Nextcloud version 12.0.0.29:
Operating system and version Raspbian GNU/Linux 8.0 (jessie):
Apache or nginx version nginx 1.10.2-2:
PHP version 7.0.14-2:
Is this the first time you’ve seen this error?: yes
Can you reliably replicate it? (If so, please outline steps): I haven’t tried
My backup server used to run Nextcloud 11 and a few days ago I tried to upgrade it to Nextcloud 12 and now the web interface shows the following error:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
/var/log/nextcloud.log doesn’t show anything when this error occurs, so I decided to dig into the PHP code myself a bit. Editing index.php, I added some logging code around https://github.com/nextcloud/server/blob/08702cbabaa4169b9fd368bc4b003c1ee0d73a40/index.php#L59 which revealed that the error is coming from https://github.com/nextcloud/server/blob/08702cbabaa4169b9fd368bc4b003c1ee0d73a40/lib/private/Files/Node/Node.php#L97. Adding a die($this->path) before that line reveals that the path name that isn’t found is “/appdata_ocsy9nheifei/js”. My data directory is /data, and under it I have:
$ ls -al /data/appdata_ocsy9nheifei
total 24
drwxr-xr-x 6 www-data www-data 4096 Jun 11 19:48 .
drwxrwx— 9 pi www-data 4096 Dec 14 04:27 …
drwxr-xr-x 2 www-data www-data 4096 Dec 14 04:27 appstore
drwxr-xr-x 4 www-data www-data 4096 Dec 14 04:45 avatar
drwxr-xr-x 2 www-data www-data 4096 Dec 14 04:27 preview
drwxr-xr-x 3 www-data www-data 4096 Jun 11 19:48 theming
Indeed no js directory under there. I tried creating that directory manually and now I get this exception:
[error] Exception: OCP\Files\NotPermittedException
Message: No create permission for folder
Code:0
Trace:
#0 /home/pi/nextcloud/lib/private/Files/AppData/AppData.php(112): OC\Files\Node\Folder->newFolder('core')
#1 /home/pi/nextcloud/lib/private/Template/JSCombiner.php(83): OC\Files\AppData\AppData->newFolder('core')
#2 /home/pi/nextcloud/lib/private/Template/JSResourceLocator.php(105): OC\Template\JSCombiner->process('/home/pi/nextcl...', 'core/js/merged-...', 'core')
#3 /home/pi/nextcloud/lib/private/Template/JSResourceLocator.php(68): OC\Template\JSResourceLocator->cacheAndAppendCombineJsonIfExist('/home/pi/nextcl...', 'core/js/merged-...')
#4 /home/pi/nextcloud/lib/private/Template/ResourceLocator.php(75): OC\Template\JSResourceLocator->doFind('js/merged-templ...')
#5 /home/pi/nextcloud/lib/private/TemplateLayout.php(249): OC\Template\ResourceLocator->find(Array)
#6 /home/pi/nextcloud/lib/private/TemplateLayout.php(132): OC\TemplateLayout::findJavascriptFiles(Array)
#7 /home/pi/nextcloud/lib/private/legacy/template.php(205): OC\TemplateLayout->__construct('guest', 'core')
#8 /home/pi/nextcloud/lib/public/AppFramework/Http/TemplateResponse.php(157): OC_Template->fetchPage()
#9 /home/pi/nextcloud/lib/private/AppFramework/Http/Dispatcher.php(113): OCP\AppFramework\Http\TemplateResponse->render()
#10 /home/pi/nextcloud/lib/private/AppFramework/App.php(114): OC\AppFramework\Http\Dispatcher->dispatch(Object(OC\Core\Controller\LoginController), 'showLoginForm')
#11 /home/pi/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php(47): OC\AppFramework\App::main('OC\\Core\\Control...', 'showLoginForm', Object(OC\AppFramework\DependencyInjection\DIContainer), Array)
#12 [internal function]: OC\AppFramework\Routing\RouteActionHandler->__invoke(Array)
#13 /home/pi/nextcloud/lib/private/Route/Router.php(299): call_user_func(Object(OC\AppFramework\Routing\RouteActionHandler), Array)
#14 /home/pi/nextcloud/lib/base.php(1000): OC\Route\Router->match('/login')
#15 /home/pi/nextcloud/index.php(40): OC::handleRequest()
#16 {main}
File:/home/pi/nextcloud/lib/private/Files/Node/Folder.php
Line:166
Even though the mode for /data/appdata_ocsy9nheifei/js is 777. So I had to create /data/appdata_ocsy9nheifei/js/core and change its mode to 777 myself manually. I had to repeat this a number of times by getting similar error messages over and over again and creating the respective directories manually. After that I got a similar error message for a non-existing /data/appdata_ocsy9nheifei/css directory as well, and created that one similarly as well. After doing all of this now I can use the web interface again, it seems.
This is the current state of these new directories:
$ ls -l /data/appdata_ocsy9nheifei/{js,css}
/data/appdata_ocsy9nheifei/css:
total 20
drwxr-xr-x 2 pi pi 4096 Jun 11 22:39 core
drwxr-xr-x 2 pi pi 4096 Jun 11 22:39 files
drwxr-xr-x 2 pi pi 4096 Jun 11 22:39 files_sharing
drwxr-xr-x 2 pi pi 4096 Jun 11 22:39 files_texteditor
drwxr-xr-x 2 pi pi 4096 Jun 11 22:37 theming
/data/appdata_ocsy9nheifei/js:
total 40
drwxrwxrwx 2 root root 4096 Jun 11 22:01 activity
drwxrwxrwx 2 root root 4096 Jun 11 22:02 comments
drwxrwxrwx 2 root root 4096 Jun 11 22:06 core
drwxrwxrwx 2 root root 4096 Jun 11 22:01 files
drwxrwxrwx 2 root root 4096 Jun 11 22:04 files_sharing
drwxrwxrwx 2 root root 4096 Jun 11 22:06 files_texteditor
drwxrwxrwx 2 root root 4096 Jun 11 22:04 files_versions
drwxrwxrwx 2 root root 4096 Jun 11 22:06 gallery
drwxrwxrwx 2 root root 4096 Jun 11 22:01 notifications
drwxrwxrwx 2 root root 4096 Jun 11 22:07 systemtags
The directories under /data/appdata_ocsy9nheifei/css were created by Nextcloud not me.
I both wanted to report this issue in case other users are hitting this since digging oneself out of it wasn’t wasy and also because I’m not quite sure if everything is now in a good condition or not…
'instanceid' => 'ocsy9nheifei',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'cloud.xxx',
'datadirectory' => '/data',
'overwrite.cli.url' => 'https://cloud.xxx',
'version' => '12.0.0.29',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'xxx',
'dbpassword' => 'xxx',
'logtimezone' => 'UTC',
'logfile' => '/var/log/nextcloud.log',
'mail_domain' => 'xxx',
'mail_smtpmode' => 'php',
'loglevel' => 2,
Remember, this information may be requested if it isn’t supplied; for fastest response please provide as much as you can
Feel free to use a pastebin service, otherwise log files can be indented with 4 spaces on each line to present them in a friendlier way on the forum.
