caddy-1  | {"level":"debug","ts":1753456396.0090222,"logger":"tls.handshake","msg":"choosing certificate","identifier":"mydomain.ddns.net","num_choices":1}
caddy-1  | {"level":"debug","ts":1753456396.0090728,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"mydomain.ddns.net","subjects":["mydomain.ddns.net"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"213ad28d29977852438b5c0bd92554da4f0f7822bc1dad1ff9deb983d3b5d64f"}
caddy-1  | {"level":"debug","ts":1753456396.0091124,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"82.212.15.135","remote_port":"53146","subjects":["mydomain.ddns.net"],"managed":true,"expiration":1761206189,"hash":"213ad28d29977852438b5c0bd92554da4f0f7822bc1dad1ff9deb983d3b5d64f"}
caddy-1  | {"level":"debug","ts":1753456396.0408027,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.0.93:11000","total_upstreams":1}
caddy-1  | {"level":"debug","ts":1753456396.0559578,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.0.93:11000","duration":0.014777333,"request":{"remote_ip":"82.212.15.135","remote_port":"53146","client_ip":"82.212.15.135","proto":"HTTP/2.0","method":"REPORT","host":"mydomain.ddns.net","uri":"/remote.php/dav/calendars/andi/testaio/","headers":{"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["de-de, de;q=0.9"],"Depth":["1"],"User-Agent":["Evolution/3.56.2"],"Cache-Control":["no-cache"],"Pragma":["no-cache"],"X-Forwarded-For":["82.212.15.135"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["mydomain.ddns.net"],"Via":["2.0 Caddy"],"Content-Type":["application/xml; charset=\"utf-8\""],"Content-Length":["318"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"h2","server_name":"mydomain.ddns.net"}},"error":"dial tcp 192.168.0.93:11000: connect: connection refused"}
caddy-1  | {"level":"error","ts":1753456396.0565417,"logger":"http.log.error","msg":"dial tcp 192.168.0.93:11000: connect: connection refused","request":{"remote_ip":"82.212.15.135","remote_port":"53146","client_ip":"82.212.15.135","proto":"HTTP/2.0","method":"REPORT","host":"mydomain.ddns.net","uri":"/remote.php/dav/calendars/andi/testaio/","headers":{"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["de-de, de;q=0.9"],"Depth":["1"],"User-Agent":["Evolution/3.56.2"],"Cache-Control":["no-cache"],"Pragma":["no-cache"],"Content-Type":["application/xml; charset=\"utf-8\""],"Content-Length":["318"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"h2","server_name":"mydomain.ddns.net"}},"duration":0.015549732,"status":502,"err_id":"cgrafpg0g","err_trace":"reverseproxy.statusError (reverseproxy.go:1390)"}
caddy-1  | {"level":"debug","ts":1753456452.387643,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.0.93:11000","total_upstreams":1}
caddy-1  | {"level":"debug","ts":1753456452.397915,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.0.93:11000","duration":0.010132355,"request":{"remote_ip":"82.212.15.135","remote_port":"53140","client_ip":"82.212.15.135","proto":"HTTP/1.1","method":"GET","host":"mydomain.ddns.net","uri":"/index.php/204","headers":{"User-Agent":["Mozilla/5.0 (Linux) mirall/3.16.6 (build 31593) (Nextcloud, linuxmint-6.8.0-64-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)"],"Accept":["*/*"],"X-Request-Id":["fa6ade79-b46d-4e9a-bb80-d83f6c7fd687"],"X-Forwarded-For":["82.212.15.135"],"Accept-Encoding":["zstd, gzip, deflate"],"Accept-Language":["de-DE,en,*"],"X-Forwarded-Host":["mydomain.ddns.net"],"Via":["1.1 Caddy"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"","server_name":"mydomain.ddns.net"}},"error":"dial tcp 192.168.0.93:11000: connect: connection refused"}
caddy-1  | {"level":"error","ts":1753456452.398081,"logger":"http.log.error","msg":"dial tcp 192.168.0.93:11000: connect: connection refused","request":{"remote_ip":"82.212.15.135","remote_port":"53140","client_ip":"82.212.15.135","proto":"HTTP/1.1","method":"GET","host":"mydomain.ddns.net","uri":"/index.php/204","headers":{"User-Agent":["Mozilla/5.0 (Linux) mirall/3.16.6 (build 31593) (Nextcloud, linuxmint-6.8.0-64-generic ClientArchitecture: x86_64 OsArchitecture: x86_64)"],"Accept":["*/*"],"X-Request-Id":["fa6ade79-b46d-4e9a-bb80-d83f6c7fd687"],"Connection":["Keep-Alive"],"Accept-Encoding":["zstd, gzip, deflate"],"Accept-Language":["de-DE,en,*"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"","server_name":"mydomain.ddns.net"}},"duration":0.010465536,"status":502,"err_id":"mmsmy58e3","err_trace":"reverseproxy.statusError (reverseproxy.go:1390)"}
running on server 1 (192.168.0.93)
  1. docker-compose.yml (without reverse-proxy):
services:
    image: ghcr.io/nextcloud-releases/all-in-one:latest
    init: true
    restart: always
    volumes:
    network_mode: bridge # add to the same network as docker run would do
    ports:
      - 80:80 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      - 8080:8080
