example
longer
example
here
Nextcloud version: 25.0.3.2
Operating system and version: Ubuntu 22.04.1 LTS, Proxmox, NextcloudVM
Apache version: 2.4.52 (Ubuntu)
PHP version: 8.1
My Nextcloud instance is running on a VM in proxmox behind a reverse proxy (and let’s encrypt certificate). All worked fine with connection from web and locally. Now i face the issue, that I can no more connect to Nextcloud over LAN from one specific computer (using URL). If I change to WLAN connection there are no issues. My laptop over WLAN works as well. Android Version working as well.
Steps i took but the problem remains on this specific PC (only on LAN):
deactivated firewalls
tried with other browsers
changed IP and Computer name
deactivated IPV6
deleted the bruteforce list in mysql on Nextcloud → clean
checked IP tables on Nextcloud and Proxyserver → no bans
I can not pinpoint the source of this strange issue… May be someone of you guys has an idea.
thanks for your effort and reply! I thought about that and checked again but both hosts files show the same entry. I think this is not the issue because over WLAN connection on the “issue” PC I can reach the Nextcloud server via URL… I use windows defender on both machines.
having too little informations to judge just an educated guess - given the fact WLAN and LAN are more or less the same network, just different IPs for same device (-> really?), the problem must be related to the IP you are using in WLAN. maybe you triggered brute force protection somehow (testing yourself, bad app etc…). try another IP in WLAN and check if the problem persist… you already check basic bruteforce things… what is the difference in your LAN vs WLAN? same system? same IP range? DNS and routing?
The problem still remains. I tried different config.php configurations of the nextcloud instance. If i deactivate forced https (it is behind a reverse proxy) i can without problems connect via the internal IP. External URL from LAN connections are not working. WLAN connections with direct IP (no ssl-certificate) and external URL (with ssl-certificate due to proxy) are working without problems. I even tried a Rasperry pi, the same problem remains. And yes, the internal IPs on LAN/WLAN are in the same range (DHCP, 192.168.0.1-254). I tried another install of nginx reverse proxy and the problems still persists. Restarted my modem/router etc.
I think the problem lies within the modem/router of my internet provider and the silent updates with some strange NAT/loopback/hairpinning rules or maybe firewall or header problems… But i do not get why only the LAN connections are affected and how to test this. There are some guys from the Cablecom/Sunrise community who have reported the same problem (see the link).
For me, I am out of ideas. My Internet provider does not care and “just rebooted the modem…!” Maybe a new Nextcloud install can resolve the problems (i have not triedyet) but i highly doubt that. For now i entered the local IP for nextcloud on my working PC (LAN) as a quick fix… But it is kind of frustrating.
