Sorry to hear youâre facing problems
help.nextcloud.com is for home/non-enterprise users. If youâre running a business, paid support can be accessed via portal.nextcloud.com where we can ensure your business keeps running smoothly.
example
longer
example
here
Some or all of the below information will be requested if it isnât supplied; for fastest response please provide as much as you can
Nextcloud version (eg, 20.0.5): 20.0.7
Operating system and version (eg, Ubuntu 20.04): Linux 5.10.28-Unraid x86_64
Apache or nginx version (eg, Apache 2.4.25): nginx/1.20.2 (fpm-fcgi)
PHP version (eg, 7.4): 7.4.26
My windows 10 machine stops updating now. When I check the logs located on appdata\nextcloud\log\php\error.log I get the following info:
[12-Dec-2021 02:00:01] NOTICE: fpm is running, pid 2027
[12-Dec-2021 02:00:01] NOTICE: ready to handle connections
[13-Dec-2021 01:00:32] NOTICE: Terminating âŚ
[13-Dec-2021 01:00:32] NOTICE: exiting, bye-bye!
[13-Dec-2021 01:03:42] NOTICE: fpm is running, pid 394
[13-Dec-2021 01:03:42] NOTICE: ready to handle connections
[13-Dec-2021 03:00:11] NOTICE: Terminating âŚ
[13-Dec-2021 03:00:11] NOTICE: exiting, bye-bye!
[14-Dec-2021 11:37:01] NOTICE: fpm is running, pid 405
[14-Dec-2021 11:37:01] NOTICE: ready to handle connections
[14-Dec-2021 11:52:25] NOTICE: Terminating âŚ
[14-Dec-2021 11:52:25] NOTICE: exiting, bye-bye!
[14-Dec-2021 11:52:51] NOTICE: fpm is running, pid 403
[14-Dec-2021 11:52:51] NOTICE: ready to handle connections
[14-Dec-2021 13:54:31] WARNING: [pool www] seems busy (you may need to increase pm.start_servers, or pm.min/max_spare_servers), spawning 8 children, there are 0 idle, and 6 total children
[14-Dec-2021 13:54:32] WARNING: [pool www] seems busy (you may need to increase pm.start_servers, or pm.min/max_spare_servers), spawning 16 children, there are 0 idle, and 7 total children
[14-Dec-2021 14:26:13] WARNING: [pool www] seems busy (you may need to increase pm.start_servers, or pm.min/max_spare_servers), spawning 8 children, there are 0 idle, and 6 total children
[15-Dec-2021 10:32:04] WARNING: [pool www] seems busy (you may need to increase pm.start_servers, or pm.min/max_spare_servers), spawning 8 children, there are 0 idle, and 6 total children
[15-Dec-2021 10:32:18] WARNING: [pool www] seems busy (you may need to increase pm.start_servers, or pm.min/max_spare_servers), spawning 8 children, there are 0 idle, and 6 total children
Is this the first time youâve seen this error? (Y/N):Y
- Open Nextcloud
{"reqId":"jNDBK1N7vaDss94Uk2nK","level":4,"time":"2021-12-13T09:00:08+00:00","remoteAddr":"47.221.239.108","user":"shendrix","app":"webdav","method":"PROPFIND","url":"/remote.php/dav/files/shendrix/","message":{"Exception":"Sabre\\DAV\\Exception\\ServiceUnavailable","Message":"Doctrine\\DBAL\\Exception\\DriverException: An exception occurred while executing 'SELECT `id`, `numeric_id`, `available`, `last_checked` FROM `oc_storages` WHERE `id` = ?' with params [\"home::shendrix\"]:\n\nSQLSTATE[HY000]: General error: 2006 MySQL server has gone away","Code":0,"Trace":[{"file":"/config/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":192,"function":"check","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->"},{"file":"/config/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":144,"function":"check","class":"Sabre\\DAV\\Auth\\Plugin","type":"->"},{"file":"/config/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"beforeMethod","class":"Sabre\\DAV\\Auth\\Plugin","type":"->"},{"file":"/config/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":458,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/config/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/config/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":319,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/config/www/nextcloud/apps/dav/lib/Server.php","line":332,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/config/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/config/www/nextcloud/remote.php","line":167,"args":["/config/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/config/www/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php","Line":163,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Windows) mirall/3.4.0stable-Win64 (build 20211129) (Nextcloud, windows-10.0.19044 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"20.0.7.1"}
{"reqId":"2VIfjCWjZvguZPA1LK97","level":2,"time":"2021-12-14T15:11:27+00:00","remoteAddr":"71.14.139.183","user":"--","app":"no app in context","method":"POST","url":"/login","message":"Login failed: xxxxx (Remote IP: xx.xx.xxx.xxx)","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.93 Safari/537.36 Edg/96.0.1054.53","version":"20.0.7.1"}
output of your config.php file in /path/to/nextcloud
'datadirectory' => '/data',
'instanceid' => 'xxxxxx',
'passwordsalt' => 'xxx/xxx/xxx',
'secret' => 'xxxxxx',
0 => '192.168.1.xx:444',
1 => 'nextcloud.xxxxxx.com',
'version' => '20.0.7.1',
'overwrite.cli.url' => 'https://nextcloud.xxxxxx.com',
'overwritehost' => 'nextcloud.xxxxxx.com',
'dbname' => 'nextcloud',
'dbhost' => '192.168.1.xx:3306',
'dbuser' => 'xxxxxx',
'dbpassword' => 'xxxxxx',
copied from \appdata\nextcloud\www\nextcloud\config\config.php
2021/12/13 03:00:08 [error] 415#415: *1781 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught Error: Class 'OCA\DAV\Connector\Sabre\ExceptionLoggerPlugin' not found in /config/www/nextcloud/remote.php:61
Stack trace:
#0 /config/www/nextcloud/remote.php(169): handleException()
#1 {main}
thrown in /config/www/nextcloud/remote.php on line 61" while reading response header from upstream, client: 71.14.139.183, server: _, request: "PROPFIND /remote.php/dav/files/xxxxxx/ HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.xxxxxx.com"
2021/12/14 11:37:23 [error] 431#431: *109 upstream prematurely closed FastCGI request while reading upstream, client: xx.xxx.xxx.xxx, server: _, request: "GET /remote.php/dav/files/shendrix/Desktop/iPipeline%20Template.txt HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.xxxxxx.com"
2021/12/14 11:38:06 [error] 431#431: *354 upstream prematurely closed FastCGI request while reading upstream, client: xx.xxx.xxx.xxx, server: _, request: "GET /remote.php/dav/files/shendrix/Desktop/iPipeline%20Template.txt HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.xxxxxx.com"
2021/12/14 11:53:55 [error] 429#429: *77 upstream prematurely closed FastCGI request while reading upstream, client: xx.xxx.xxx.xxx, server: _, request: "GET /remote.php/dav/files/shendrix/Desktop/iPipeline%20Template.txt HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.xxxxxx.com"
2021/12/14 12:45:46 [error] 429#429: *1427 upstream prematurely closed FastCGI request while reading upstream, client: xx.xxx.xxx.xxx, server: _, request: "GET /remote.php/dav/files/shendrix/Desktop/iPipeline%20Template.txt HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.xxxxxx.com"
2021/12/14 13:55:36 [error] 429#429: *10246 upstream prematurely closed FastCGI request while reading upstream, client: xx.xxx.xxx.xxx, server: _, request: "GET /remote.php/dav/files/shendrix/Desktop/iPipeline%20Template.txt HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.xxxxxx.com"
2021/12/14 19:55:51 [error] 429#429: *20107 upstream prematurely closed FastCGI request while reading upstream, client: xx.xxx.xxx.xxx, server: _, request: "GET /remote.php/dav/files/shendrix/Desktop/iPipeline%20Template.txt HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.xxxxxx.com"
copied from \appdata\nextcloud\log\nginx\error.log