      - 8443:8443 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
    environment:
      NEXTCLOUD_DATADIR: /media/docker/nextcloud/data_dir
      SKIP_DOMAIN_VALIDATION: true
volumes: # If you want to store the data on a different drive, see https://github.com/nextcloud/all-in-one#how-to-store-the-filesinstallation-on-a-separate-drive
  1. docker-compose.yml (with reverse-proxy:
services:
    init: true
    restart: always
    volumes:
    # network_mode: bridge # add to the same network as docker run would do
    network_mode: host
    ports:
    # - 80:80 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      - 8080:8080
      - 11000:11000
    # - 8443:8443 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
    environment:
      - NEXTCLOUD_DATADIR: /media/docker/nextcloud/data_dir
      - SKIP_DOMAIN_VALIDATION: true
      - APACHE_PORT: 11000
      - APACHE_IP_BINDING: 0.0.0.0
      #APACHE_ADDITIONAL_NETWORK: ""
  1. php configuration
sudo docker exec --user www-data -it nextcloud-aio-nextcloud php /var/www/html/occ config:list system
        "one-click-instance": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "overwritehost": "mydomain.ddns.net",
        "overwriteprotocol": "https",
            "localhost",
            "192.168.0.14"
        "dbtype": "pgsql",
        "version": "31.0.7.1",
        "overwrite.cli.url": "https:\/\/mydomain.ddns.net\/",
        "dbport": "",
        "updatechecker": false,
        "loglevel": 2,
        "log_type": "file",
        "log_rotate_size": 10485760,
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
            "7": "OC\\Preview\\Krita",
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": 30,
        "share_folder": "\/Shared",
        "htaccess.RewriteBase": "\/",
        "dbpersistent": false,
        "DOMAIN": "mydomain.ddns.net"
Caddy configuration running on server 2 (192.168.0.14)
  1. docker-compose.yml for caddy
services:
  caddy:
    image: caddy:latest
    restart: unless-stopped
    ports:
      - "80:80"
      - "443:443"
      - "443:443/udp"
    volumes:
      - ./conf:/etc/caddy
      - ./certs:/certs
      - ./site:/srv
      - caddy_data:/data
      - caddy_config:/config
volumes:
  caddy_data:
  caddy_config:
  1. caddy config file: conf/Caddyfile
	debug
mydomain.ddns.net:1880 {
	reverse_proxy 192.168.0.14:1880
mydomain.ddns.net:443 {
	reverse_proxy 192.168.0.93:11000
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "writable": true
        "redis": {
            "port": 6379
            "localhost",
            "192.168.0.14"
        "dbtype": "pgsql",
        "dbport": "",
        "loglevel": 2,
        "log_type": "file",
        "log.condition": {
            "apps": [
                "admin_audit"
        "jpeg_quality": 60,
    "apps": {
        "activity": {
            "installed_version": "4.0.0",
            "types": "filesystem",
            "enabled": "yes"
        "admin_audit": {
            "installed_version": "1.21.0",
            "types": "logging",
            "enabled": "yes",
            "logfile": "\/var\/www\/html\/data\/audit.log"
        "app_api": {
            "default_daemon_config": "docker_aio",
            "installed_version": "5.0.2",
            "types": "",
            "enabled": "no"
        "backgroundjob": {
            "lastjob": "10"
        "bruteforcesettings": {
            "types": "",
            "enabled": "yes"
        "calendar": {
            "types": "",
            "enabled": "yes",
            "installed_version": "5.3.6"
        "circles": {
            "installed_version": "31.0.0",
            "types": "filesystem,dav",
            "enabled": "yes",
            "loopback_tmp_scheme": "https",
            "migration_22": "1",
            "loopback_tmp_path": "\/",
            "migration_run": "0",
            "maintenance_run": "0",
            "maintenance_update": "{\"3\":1753534570,\"2\":1753535470,\"1\":1753535470}"
        "cloud_federation_api": {
            "installed_version": "1.14.0",
            "enabled": "yes"
        "comments": {
            "types": "logging",
            "enabled": "yes"
        "contacts": {
            "enabled": "yes",
            "types": "dav",
            "installed_version": "7.2.0"
        "contactsinteraction": {
            "installed_version": "1.12.0",
            "types": "dav",
            "enabled": "yes"
        "core": {
            "installedat": "1751989030.8281",
            "vendor": "nextcloud",
            "public_files": "files_sharing\/public.php",
            "lastupdatedat": 0,
            "metadataGenerationDone": true,
            "moveavatarsdone": "yes",
            "previewsCleanedUp": "1",
            "backgroundjobs_mode": "cron",
            "lastcron": 1753535470,
            "files_metadata": {
                "photos-original_date_time": {
