When I open URL, browser says:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
Nextcloud log for couple of hours contains 11 lines:
{"reqId":"MRHlCmX7cMsbTA1GlKDN","level":3,"time":"2024-01-13T20:32:48+00:00","remoteAddr":"162.158.170.218","user":"--","app":"index","method":"GET","url":"/index.php/204","message":"An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'ncdb.oc_appconfig' doesn't exist","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.27.0","version":"27.0.1.2","exception":{"Exception":"Doctrine\\DBAL\\Exception\\TableNotFoundException","Message":"An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'ncdb.oc_appconfig' doesn't exist","Code":1146,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1938,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],["Doctrine\\DBAL\\Query"]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1880,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],["Doctrine\\DBAL\\Query"]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1105,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],"SELECT * FROM `oc_appconfig`",[],[]]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":337,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":418,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":184,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":374,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":128,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"enabled"]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":149,"function":"getInstalledAppsValues","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_App.php","line":231,"function":"getInstalledApps","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppFramework/Bootstrap/Coordinator.php","line":90,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"/var/www/html/lib/base.php","line":700,"function":"runInitialRegistration","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":[]},{"file":"/var/www/html/lib/base.php","line":1200,"function":"init","class":"OC","type":"::","args":[]},{"file":"/var/www/html/index.php","line":37,"args":["/var/www/html/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":49,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[42S02]: Base table or view not found: 1146 Table 'ncdb.oc_appconfig' doesn't exist","Code":1146,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","line":76,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::","args":[["PDOException",["42S02",1146,"Table 'ncdb.oc_appconfig' doesn't exist"]]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1100,"function":"query","class":"Doctrine\\DBAL\\Driver\\PDO\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":337,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":418,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":184,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":374,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":128,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"enabled"]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":149,"function":"getInstalledAppsValues","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_App.php","line":231,"function":"getInstalledApps","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppFramework/Bootstrap/Coordinator.php","line":90,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"/var/www/html/lib/base.php","line":700,"function":"runInitialRegistration","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":[]},{"file":"/var/www/html/lib/base.php","line":1200,"function":"init","class":"OC","type":"::","args":[]},{"file":"/var/www/html/index.php","line":37,"args":["/var/www/html/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":28,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[42S02]: Base table or view not found: 1146 Table 'ncdb.oc_appconfig' doesn't exist","Code":"42S02","Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","line":71,"function":"query","class":"PDO","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1100,"function":"query","class":"Doctrine\\DBAL\\Driver\\PDO\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":337,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":418,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":184,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":374,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":128,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"enabled"]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":149,"function":"getInstalledAppsValues","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_App.php","line":231,"function":"getInstalledApps","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppFramework/Bootstrap/Coordinator.php","line":90,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"/var/www/html/lib/base.php","line":700,"function":"runInitialRegistration","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":[]},{"file":"/var/www/html/lib/base.php","line":1200,"function":"init","class":"OC","type":"::","args":[]},{"file":"/var/www/html/index.php","line":37,"args":["/var/www/html/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","Line":71}},"message":"An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'ncdb.oc_appconfig' doesn't exist","exception":{},"CustomMessage":"An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'ncdb.oc_appconfig' doesn't exist"}}
{"reqId":"MRHlCmX7cMsbTA1GlKDN","level":3,"time":"2024-01-13T20:32:48+00:00","remoteAddr":"162.158.170.218","user":"--","app":"core","method":"GET","url":"/index.php/204","message":"Exception thrown: Doctrine\\DBAL\\Exception\\TableNotFoundException","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.27.0","version":"27.0.1.2","exception":{"Exception":"Doctrine\\DBAL\\Exception\\TableNotFoundException","Message":"An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'ncdb.oc_appconfig' doesn't exist","Code":1146,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1938,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],["Doctrine\\DBAL\\Query"]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1880,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],["Doctrine\\DBAL\\Query"]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1105,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],"SELECT * FROM `oc_appconfig`",[],[]]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":337,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":418,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":184,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":374,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":128,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"enabled"]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":149,"function":"getInstalledAppsValues","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_App.php","line":231,"function":"getInstalledApps","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppFramework/Bootstrap/Coordinator.php","line":90,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"/var/www/html/lib/base.php","line":700,"function":"runInitialRegistration","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":[]},{"file":"/var/www/html/lib/base.php","line":1200,"function":"init","class":"OC","type":"::","args":[]},{"file":"/var/www/html/index.php","line":37,"args":["/var/www/html/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":49,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[42S02]: Base table or view not found: 1146 Table 'ncdb.oc_appconfig' doesn't exist","Code":1146,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","line":76,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::","args":[["PDOException",["42S02",1146,"Table 'ncdb.oc_appconfig' doesn't