Nextcloud startup problem
Raspberry pi 8gb apache nextcloud 25, when starting I get this error:
Error
  • Configuration was not read or initialized correctly, not overwriting /var/www/nextcloud/config/config.php
Could you give me a hand?
I gave the command:
sudo chmod 750 /var/www/nextcloud/config
but I keep getting this error
Could indicate that the SD card is damaged?
Security Support for nextcloud 25 was ending 31 Oct 2023. So its EOL since one and a half year.