                    "value": null,
                    "type": "int",
                    "etag": "",
                    "indexed": true,
                    "editPermission": 0
                "photos-size": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-exif": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "photos-ifd0": {
                    "value": null,
                    "type": "array",
                    "etag": "",
                    "indexed": false,
                    "editPermission": 0
                "blurhash": {
                    "value": null,
                    "type": "string",
                    "etag": "5de42567f612ed520c0d82f53f86b117",
                    "indexed": false,
                    "editPermission": 0
            "oc.integritycheck.checker": []
        "dashboard": {
            "installed_version": "7.11.0",
            "types": "",
            "enabled": "yes"
        "dav": {
            "installed_version": "1.33.0",
            "enabled": "yes",
            "regeneratedBirthdayCalendarsForYearFix": "yes",
            "buildCalendarSearchIndex": "yes",
            "buildCalendarReminderIndex": "yes",
            "builtSocialSearchIndex": "yes"
        "deck": {
            "installed_version": "1.15.1",
            "types": "dav",
            "enabled": "yes"
        "federatedfilesharing": {
            "types": "",
            "enabled": "yes"
        "federation": {
            "types": "authentication",
            "enabled": "yes"
        "files": {
            "installed_version": "2.3.1",
            "enabled": "yes",
            "mimetype_version": "31.0.7.1"
        "files_downloadlimit": {
            "types": "",
            "enabled": "yes"
        "files_pdfviewer": {
            "types": "",
            "enabled": "yes"
        "files_reminders": {
            "installed_version": "1.4.0",
            "types": "",
            "enabled": "yes"
        "files_sharing": {
            "installed_version": "1.23.1",
            "enabled": "yes"
        "files_trashbin": {
            "enabled": "yes",
            "background_job_expire_trash_offset": 0
        "files_versions": {
            "installed_version": "1.24.0",
            "enabled": "yes"
        "firstrunwizard": {
            "types": "",
            "enabled": "yes"
        "logreader": {
            "types": "logging",
            "enabled": "yes"
        "lookup_server_connector": {
            "installed_version": "1.19.0",
            "enabled": "yes"
        "nextcloud-aio": {
            "installed_version": "0.8.0",
            "types": "",
            "enabled": "yes"
        "nextcloud_announcements": {
            "installed_version": "3.0.0",
            "types": "logging",
            "enabled": "yes",
            "pub_date": "Thu, 24 Oct 2019 00:00:00 +0200"
        "notes": {
            "enabled": "yes",
            "types": "",
            "installed_version": "4.12.2"
        "notifications": {
            "types": "logging",
            "enabled": "yes"
        "notify_push": {
            "installed_version": "1.1.0",
            "base_endpoint": "https:\/\/mydomain.ddns.net\/push",
            "enabled": "yes"
        "oauth2": {
            "installed_version": "1.19.1",
            "enabled": "yes"
        "password_policy": {
            "enabled": "yes"
        "photos": {
            "types": "dav,authentication",
            "enabled": "yes",
            "lastPlaceMappedUser": "admin",
            "lastPlaceMappingDone": "true"
        "preview": {
            "jpeg_quality": "60"
        "privacy": {
            "types": "",
            "enabled": "yes"
        "profile": {
            "installed_version": "1.0.0",
            "types": "",
            "enabled": "yes"
        "provisioning_api": {
            "types": "prevent_group_restriction",
            "enabled": "yes"
        "recommendations": {
            "types": "",
            "enabled": "yes"
        "related_resources": {
            "installed_version": "2.0.0",
            "types": "",
            "enabled": "yes"
        "serverinfo": {
            "types": "",
            "enabled": "yes",
            "cached_count_appdata_files": 3120,
            "size_appdata_storage": -1,
            "cached_count_storages": 6,
            "cached_count_filecache": 3818
        "settings": {
            "types": "",
            "enabled": "yes"
        "sharebymail": {
            "enabled": "yes"
        "support": {
            "types": "session",
            "enabled": "yes",
            "SwitchUpdaterServerHasRun": "yes"
        "survey_client": {
            "types": "",
            "enabled": "yes"
        "systemtags": {
            "installed_version": "1.21.1",
            "types": "logging",
