Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 20.0.5): 23.0.4
Operating system and version (eg, Ubuntu 20.04): Official Docker image nextcloud:fpm-stable
Apache or nginx version (eg, Apache 2.4.25): Nginx 1.21.6
PHP version (eg, 7.4): The one from the Docker image
Sometimes when my Nextcloud instance is a bit under stress like e.g. someone uploads a large video or someone scrolls too fast through a folder with many images (i have the preview generator active) my Nextcloud simply stops working.
What this means is the app is unusable - it loads forever - and the web page just shows a 504 Gateway Time-out error.
According to Portainer the CPU load of Nextcloud is at about 15-30 percent so not too heavy but it’s definitely doing something.
I am not sure what exactly triggers this, but it’s very annoying, because the Nextcloud instance takes a really long time until it comes up again (about 15 min mostly).
Not even a restart of the Docker Nextcloud container helps. I have to restart all containers that belogn to the docker-compose stack including MariaDB.
Is this the first time you’ve seen this error? (Y/N): No
- Put Nextcloud under a bit of stress like uploading a few large files while accessing it from multiple devices etc.
Nothing really special there, just a few deprecation warnings. But the Docker logs show this:
172.19.0.5 - 04/May/2022:18:47:12 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:18:47:13 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:18:47:15 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:18:52:25 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:18:52:26 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:18:52:27 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:18:52:29 +0000 "GET /index.php" 204
172.19.0.5 - Laurenz 04/May/2022:18:52:50 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - Laurenz 04/May/2022:18:52:58 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - Laurenz 04/May/2022:18:52:59 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - 04/May/2022:18:53:03 +0000 "PROPFIND /remote.php" 401
172.19.0.5 - Laurenz 04/May/2022:18:53:03 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - 04/May/2022:18:53:04 +0000 "PROPFIND /remote.php" 401
172.19.0.5 - Laurenz 04/May/2022:18:53:04 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - Laurenz 04/May/2022:18:53:28 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - Laurenz 04/May/2022:18:53:47 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - 04/May/2022:18:53:55 +0000 "GET /index.php" 204
172.19.0.5 - Laurenz 04/May/2022:18:53:58 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - Laurenz 04/May/2022:18:54:00 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - Laurenz 04/May/2022:18:54:28 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - Laurenz 04/May/2022:18:54:45 +0000 "GET /index.php" 200
172.19.0.5 - Laurenz 04/May/2022:18:54:45 +0000 "GET /ocs/v2.php" 200
172.19.0.5 - Laurenz 04/May/2022:18:54:45 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - Laurenz 04/May/2022:18:54:46 +0000 "GET /ocs/v2.php" 200
172.19.0.5 - Laurenz 04/May/2022:18:54:47 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - Laurenz 04/May/2022:18:54:48 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - Laurenz 04/May/2022:18:54:49 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - Laurenz 04/May/2022:18:55:15 +0000 "HEAD /remote.php" 404
172.19.0.5 - Laurenz 04/May/2022:18:55:16 +0000 "MKCOL /remote.php" 201
172.19.0.5 - Laurenz 04/May/2022:18:55:17 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - Laurenz 04/May/2022:18:55:17 +0000 "PUT /remote.php" 201
172.19.0.5 - Laurenz 04/May/2022:18:55:27 +0000 "PUT /remote.php" 201
172.19.0.5 - 04/May/2022:18:55:31 +0000 "GET /index.php" 204
172.19.0.5 - Laurenz 04/May/2022:18:55:31 +0000 "PROPFIND /remote.php" 207
172.19.0.5 - Laurenz 04/May/2022:18:55:29 +0000 "PUT /remote.php" 201
172.19.0.5 - Laurenz 04/May/2022:18:55:32 +0000 "PUT /remote.php" 201
172.19.0.5 - Laurenz 04/May/2022:18:55:53 +0000 "PUT /remote.php" 201
172.19.0.5 - 04/May/2022:18:57:44 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:18:58:03 +0000 "PROPFIND /remote.php" 401
172.19.0.5 - 04/May/2022:18:59:03 +0000 "PROPFIND /remote.php" 401
172.19.0.5 - 04/May/2022:19:01:08 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:19:01:09 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:19:01:11 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:19:02:48 +0000 "GET /remote.php" 200
