Hi folks,
I am already quite desperate after playing several days with the same problem.
I have set up a Ubuntu 18.04.04 LTS server with nextcloud 17.0.3snap1. This works fine, https is not enabled because this should be done by the reverse proxy.
Additonally I have set up a second Ubuntu 18.04.04 LTS server with nginx 1.14.0 as the reverse proxy. Plan is to have the nextcloud server and another web server side-by-side on one public ip, separated by the domain name.
Since days I am stuck with the problem that I can access nextcloud server via the domain (https certificat on nginx from LetsEncrypt) but I can not login to nextcloud, infinite login loop.
Local acces to the IP of the nextcloud server is ok, I can login and nextloud is working fine. Only access via nginx is creatig the infinite login loop.
Nextcloud Server:
Ubuntu 18.04.4 LTS
- nextcloud 17.0.3snap1
- setting for trusted domain added with command:
nextcloud.occ config:system:set trusted_domains 1 --value=domainname1.org
nextcloud.occ config:system:set trusted_domains 2 --value=192.168.x.x (IP of reverse proxy Server)
Reverse-proxy-server:
Ubuntu 18.04.4 LTS
- nginx 1.14.0
Configuration of nginx
server {
listen 80;
server_name domain1.org;
location / {
proxy_headers_hash_max_size 512;
proxy_headers_hash_bucket_size 64;
proxy_set_header Host $host;
add_header Front-End-Https on;
proxy_pass http://192.168.1.10; #IP des Nextcloud-Servers
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/xxxxxxxxxxxxxxxxxxxx/fullchain.pem$
ssl_certificate_key /etc/letsencrypt/live/xxxxxxxxxxxxxxxx/privkey.p$
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
I have already done an extensive research in internet, found a lot of similar problems. Most of them were diskussion the follwoing config commands:
nextcloud.occ config:system:set overwritehost --value=“domain.org”
nextcloud.occ config:system:set overwriteprotocol --value=“https”
Nextcloud documentation for reverse proxy says what to do
https://docs.nextcloud.com/server/15/admin_manual/configuration_server/reverse_proxy_configuration.html?highlight=reverse%20proxy
But I am not clear that I have understood everything correctly. And this documentatin is not for snap package.
Any ideas? What to test next? Where to look next?