            "enabled": "yes"
        "tasks": {
            "installed_version": "0.16.1",
            "types": "",
            "enabled": "yes"
        "text": {
            "installed_version": "5.0.0",
            "types": "dav",
            "enabled": "yes"
        "theming": {
            "installed_version": "2.6.1",
            "types": "logging",
            "enabled": "yes"
        "twofactor_backupcodes": {
            "installed_version": "1.20.0",
            "types": "",
            "enabled": "yes"
        "twofactor_totp": {
            "installed_version": "13.0.0-dev.0",
            "types": "",
            "enabled": "yes"
        "updatenotification": {
            "types": "",
            "enabled": "yes",
            "notify_groups": "[]",
            "calendar": "5.3.7",
            "contacts": "7.2.2",
            "notes": "4.12.2"
        "user_status": {
            "installed_version": "1.11.0",
            "types": "",
            "enabled": "yes"
        "viewer": {
            "types": "",
            "enabled": "yes"
        "weather_status": {
            "types": "",
            "enabled": "yes"
        "webhook_listeners": {
            "installed_version": "1.2.0",
            "enabled": "yes"
        "whiteboard": {
            "installed_version": "1.1.2",
            "types": "",
            "collabBackendUrl": "https:\/\/mydomain.ddns.net\/whiteboard",
            "jwt_secret_key": "***REMOVED SENSITIVE VALUE***",
            "enabled": "yes"
        "workflowengine": {
            "installed_version": "2.13.0",
            "enabled": "yes"
I found caddy files in the apache container:
docker exec -it nextcloud-aio-apache cat /tmp/Caddyfile
	auto_https disable_redirects
	storage file_system {
		root /mnt/data/caddy
	servers {
		trusted_proxies static 172.18.0.0/16
	log {
		level ERROR
{$PROTOCOL}://{$NC_DOMAIN}:{$APACHE_PORT} {
	header -Server
	header -X-Powered-By
	# Collabora
	route /browser/* {
		reverse_proxy {$COLLABORA_HOST}:9980
	route /hosting/* {
	route /cool/* {
	# Notify Push
	route /push/* {
		uri strip_prefix /push
		reverse_proxy {$NOTIFY_PUSH_HOST}:7867
	# Onlyoffice
	route /onlyoffice/* {
		uri strip_prefix /onlyoffice
		reverse_proxy {$ONLYOFFICE_HOST}:80 {
			header_up X-Forwarded-Host {http.request.hostport}/onlyoffice
			header_up X-Forwarded-Proto https
	# Talk
	route /standalone-signaling/* {
		uri strip_prefix /standalone-signaling
		reverse_proxy {$TALK_HOST}:8081
	# Whiteboard
	route /whiteboard/* {
		uri strip_prefix /whiteboard
		reverse_proxy {$WHITEBOARD_HOST}:3002
	# Nextcloud
	route {
		header Strict-Transport-Security max-age=31536000;
		reverse_proxy 127.0.0.1:8000
	redir /.well-known/carddav /remote.php/dav/ 301
	redir /.well-known/caldav /remote.php/dav/ 301
	# TLS options
	tls {
		issuer acme {
			disable_http_challenge
and
docker exec -it nextcloud-aio-apache ls -al /mnt/data/caddy
total 24
drwxr-xr-x    5 www-data www-data      4096 Jul 26 10:16 .
drwxr-xr-x    3 www-data www-data      4096 Jul  8 15:43 ..
drwx------    3 www-data www-data      4096 Jul  8 15:43 acme
drwx------    3 www-data www-data      4096 Jul  8 15:43 certificates
-rw-------    1 www-data www-data       106 Jul 26 10:16 last_clean.json
drwx------    2 www-data www-data      4096 Jul 26 10:16 locks
Why are this files available and how are it used?
Hello @afi4711,
welcome to the Nextcloud community! :handshake:
please don’t mess with the AiO containers - the system is not designed for direct interaction. It has caddy built-in for straight installation without reverseproxy. Please review the AiO reverse proxy docs for examples.
Thank you for the hint. I have read all documents.
Main problem is that the AIO containers does not listen to port 11000:
curl -vvv 192.168.0.93:11000
* Failed to connect to 192.168.0.93 port 11000 after 32 ms: Couldn't connect to server
curl: (7) Failed to connect to 192.168.0.93 port 11000 after 32 ms: Couldn't connect to server
Although APACHE_PORT is set to 11000 in docker-compose.yaml, the env in the apache container (nextcloud-aio-apache):
 environment:
      - NEXTCLOUD_DATADIR: /media/andi/Backup-T7/docker/nextcloud/data_dir
      - APACHE_PORT=11000
      - APACHE_IP_BINDING=0.0.0.0
docker exec -it nextcloud-aio-apache env | grep -i apa
PATH=/usr/local/apache2/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
HOSTNAME=nextcloud-aio-apache
APACHE_HOST=nextcloud-aio-apache
APACHE_PORT=443
APACHE_MAX_SIZE=17179869184
APACHE_MAX_TIME=3600
HTTPD_PREFIX=/usr/local/apache2
Hi, can you open the aio interface and stop and start the containers again? Only then are changes applied to the sibling containers.
Of course i restarted all containers with the aio interface. For testing, I define some own variables, but nothing could be seen in both container (mastercontainer or apache)?
