After completing the installation steps, I do not have the installation wizard at the assigned IP address. I do see the Apache default page. Where do I start to troubleshoot. I have changed the file ownership and modified the php. I am using a physical server.
What “installations steps” exactly did you complete?
Did you create the apache configuration file pointing to the directory where you installed your nextcloud like described → here ← ?
In your apache2 configuration.
What do you understand under “modified”?
That information is absolutely worthless without specifying the operating system running on it.
Much and good luck,
ernolf
I have completed the steps in the guide up to and including Installation on Linux.
ernolf,
Yes, I did compete the apache configuration file, I was not getting the landing page until I fixed this file.
Anything specific that is a common mistake in the apache2 file configuration? I copied it from the installation guide. and made the changes for my domain name.
I changed the php file as directed in the installation guide.
Ubuntu 22.04
