Nextcloud Snap: create SSL certificate without using Certbot
Edited to remove all references to “self-signed” made in error:
example
longer
example
here
Nextcloud version (eg, 20.0.5): 24.0.6 (via snap)
Operating system and version (eg, Ubuntu 20.04): Debian Bookworm
Apache or nginx version (eg, Apache 2.4.25): 2.4.54
PHP version (eg, 7.4): 8.1.12
The issue you are facing: Can’t install SSL certificate using command sudo ./nextcloud.enable-https lets-encrypt because certbot requires port 80 & 443 to be open, however, my locked-down ISP router is blocking port 80 & 443. I can use any other port, just not 80 & 443, but certbot requires 80 & 443. I am hoping for a different way to get a SSL certificate from Let’s Encrypt. Thank you so much for your help in advance!
  1. Log onto server
  2. Type cd /snap/bin
  3. Type sudo ./nextcloud.enable-https lets-encrypt
Not required, I believe.
I am sorry but self signed certificate doesn’t need Lets-Encrypt.
If you are requesting Lets-Encrypt, that means you are asking for their certificate.
I think the command for self signed certificate is, sudo nextcloud.enable-https self-signed
Refer here for official docs → Enabling HTTPS (SSL, TLS) · nextcloud-snap/nextcloud-snap Wiki (github.com)
Thanks.
Sorry, looks like I confused myself. I already have a self-signed certificate, but I have an issue with an app refusing to connect to servers with self-signed certificates. So, I am trying to obtain a free official certificate via Lets Encrypt, but I’m having this issue with ports 80 & 443 being blocked by my ISP.
You can use certbot’s DNS challenge instead of the HTTP challenge. But, you will probably have to run the renewal manually each time, every 60-90 days.
Helou eddles, I have the same problem.
Did you resolve it?
With Certbot’s DNS is possible?
bye
Antonio
Buenos Aires
Argentina
Pd: I am sorry for my english
Hello here is my script I use for my snap instance of nextcloud to get around this since COX won’t allow inbound traffic on port 80 even though my router has the port opened and forwarded. https://github.com/EchoBased/certbot_dns_script/tree/main