For example, this environment
   environment:
      - MY_VAR1: 11
      - MY_VAR2: 12
      - MY_VAR3: 13
in the docker-compose.yml file shows these results:
TERM=xterm
NC_DOMAIN=afiraspi.ddns.net
NEXTCLOUD_HOST=nextcloud-aio-nextcloud
COLLABORA_HOST=nextcloud-aio-collabora
TALK_HOST=nextcloud-aio-talk
APACHE_PORT=443
ONLYOFFICE_HOST=nextcloud-aio-onlyoffice
TZ=Etc/UTC
NOTIFY_PUSH_HOST=nextcloud-aio-notify-push
WHITEBOARD_HOST=nextcloud-aio-whiteboard
HTTPD_VERSION=2.4.63
HTTPD_SHA256=88fc236ab99b2864b248de7d49a008ec2afd7551e64dce8b95f58f32f94c46ab
HTTPD_PATCHES=
HOME=/home/www-data
docker exec -it nextcloud-aio-mastercontainer env
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
HOSTNAME=de9086c70509
TERM=xterm
SKIP_DOMAIN_VALIDATION=true
NEXTCLOUD_DATADIR=/media/andi/Backup-T7/docker/nextcloud/data_dir
PHPIZE_DEPS=autoconf 		dpkg-dev dpkg 		file 		g++ 		gcc 		libc-dev 		make 		pkgconf 		re2c
PHP_INI_DIR=/usr/local/etc/php
PHP_CFLAGS=-fstack-protector-strong -fpic -fpie -O2 -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
PHP_CPPFLAGS=-fstack-protector-strong -fpic -fpie -O2 -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
PHP_LDFLAGS=-Wl,-O1 -pie
GPG_KEYS=AFD8691FDAEDF03BDF6E460563F15A9B715376CA 9D7F99A0CB8F05C8A6958D6256A97AF7600A39A6 0616E93D95AF471243E26761770426E17EBBB3DD
PHP_VERSION=8.4.10
PHP_URL=https://www.php.net/distributions/php-8.4.10.tar.xz
PHP_ASC_URL=https://www.php.net/distributions/php-8.4.10.tar.xz.asc
PHP_SHA256=14983a9ef8800e6bc2d920739fd386054402f7976ca9cd7f711509496f0d2632
HOME=/root
It is very strange, isn’t it?
Indeed it is strange. Is something logged in the mastercontainer logs after you restarted the containers via the aio interface? Also, can you post the output of sudo docker inspect nextcloud-aio-mastercontainer here?
Perhaps I have to remove the containers and restart again? In the mastercontainer logs there is nothing logged after restart, here the inspect output:
        "Id": "b2fff0e72cdacacd2bd0d88a3be77acf29a97caf15d0aea01e482eecd309eb89",
        "Created": "2025-07-17T11:33:34.006743138Z",
        "Path": "/start.sh",
        "Args": [],
        "State": {
            "Status": "running",
            "Running": true,
            "Paused": false,
            "Restarting": false,
            "OOMKilled": false,
            "Dead": false,
            "Pid": 1915784,
            "ExitCode": 0,
            "Error": "",
            "StartedAt": "2025-07-26T13:32:45.040897681Z",
            "FinishedAt": "2025-07-26T13:32:35.282910877Z",
            "Health": {
                "Status": "healthy",
                "FailingStreak": 0,
                "Log": [
                        "Start": "2025-07-27T20:50:13.865332462+02:00",
                        "End": "2025-07-27T20:50:13.993012841+02:00",
                        "ExitCode": 0,
                        "Output": "Connection to 127.0.0.1 80 port [tcp/http] succeeded!\nConnection to 127.0.0.1 8000 port [tcp/*] succeeded!\nConnection to 127.0.0.1 8080 port [tcp/http-alt] succeeded!\nConnection to 127.0.0.1 8443 port [tcp/*] succeeded!\nConnection to 127.0.0.1 9000 port [tcp/*] succeeded!\nConnection to 127.0.0.1 9876 port [tcp/*] succeeded!\n"
                        "Start": "2025-07-27T20:50:43.99647499+02:00",
                        "End": "2025-07-27T20:50:44.176164748+02:00",
                        "ExitCode": 0,
                        "Start": "2025-07-27T20:51:14.179402334+02:00",
                        "End": "2025-07-27T20:51:14.354220764+02:00",
                        "ExitCode": 0,
                        "Start": "2025-07-27T20:51:44.356652865+02:00",
                        "End": "2025-07-27T20:51:44.529085339+02:00",
                        "ExitCode": 0,
                        "Start": "2025-07-27T20:52:14.531216633+02:00",
                        "End": "2025-07-27T20:52:14.663460538+02:00",
                        "ExitCode": 0,
        "Image": "sha256:505d629c97f41d3c9f9e1e08174b9166ea50bdb75105e66785c7de9ce386118b",
        "ResolvConfPath": "/media/andi/Backup-T7/var_docker/containers/b2fff0e72cdacacd2bd0d88a3be77acf29a97caf15d0aea01e482eecd309eb89/resolv.conf",
        "HostnamePath": "/media/andi/Backup-T7/var_docker/containers/b2fff0e72cdacacd2bd0d88a3be77acf29a97caf15d0aea01e482eecd309eb89/hostname",