172.19.0.5 - 04/May/2022:19:02:58 +0000 "PROPFIND /remote.php" 401
172.19.0.5 - 04/May/2022:19:03:58 +0000 "PROPFIND /remote.php" 401
172.19.0.5 - 04/May/2022:19:04:34 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:19:05:24 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:19:08:04 +0000 "GET /index.php" 302
172.19.0.5 - 04/May/2022:19:08:16 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:19:08:17 +0000 "GET /index.php" 204
172.19.0.5 - 04/May/2022:19:08:59 +0000 "GET /index.php" 302
172.19.0.5 - 04/May/2022:19:10:00 +0000 "GET /index.php" 302
[04-May-2022 19:10:20] WARNING: [pool www] server reached pm.max_children setting (60), consider raising it
172.19.0.5 - 04/May/2022:19:11:07 +0000 "GET /index.php" 204
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'xxx',
'passwordsalt' => 'xxx/xx',
'secret' => 'xxxx',
0 => 'xxx',
'trusted_proxies' =>
0 => '172.16.0.0/12',
'overwrite.cli.url' => 'https://xxx',
'version' => '23.0.4.1',
'dbname' => 'nextcloud',
'dbhost' => 'db',
'dbuser' => 'nextadm',
'dbpassword' => 'xxx',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_smtphost' => 'smtp.googlemail.com',
'mail_smtpport' => '465',
'mail_from_address' => 'xxx',
'mail_domain' => 'xxx',
'mail_smtpauth' => 1,
'mail_smtpauthtype' => 'PLAIN',
'mail_smtpname' => 'xxx',
'mail_smtppassword' => 'xxxx',
'enable_previews' => true,
'jpeg_quality' => 60,
'preview_max_x' => 1920,
'preview_max_y' => 1080,
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\MP3',
1 => 'OC\\Preview\\Movie',
2 => 'OC\\Preview\\MKV',
3 => 'OC\\Preview\\MP4',
4 => 'OC\\Preview\\AVI',
5 => 'OC\\Preview\\Image',
6 => 'OC\\Preview\\TXT',
7 => 'OC\\Preview\\MarkDown',
8 => 'OC\\Preview\\PDF',
9 => 'OC\\Preview\\Postscript',
'redis' =>
'host' => 'redis',
'port' => 6379,
'password' => 'xxx',
'loglevel' => 0,
'theme' => '',
'onlyoffice' =>
'verify_peer_off' => true,
'activity_use_cached_mountpoints' => true,
'defaultapp' => 'files',
'app_install_overwrite' =>
0 => 'imageconverter',
1 => 'previewgenerator',
172.19.0.1 - Laurenz [04/May/2022:19:00:04 +0000] "PROPFIND /remote.php/dav/ HTTP/1.1" 504 167 "-" "Mozilla/5.0 (X11; Linux x86_64) KIO/5.92 akonadi_davgroupware_resource_3/5.19.3 (21.12.3)" "37.201.214.49"
2022/05/04 19:00:04 [error] 25#25: *70623 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "PROPFIND /remote.php/dav/ HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
2022/05/04 19:00:04 [error] 25#25: *70625 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "PROPFIND /remote.php/dav/ HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
2022/05/04 19:00:20 [error] 25#25: *70629 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "PROPFIND /remote.php/dav/files/laurenz// HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
172.19.0.1 - Laurenz [04/May/2022:19:00:20 +0000] "PROPFIND /remote.php/dav/files/laurenz// HTTP/1.1" 504 167 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.20.0" "37.201.214.49"
172.19.0.1 - - [04/May/2022:19:01:08 +0000] "GET /index.php/204 HTTP/1.1" 204 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - - [04/May/2022:19:01:09 +0000] "GET /index.php/204 HTTP/1.1" 204 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - - [04/May/2022:19:01:11 +0000] "GET /index.php/204 HTTP/1.1" 204 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:01:53 +0000] "PROPFIND /remote.php/dav/files/papa// HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:02:34 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/ HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - - [04/May/2022:19:02:49 +0000] "GET /remote.php/dav/public-calendars/4nwG3W95M2rm4t6T?export HTTP/1.1" 200 6972 "-" "ICS Calendar 9.4.0" "85.13.138.196"
172.19.0.1 - - [04/May/2022:19:02:58 +0000] "PROPFIND /remote.php/dav/ HTTP/1.1" 401 569 "-" "Mozilla/5.0 (X11; Linux x86_64) KIO/5.92 akonadi_davgroupware_resource_3/5.19.3 (21.12.3)" "37.201.214.49"
172.19.0.1 - Papa [04/May/2022:19:03:14 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-15_21-55-40.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:03:54 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-15_22-01-25.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
2022/05/04 19:03:58 [error] 25#25: *70656 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "PROPFIND /remote.php/dav/ HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
