- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
30
22
apache
nginx 1.18
- PHP version (e.g, 8.3):
8.1
yes
always
script
yesmod_security
I wanted to share a feedback of an issue I found, if mod_security is comfigured on NGINX, there will be false positives that will prevent the user to brows and look at image in the internet experience ( after the reverse proxy, it works fine if the browsing is local without the WAF) :
The culpitre is this rule from the coreruleset :
[file “/etc/nginx/modsec/coreruleset/rules/REQUEST-949-BLOCKING-EVALUATION.conf”] [line “222”] [id “949110”] [rev “”] [msg “Inbound Anomaly Score Exceeded (Total Score: 5)”] [data “”] [severity “0”]
[ver “OWASP_CRS/4.23.0-dev”] [maturity “0”] [accuracy “0”] [tag “anomaly-evaluation”] [tag “OWASP_CRS”]
so you need to comment this rule id 949110 or you need to disable ( by default it is in deny, you might want to audit it only.. )
ModSecurity: Access denied with code 403 (phase 2).
Matched "Operator `Ge' with parameter `5' against variable `TX:BLOCKING_INBOUND_ANOMALY_SCORE' (Value: `5' )
[file "/etc/nginx/modsec/coreruleset/rules/REQUEST-949-BLOCKING-EVALUATION.conf"]
[line "222"] [id "949110"] [rev ""] [msg "Inbound Anomaly Score Exceeded (Total Score: 5)"] [data ""] [severity "0"]
[ver "OWASP_CRS/4.23.0-dev"] [maturity "0"] [accuracy "0"] [tag "anomaly-evaluation"] [tag "OWASP_CRS"]
[hostname "XXXXX.XXXXXXXX.COM"] [uri "/remote.php/dav/files/XXXXXXX/"] [unique_id "XXXXXXX.XXXXXXX"] [ref ""]
PASTE
PASTE HERE
PASTE HERE
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