        "HostsPath": "/media/andi/Backup-T7/var_docker/containers/b2fff0e72cdacacd2bd0d88a3be77acf29a97caf15d0aea01e482eecd309eb89/hosts",
        "LogPath": "/media/andi/Backup-T7/var_docker/containers/b2fff0e72cdacacd2bd0d88a3be77acf29a97caf15d0aea01e482eecd309eb89/b2fff0e72cdacacd2bd0d88a3be77acf29a97caf15d0aea01e482eecd309eb89-json.log",
        "Name": "/nextcloud-aio-mastercontainer",
        "RestartCount": 0,
        "Driver": "overlay2",
        "Platform": "linux",
        "MountLabel": "",
        "ProcessLabel": "",
        "AppArmorProfile": "",
        "ExecIDs": null,
        "HostConfig": {
            "Binds": [
                "nextcloud_aio_mastercontainer:/mnt/docker-aio-config:rw",
                "/var/run/docker.sock:/var/run/docker.sock:ro"
            "ContainerIDFile": "",
            "LogConfig": {
                "Type": "json-file",
                "Config": {}
            "NetworkMode": "bridge",
            "PortBindings": {
                "80/tcp": [
                        "HostIp": "",
                        "HostPort": "80"
                "8080/tcp": [
                        "HostIp": "",
                        "HostPort": "8080"
                "8443/tcp": [
                        "HostIp": "",
                        "HostPort": "8443"
            "RestartPolicy": {
                "Name": "always",
                "MaximumRetryCount": 0
            "AutoRemove": false,
            "VolumeDriver": "",
            "VolumesFrom": null,
            "ConsoleSize": [
                0,
                0
            "CapAdd": null,
            "CapDrop": null,
            "CgroupnsMode": "private",
            "Dns": [],
            "DnsOptions": [],
            "DnsSearch": [],
            "ExtraHosts": [],
            "GroupAdd": null,
            "IpcMode": "private",
            "Cgroup": "",
            "Links": null,
            "OomScoreAdj": 0,
            "PidMode": "",
            "Privileged": false,
            "PublishAllPorts": false,
            "ReadonlyRootfs": false,
            "SecurityOpt": null,
            "UTSMode": "",
            "UsernsMode": "",
            "ShmSize": 67108864,
            "Runtime": "runc",
            "Isolation": "",
            "CpuShares": 0,
            "Memory": 0,
            "NanoCpus": 0,
            "CgroupParent": "",
            "BlkioWeight": 0,
            "BlkioWeightDevice": null,
            "BlkioDeviceReadBps": null,
            "BlkioDeviceWriteBps": null,
            "BlkioDeviceReadIOps": null,
            "BlkioDeviceWriteIOps": null,
            "CpuPeriod": 0,
            "CpuQuota": 0,
            "CpuRealtimePeriod": 0,
            "CpuRealtimeRuntime": 0,
            "CpusetCpus": "",
            "CpusetMems": "",
            "Devices": null,
            "DeviceCgroupRules": null,
            "DeviceRequests": null,
            "MemoryReservation": 0,
            "MemorySwap": 0,
            "MemorySwappiness": null,
            "OomKillDisable": null,
            "PidsLimit": null,
            "Ulimits": null,
            "CpuCount": 0,
            "CpuPercent": 0,
            "IOMaximumIOps": 0,
            "IOMaximumBandwidth": 0,
            "MaskedPaths": [
                "/proc/asound",
                "/proc/acpi",
                "/proc/interrupts",
                "/proc/kcore",
                "/proc/keys",
                "/proc/latency_stats",
                "/proc/timer_list",
                "/proc/timer_stats",
                "/proc/sched_debug",
                "/proc/scsi",
                "/sys/firmware",
                "/sys/devices/virtual/powercap"
            "ReadonlyPaths": [
                "/proc/bus",
                "/proc/fs",
                "/proc/irq",
                "/proc/sys",
                "/proc/sysrq-trigger"
            "Init": true
        "GraphDriver": {
            "Data": {
                "ID": "b2fff0e72cdacacd2bd0d88a3be77acf29a97caf15d0aea01e482eecd309eb89",