2022/05/04 19:03:58 [error] 25#25: *70653 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "PROPFIND /remote.php/dav/ HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
172.19.0.1 - Laurenz [04/May/2022:19:03:58 +0000] "PROPFIND /remote.php/dav/ HTTP/1.1" 504 167 "-" "Mozilla/5.0 (X11; Linux x86_64) KIO/5.92 akonadi_davgroupware_resource_3/5.19.3 (21.12.3)" "37.201.214.49"
172.19.0.1 - - [04/May/2022:19:03:58 +0000] "PROPFIND /remote.php/dav/ HTTP/1.1" 401 569 "-" "Mozilla/5.0 (X11; Linux x86_64) KIO/5.92 akonadi_davgroupware_resource_3/5.19.3 (21.12.3)" "37.201.214.49"
172.19.0.1 - - [04/May/2022:19:04:34 +0000] "GET /index.php/204 HTTP/1.1" 204 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.20.0" "37.201.214.49"
172.19.0.1 - Papa [04/May/2022:19:04:34 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-17_05-59-00.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
2022/05/04 19:04:59 [error] 25#25: *70656 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "PROPFIND /remote.php/dav/ HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
2022/05/04 19:04:59 [error] 25#25: *70653 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "PROPFIND /remote.php/dav/ HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
172.19.0.1 - Laurenz [04/May/2022:19:04:59 +0000] "PROPFIND /remote.php/dav/ HTTP/1.1" 504 167 "-" "Mozilla/5.0 (X11; Linux x86_64) KIO/5.92 akonadi_davgroupware_resource_3/5.19.3 (21.12.3)" "37.201.214.49"
172.19.0.1 - Papa [04/May/2022:19:05:14 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-18_09-11-45.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - - [04/May/2022:19:05:19 +0000] "GET / HTTP/1.1" 499 0 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:100.0) Gecko/20100101 Firefox/100.0" "37.201.214.49"
172.19.0.1 - Laurenz [04/May/2022:19:05:24 +0000] "HEAD /remote.php/dav/files/laurenz//Bilder%20Privat/Laurenz%20Phone/2022/05/PXL_20220504_205303091.mp4 HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.20.0" "37.201.214.49"
172.19.0.1 - - [04/May/2022:19:05:24 +0000] "GET /index.php/204 HTTP/1.1" 204 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.20.0" "37.201.214.49"
172.19.0.1 - Laurenz [04/May/2022:19:05:32 +0000] "GET /ocs/v2.php/cloud/user?format=json HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.20.0" "37.201.214.49"
172.19.0.1 - Papa [04/May/2022:19:05:54 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-19_09-16-01.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Laurenz [04/May/2022:19:06:15 +0000] "HEAD /remote.php/dav/files/laurenz//Ablage/PXL_20220504_205303091.mp4 HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.20.0" "37.201.214.49"
172.19.0.1 - Papa [04/May/2022:19:06:35 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-20_09-24-09.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Laurenz [04/May/2022:19:06:41 +0000] "PROPFIND /remote.php/dav/calendars/laurenz/familienkalender/ HTTP/1.1" 499 0 "-" "DAVx5/4.2.0.3-gplay (2022/03/23; dav4jvm; okhttp/4.9.3) Android/12" "37.201.214.49"
172.19.0.1 - Laurenz [04/May/2022:19:06:45 +0000] "MKCOL /remote.php/dav/uploads/laurenz/3b69dc902bc3235d49a86a161f91917e HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.20.0" "37.201.214.49"
172.19.0.1 - Papa [04/May/2022:19:07:15 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-21_11-06-05.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:07:55 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-22_14-12-48.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - - [04/May/2022:19:08:04 +0000] "GET / HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:100.0) Gecko/20100101 Firefox/100.0" "37.201.214.49"
172.19.0.1 - - [04/May/2022:19:08:16 +0000] "GET /index.php/204 HTTP/1.1" 204 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.20.0" "37.201.214.49"
172.19.0.1 - - [04/May/2022:19:08:17 +0000] "GET /index.php/204 HTTP/1.1" 204 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.20.0" "37.201.214.49"
172.19.0.1 - Papa [04/May/2022:19:08:35 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-23_17-12-56.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - - [04/May/2022:19:08:59 +0000] "GET / HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:100.0) Gecko/20100101 Firefox/100.0" "178.200.142.40"
2022/05/04 19:09:04 [error] 27#27: *70692 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "GET /login HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
