When setting up Nexcloud 12 for the first time, I was unable to set the data directory to /home/nextcloud/data/ It said that the directory was inaccessible. I made sure that ownership was apache:apache and permissions were 775 throughout the /home/nextcloud directory.
I moved the data directory from the installed directory to home/nextcloud. after installation. I set the new location in config.php
I ran sudo -u apache ./occ files:scan --all
I got the following error:
Your data directory is invalid
Ensure there is a file called “.ocdata” in the root of the data directory.
Exception: Environment not properly prepared. in /var/www/html/nextcloud/lib/private/Console/Application.php:145
There is an .ocdata file in that directory, but it is a 0 byte file.
[/details]
Nextcloud version 12.0.2
Operating system and version Centos 7.5.1804
Apache or nginx version Apache 2.4.6
PHP version (eg, 7.1): 7.0
Thanks, and let me know if additional info would be helpful.