exist"]]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1100,"function":"query","class":"Doctrine\\DBAL\\Driver\\PDO\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":337,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":418,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":184,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":374,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":128,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"enabled"]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":149,"function":"getInstalledAppsValues","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_App.php","line":231,"function":"getInstalledApps","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppFramework/Bootstrap/Coordinator.php","line":90,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"/var/www/html/lib/base.php","line":700,"function":"runInitialRegistration","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":[]},{"file":"/var/www/html/lib/base.php","line":1200,"function":"init","class":"OC","type":"::","args":[]},{"file":"/var/www/html/index.php","line":37,"args":["/var/www/html/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":28,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[42S02]: Base table or view not found: 1146 Table 'ncdb.oc_appconfig' doesn't exist","Code":"42S02","Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","line":71,"function":"query","class":"PDO","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1100,"function":"query","class":"Doctrine\\DBAL\\Driver\\PDO\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":337,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":418,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":184,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":374,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":128,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"enabled"]},{"file":"/var/www/html/lib/private/App/AppManager.php","line":149,"function":"getInstalledAppsValues","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_App.php","line":231,"function":"getInstalledApps","class":"OC\\App\\AppManager","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppFramework/Bootstrap/Coordinator.php","line":90,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"/var/www/html/lib/base.php","line":700,"function":"runInitialRegistration","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":[]},{"file":"/var/www/html/lib/base.php","line":1200,"function":"init","class":"OC","type":"::","args":[]},{"file":"/var/www/html/index.php","line":37,"args":["/var/www/html/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","Line":71}},"CustomMessage":"Exception thrown: Doctrine\\DBAL\\Exception\\TableNotFoundException"}}
{"reqId":"MRHlCmX7cMsbTA1GlKDN","level":3,"time":"2024-01-13T20:32:48+00:00","remoteAddr":"162.158.170.218","user":"--","app":"core","method":"GET","url":"/index.php/204","message":"Exception thrown: Doctrine\\DBAL\\Exception\\TableNotFoundException","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.27.0","version":"27.0.1.2","exception":{"Exception":"Doctrine\\DBAL\\Exception\\TableNotFoundException","Message":"An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'ncdb.oc_appconfig' doesn't exist","Code":1146,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1938,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],["Doctrine\\DBAL\\Query"]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1880,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],["Doctrine\\DBAL\\Query"]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1105,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":[["Doctrine\\DBAL\\Driver\\PDO\\Exception"],"SELECT * FROM `oc_appconfig`",[],[]]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":337,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":418,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":184,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":374,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_App.php","line":734,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"installed_version"]},{"file":"/var/www/html/lib/private/TemplateLayout.php","line":236,"function":"getAppVersions","class":"OC_App","type":"::","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->","args":["error",""]},{"file":"/var/www/html/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":291,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/index.php","line":104,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[["Doctrine\\DBAL\\Exception\\TableNotFoundException"],500]}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":49,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[42S02]: Base table or view not found: 1146 Table 'ncdb.oc_appconfig' doesn't exist","Code":1146,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","line":76,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::","args":[["PDOException",["42S02",1146,"Table 'ncdb.oc_appconfig' doesn't exist"]]]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1100,"function":"query","class":"Doctrine\\DBAL\\Driver\\PDO\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":337,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":418,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":184,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":374,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_App.php","line":734,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"installed_version"]},{"file":"/var/www/html/lib/private/TemplateLayout.php","line":236,"function":"getAppVersions","class":"OC_App","type":"::","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->","args":["error",""]},{"file":"/var/www/html/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":291,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/index.php","line":104,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[["Doctrine\\DBAL\\Exception\\TableNotFoundException"],500]}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":28,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[42S02]: Base table or view not found: 1146 Table 'ncdb.oc_appconfig' doesn't exist","Code":"42S02","Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","line":71,"function":"query","class":"PDO","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Connection.php","line":1100,"function":"query","class":"Doctrine\\DBAL\\Driver\\PDO\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`"]},{"file":"/var/www/html/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":337,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT * FROM `oc_appconfig`",[],[],null]},{"file":"/var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":377,"function":"executeQuery","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":280,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":418,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":184,"function":"loadConfigValues","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppConfig.php","line":374,"function":"getApps","class":"OC\\AppConfig","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_App.php","line":734,"function":"getValues","class":"OC\\AppConfig","type":"->","args":[false,"installed_version"]},{"file":"/var/www/html/lib/private/TemplateLayout.php","line":236,"function":"getAppVersions","class":"OC_App","type":"::","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":142,"function":"__construct","class":"OC\\TemplateLayout","type":"->","args":["error",""]},{"file":"/var/www/html/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":291,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/index.php","line":104,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[["Doctrine\\DBAL\\Exception\\TableNotFoundException"],500]}],"File":"/var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php","Line":71}},"CustomMessage":"Exception thrown: Doctrine\\DBAL\\Exception\\TableNotFoundException"}}
Well, I can see problem now:
I’ll try to google this problem, thank you.
MariaDb volume inside Nextcloud folder worked fine for a long time, there is not even any user rights problem with folders, they are separated. I agree that’s bad solution, but it makes it easier to backup data for me.