172.19.0.1 - - [04/May/2022:19:09:04 +0000] "GET /login HTTP/1.1" 504 167 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:100.0) Gecko/20100101 Firefox/100.0" "37.201.214.49"
172.19.0.1 - Laurenz [04/May/2022:19:09:07 +0000] "HEAD /remote.php/dav/files/laurenz//Ablage/PXL_20220504_205303091.mp4 HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.20.0" "37.201.214.49"
172.19.0.1 - Papa [04/May/2022:19:09:15 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-24_17-57-16.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Laurenz [04/May/2022:19:09:30 +0000] "GET /index.php/apps/notify_push/uid HTTP/1.1" 499 0 "-" "-" "178.200.142.40, 172.19.0.1, 178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:09:56 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-25_18-05-45.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
2022/05/04 19:09:59 [error] 27#27: *70702 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "GET /login HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
172.19.0.1 - - [04/May/2022:19:09:59 +0000] "GET /login HTTP/1.1" 504 167 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:100.0) Gecko/20100101 Firefox/100.0" "178.200.142.40"
172.19.0.1 - - [04/May/2022:19:10:00 +0000] "GET /favicon.ico HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:100.0) Gecko/20100101 Firefox/100.0" "178.200.142.40"
2022/05/04 19:10:07 [error] 27#27: *70692 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "MKCOL /remote.php/dav/uploads/laurenz/3b69dc902bc3235d49a86a161f91917e HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
172.19.0.1 - Laurenz [04/May/2022:19:10:07 +0000] "MKCOL /remote.php/dav/uploads/laurenz/3b69dc902bc3235d49a86a161f91917e HTTP/1.1" 504 167 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.20.0" "37.201.214.49"
172.19.0.1 - Laurenz [04/May/2022:19:10:14 +0000] "PROPFIND /remote.php/dav/files/laurenz/ HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Linux) mirall/3.4.4git (Nextcloud, manjaro-5.15.32-1-MANJARO ClientArchitecture: x86_64 OsArchitecture: x86_64)" "178.200.142.40"
172.19.0.1 - Laurenz [04/May/2022:19:10:19 +0000] "PROPFIND /remote.php/dav/files/laurenz/Bilder%20-%20Familienarchiv HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Linux) mirall/3.4.4git (Nextcloud, manjaro-5.15.32-1-MANJARO ClientArchitecture: x86_64 OsArchitecture: x86_64)" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:10:36 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-26_18-09-19.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - - [04/May/2022:19:11:07 +0000] "GET /index.php/204 HTTP/1.1" 204 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
2022/05/04 19:11:12 [error] 27#27: *70692 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "PROPFIND /remote.php/dav/uploads/laurenz/3b69dc902bc3235d49a86a161f91917e HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
172.19.0.1 - Laurenz [04/May/2022:19:11:12 +0000] "PROPFIND /remote.php/dav/uploads/laurenz/3b69dc902bc3235d49a86a161f91917e HTTP/1.1" 504 167 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.20.0" "37.201.214.49"
172.19.0.1 - Laurenz [04/May/2022:19:11:16 +0000] "GET /status.php HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Linux) mirall/3.4.4git (Nextcloud, manjaro-5.15.32-1-MANJARO ClientArchitecture: x86_64 OsArchitecture: x86_64)" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:11:16 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-27_18-12-49.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - - [04/May/2022:19:11:33 +0000] "GET /index.php/204 HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.20.0" "37.201.214.49"
2022/05/04 19:11:41 [error] 24#24: *70721 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "GET /login HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
172.19.0.1 - - [04/May/2022:19:11:41 +0000] "GET /login HTTP/1.1" 504 167 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:100.0) Gecko/20100101 Firefox/100.0" "178.200.142.40"
