Nextcloud Talk as a replacement for Discord
I have no support/technical question and have seen the support category. (Be aware that direct support questions will be deleted.)
on
Which general topic do you have
With Discord’s recent announcement that they’re require a face scan or a picture of a government issued ID in order to prove you’re an adult, my gaming group is looking for a self-hosted solution for chat, voice and video.
So, I’m curious if I could run Nextcloud Talk + High Performance Backend on an 8GB Raspberry Pi 5 for a weekly 4 hour voice and video session for 6 people. I have bidirectional Gigabit Internet, so bandwidth should not be an issue. Just curious if a Pi5 could handle the voice and video, or if I need something beefier.
Probably depends on your needs.
If you are just looking for chat and voice, my friends and I run mumble (that is the desktop user client) in combination with murmur (that is the server part).
The OP asked for chat, voice and VIDEO.
So why bringing up another software not fullfilling their needs?
@wwe Can you give some thoughts on here?
I have no experience with Pi - I would test. I can confirm Talk video call works for 4-5 participants with and without HPB on Intel Core i7 6700.. with AiO it should be easy to start a quick test - as long quality is good enough you can improve.. otherwise if the only goal is video likely more specialised alternatives are better suited (e.g. Jitsi)..
I have an Intel Mac mini, I am running as a Fedora Linux server. I installed the packaged version of Nextcloud and am trying to get Talk with High Performance Backend set up. This server does not have Docker installed. It has Podman. And I can’t get Nextcloud AIO to work with Podman. Which is discussion to be had in a different thread.
But I have a Raspberry Pi 5 installed with Docker, so that’s why I brought up the Pi.
I could try to use something more dedicated to video. I definitely want something self-hosted, because I can see these providers requiring age verification at some point.
docker and podman are more or less the same - many docs exist how to run AiO on different systems e.g. docker rootless and likely podman as well Nextcloud AiO - look at Rootless Podman Quadlet · nextcloud/all-in-one · Discussion #3487 · GitHub so your Mac Mini should have enough power to run talk
I tried that link and could not get it to work. And looking at that discussion, I am not the only one.
Then forget nextcloud AIO or docker as they are built on debian which has anounced they will implement age verification. It’s kinbd of too late to start acting about privacy in 2026!
Where did you get that info from?
To make it clear: this statement is incorrect as most Nextcloud AIO containers are built based on Alpine Linux. See Code search results · GitHub
A simple uname -a on my own fresh install of AIO says this;
`Linux nextcloud 6.12.90+deb13.1-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.90-2 (2026-05-27) x86_64 GNU/Linux`
How did you install your Nextcloud? Can you please specify by sending the guide you followed for example?