                "LowerDir": "/media/andi/Backup-T7/var_docker/overlay2/bfbf79aaf5cc3e28792493c9f2b3034646ffe1e394dcdef04f2647e0885e4d8d-init/diff:/media/andi/Backup-T7/var_docker/overlay2/a427904e0d37e8df325bebc7bab32122531d89df6442df5df5869973831fce47/diff:/media/andi/Backup-T7/var_docker/overlay2/3e27d77320d65b1cb145954e0f06eb967e030fc063a2b361a3228be27e4263f6/diff:/media/andi/Backup-T7/var_docker/overlay2/70c7bf197b6e382f4c67665de2078c02d171b76f175aa010db059244a8b8f59a/diff:/media/andi/Backup-T7/var_docker/overlay2/15fcde4eab7346cf271a1b150a934da7a2b0e02888049c6435aef155c8c0b1c8/diff:/media/andi/Backup-T7/var_docker/overlay2/84552d853983fcca60bee32b6d4da6dce4f57e0f3100a7532570a619ace837e6/diff:/media/andi/Backup-T7/var_docker/overlay2/a09d927b71dd9f30921fe9248db400431610dfce5c8aaae8fa958786ea949c57/diff:/media/andi/Backup-T7/var_docker/overlay2/dae40f21c869746499068494dc5efeaf212b5f9aabe192c06cb14284a88c6c9b/diff:/media/andi/Backup-T7/var_docker/overlay2/a5221200cb70395fe898980d1a57ef171b7864f5482a8bcd4b752e6188778254/diff:/media/andi/Backup-T7/var_docker/overlay2/4bfe5842be70772f70831dbce5b3b7d20dd8de89aab26aed5ad634a9cad54f4d/diff:/media/andi/Backup-T7/var_docker/overlay2/75d047296d71499392df779369d57d6453a529ef8f0f9f7cad8307cc010866bd/diff:/media/andi/Backup-T7/var_docker/overlay2/a960bdf35741ff06bd385810fc81868ab5979faaf2bda28095c7c03bf83eb3fc/diff:/media/andi/Backup-T7/var_docker/overlay2/80f5f7c37d9ac045487471cbe2ce8dcbfc4671fe36c0e801b472f1bb0632dc58/diff:/media/andi/Backup-T7/var_docker/overlay2/b05055302719d9fb155f5040eadf4c59741ac1dd6ad2cd0b4f030460c94a60de/diff:/media/andi/Backup-T7/var_docker/overlay2/aecfce199ad8e778ad160346327344a4e32c95c650da37f50d9483653cd69afe/diff:/media/andi/Backup-T7/var_docker/overlay2/b105b3575700d0b61b60e5b4af7697a91a459ee31f685b3d5a4a1fa3bd34c841/diff:/media/andi/Backup-T7/var_docker/overlay2/e473b2f9788fc5e7228c0eb68118bf8b9107e4d9e62e8aea655c042ea2e6d519/diff:/media/andi/Backup-T7/var_docker/overlay2/156d0707e1474ee626eddae57155a615fab01d516b301cdc68742f5bc4611030/diff:/media/andi/Backup-T7/var_docker/overlay2/de40998fb453da62ae8cf68edb2240eb71a73b1d2594f54cc76c7f56cd3d7c69/diff:/media/andi/Backup-T7/var_docker/overlay2/10679caeddb5ef82b72212662b565082186e81f5a0fe826f89cbac119a9b541e/diff:/media/andi/Backup-T7/var_docker/overlay2/19a53e8057ed8279abb33a63b149c65ff5d87c555eed12fb12c8bd0ad7ddba0a/diff",
                "MergedDir": "/media/andi/Backup-T7/var_docker/overlay2/bfbf79aaf5cc3e28792493c9f2b3034646ffe1e394dcdef04f2647e0885e4d8d/merged",
                "UpperDir": "/media/andi/Backup-T7/var_docker/overlay2/bfbf79aaf5cc3e28792493c9f2b3034646ffe1e394dcdef04f2647e0885e4d8d/diff",
                "WorkDir": "/media/andi/Backup-T7/var_docker/overlay2/bfbf79aaf5cc3e28792493c9f2b3034646ffe1e394dcdef04f2647e0885e4d8d/work"
            "Name": "overlay2"
        "Mounts": [
                "Type": "volume",
                "Name": "nextcloud_aio_mastercontainer",
                "Source": "/media/andi/Backup-T7/var_docker/volumes/nextcloud_aio_mastercontainer/_data",
                "Destination": "/mnt/docker-aio-config",
                "Driver": "local",
                "Mode": "rw",
                "RW": true,
                "Propagation": ""
                "Type": "bind",
                "Source": "/var/run/docker.sock",
                "Destination": "/var/run/docker.sock",
                "Mode": "ro",
                "RW": false,
                "Propagation": "rprivate"
        "Config": {
            "Hostname": "de9086c70509",
            "Domainname": "",
            "User": "root",
            "AttachStdin": false,
            "AttachStdout": true,
            "AttachStderr": true,
            "ExposedPorts": {
                "80/tcp": {},
                "8080/tcp": {},
                "8443/tcp": {},
                "9000/tcp": {}
            "Tty": false,
            "OpenStdin": false,
            "StdinOnce": false,
            "Env": [
                "SKIP_DOMAIN_VALIDATION=true",
                "NEXTCLOUD_DATADIR=/media/andi/Backup-T7/docker/nextcloud/data_dir",
                "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
                "PHPIZE_DEPS=autoconf \t\tdpkg-dev dpkg \t\tfile \t\tg++ \t\tgcc \t\tlibc-dev \t\tmake \t\tpkgconf \t\tre2c",
                "PHP_INI_DIR=/usr/local/etc/php",
                "PHP_CFLAGS=-fstack-protector-strong -fpic -fpie -O2 -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64",
                "PHP_CPPFLAGS=-fstack-protector-strong -fpic -fpie -O2 -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64",
                "PHP_LDFLAGS=-Wl,-O1 -pie",
                "GPG_KEYS=AFD8691FDAEDF03BDF6E460563F15A9B715376CA 9D7F99A0CB8F05C8A6958D6256A97AF7600A39A6 0616E93D95AF471243E26761770426E17EBBB3DD",