172.19.0.1 - Laurenz [04/May/2022:19:11:45 +0000] "GET /index.php/apps/notify_push/uid HTTP/1.1" 499 0 "-" "-" "178.200.142.40, 172.19.0.1, 178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:11:48 +0000] "PROPFIND /remote.php/dav/files/papa// HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:11:56 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-28_20-37-10.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Laurenz [04/May/2022:19:12:18 +0000] "GET /status.php HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Linux) mirall/3.4.4git (Nextcloud, manjaro-5.15.32-1-MANJARO ClientArchitecture: x86_64 OsArchitecture: x86_64)" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:12:28 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/ HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:12:36 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-29_20-40-24.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:13:08 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-15_21-55-40.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:13:16 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-30_21-20-05.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Laurenz [04/May/2022:19:13:20 +0000] "GET /status.php HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Linux) mirall/3.4.4git (Nextcloud, manjaro-5.15.32-1-MANJARO ClientArchitecture: x86_64 OsArchitecture: x86_64)" "178.200.142.40"
2022/05/04 19:13:45 [error] 24#24: *70742 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "GET /login HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
172.19.0.1 - - [04/May/2022:19:13:45 +0000] "GET /login HTTP/1.1" 504 167 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:100.0) Gecko/20100101 Firefox/100.0" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:13:48 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-15_22-01-25.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:13:56 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-31_22-05-58.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
2022/05/04 19:13:58 [error] 26#26: *70744 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "PROPFIND /remote.php/dav/ HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
172.19.0.1 - - [04/May/2022:19:13:58 +0000] "PROPFIND /remote.php/dav/ HTTP/1.1" 504 167 "-" "Mozilla/5.0 (X11; Linux x86_64) KIO/5.92 akonadi_davgroupware_resource_3/5.19.3 (21.12.3)" "178.200.142.40"
2022/05/04 19:13:58 [error] 26#26: *70746 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "PROPFIND /remote.php/dav/ HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
172.19.0.1 - Laurenz [04/May/2022:19:14:00 +0000] "GET /index.php/apps/notify_push/uid HTTP/1.1" 499 0 "-" "-" "178.200.142.40, 172.19.0.1, 178.200.142.40"
172.19.0.1 - - [04/May/2022:19:14:10 +0000] "GET / HTTP/1.1" 499 0 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.41 Safari/537.36" "178.200.142.40"
172.19.0.1 - Laurenz [04/May/2022:19:14:22 +0000] "GET /status.php HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Linux) mirall/3.4.4git (Nextcloud, manjaro-5.15.32-1-MANJARO ClientArchitecture: x86_64 OsArchitecture: x86_64)" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:14:28 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-01-17_05-59-00.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - Papa [04/May/2022:19:14:37 +0000] "PROPFIND /remote.php/dav/files/papa//.Contacts-Backup/2020-02-01_22-41-32.vcf HTTP/1.1" 499 0 "-" "Mozilla/5.0 (Android) Nextcloud-android/3.19.1" "178.200.142.40"
172.19.0.1 - - [04/May/2022:19:14:39 +0000] "GET /apps/theming/icon?v=2 HTTP/1.1" 499 0 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:100.0) Gecko/20100101 Firefox/100.0" "178.200.142.40"
2022/05/04 19:14:58 [error] 26#26: *70746 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "PROPFIND /remote.php/dav/ HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
2022/05/04 19:14:58 [error] 26#26: *70744 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 172.19.0.1, server: , request: "PROPFIND /remote.php/dav/ HTTP/1.1", upstream: "fastcgi://172.19.0.8:9000", host: "nc.xxx.de"
172.19.0.1 - - [04/May/2022:19:14:58 +0000] "PROPFIND /remote.php/dav/ HTTP/1.1" 504 167 "-" "Mozilla/5.0 (X11; Linux x86_64) KIO/5.92 akonadi_davgroupware_resource_3/5.19.3 (21.12.3)" "178.200.142.40"
The last errors or warnings are a few days ago.
I know this is not much to work with, but it’s all i could currently think of. If you need additional logs, feel free to ask and i am happy to provide them.
Edit: Here is a screenshot of the Portainer stats page. The load is indeed a bit higher than i’ve written:
I also tried restarting just the MariaDB Docker container, but this didn’t change anything. The MariaDB logs also don’t show anything interesting.
I always have to restart the Nextcloud and MariaDB container to make things work again.
