example
longer
example
here
Nextcloud version: 19.0.1 - installed via snap
Operating system and version: Ubuntu 20.04
Apache or nginx version: 2.4.43
PHP version: 7.3.2
Running in a VM on Proxmox
From the “Administrator - Overview” section, I get the following warning:
There are some warnings regarding your setup.
This instance is missing some recommended PHP modules. For improved performance and better compatibility it is highly recommended to install them.
imagick
Error PHP session_start(): A session had already been started - ignoring at /snap/nextcloud/22400/htdocs/lib/private/Session/Internal.php#209
2020-08-05T14:12:56-0400
2020-08-05T14:12:52-0400
Error cron Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2002] No such file or directory
2020-08-05T14:07:23-0400
Fatal webdav Sabre\DAV\Exception\ServiceUnavailable: Could not open file
2020-08-05T13:40:48-0400
Error PHP fopen(/var/snap/nextcloud/common/nextcloud/data/jon/files/Documents/****): failed to open stream: No such file or directory at /snap/nextcloud/22400/htdocs/lib/private/Files/Storage/Local.php#352
Error PHP fopen(/var/snap/nextcloud/common/nextcloud/data/jon/files/Documents/****: failed to open stream: No such file or directory at /snap/nextcloud/22400/htdocs/lib/private/Files/Storage/Local.php#352
The output of your config.php file in /var/snap/nextcloud/current/nextcloud/config/config.php