                "PHP_VERSION=8.4.10",
                "PHP_URL=https://www.php.net/distributions/php-8.4.10.tar.xz",
                "PHP_ASC_URL=https://www.php.net/distributions/php-8.4.10.tar.xz.asc",
                "PHP_SHA256=14983a9ef8800e6bc2d920739fd386054402f7976ca9cd7f711509496f0d2632"
            "Cmd": null,
            "Healthcheck": {
                "Test": [
                    "CMD-SHELL",
                    "/healthcheck.sh"
            "Image": "ghcr.io/nextcloud-releases/all-in-one:latest",
            "Volumes": null,
            "WorkingDir": "/var/www/docker-aio",
            "Entrypoint": [
                "/start.sh"
            "OnBuild": null,
            "Labels": {
                "com.docker.compose.config-hash": "f5c21ab69b295db21378e4ef6c1115b6a2a38dd537f3c2a608933fd34b7d3dde",
                "com.docker.compose.container-number": "1",
                "com.docker.compose.depends_on": "",
                "com.docker.compose.image": "sha256:d5b50ff7e7611d63f64b9a063fe0243a687be0bdc22e542016b07a98f02afe22",
                "com.docker.compose.oneoff": "False",
                "com.docker.compose.project": "nextcloud",
                "com.docker.compose.project.config_files": "/media/andi/Backup-T7/docker/nextcloud/docker-compose.yaml",
                "com.docker.compose.project.working_dir": "/media/andi/Backup-T7/docker/nextcloud",
                "com.docker.compose.service": "nextcloud-aio-mastercontainer",
                "com.docker.compose.version": "2.38.1",
                "org.label-schema.vendor": "Nextcloud"
            "StopSignal": "SIGQUIT"
        "NetworkSettings": {
            "Bridge": "",
            "SandboxID": "679f3a97e037f48f7be280027c70c33fa8241aacee75622684ce5802d99dae18",
            "SandboxKey": "/var/run/docker/netns/679f3a97e037",
            "Ports": {
                "80/tcp": [
                        "HostIp": "0.0.0.0",
                        "HostPort": "80"
                        "HostIp": "::",
                        "HostPort": "80"
                "8080/tcp": [
                        "HostPort": "8080"
                        "HostIp": "::",
                        "HostPort": "8080"
                "8443/tcp": [
                        "HostPort": "8443"
                        "HostIp": "::",
                        "HostPort": "8443"
                "9000/tcp": null
            "HairpinMode": false,
            "LinkLocalIPv6Address": "",
            "LinkLocalIPv6PrefixLen": 0,
            "SecondaryIPAddresses": null,
            "SecondaryIPv6Addresses": null,
            "EndpointID": "",
            "Gateway": "",
            "GlobalIPv6Address": "",
            "GlobalIPv6PrefixLen": 0,
            "IPAddress": "",
            "IPPrefixLen": 0,
            "IPv6Gateway": "",
            "MacAddress": "",
            "Networks": {
                "nextcloud-aio": {
                    "IPAMConfig": null,
                    "Links": null,
                    "Aliases": null,
                    "MacAddress": "26:7f:57:65:e4:14",
                    "DriverOpts": null,
                    "GwPriority": 0,
                    "NetworkID": "8af19ecfa56162ab0d67e89b72392e04969f02b9cc8e8db95bf2c07560604fce",
                    "EndpointID": "55eb363824e9c367cc4f0065863c4c394a367945a1271dfaf2a7e483dfcff003",
                    "Gateway": "172.18.0.1",
                    "IPAddress": "172.18.0.3",
                    "IPPrefixLen": 16,
                    "IPv6Gateway": "",
                    "DNSNames": [
                        "b2fff0e72cda",
                        "de9086c70509"
Indeed, looks like the APACHE_PORT is not set in the mastercontainer env settings. So probably you missed to run docker compose down and then docker compose up to propagate the settings. Afterwards you need to stop and start the containers via the AIO interface to propagate the new settings to the sibling containers.
Oops, there is a problem:
docker compose down
services.nextcloud-aio-mastercontainer.environment.[0]: unexpected type map[string]interface {}
I have to check it. Probably wrong formatted. I will do this tomorrow.
Thank you very much so far.
That’s it!!!
To run compose down and up was the solution!
Now the environment is OK and apache is listening to port 11000.
Now the Caddy server on another host works fine.
Thanks a lot!
