hi foks!
i have installed mariadb successfully with docker. And now i wanted to install nextcloud with the docker create command:
docker create --name=nextcloud --net=lsio -e PUID=65534 -e PGID=100 -e TZ=Europe/Berlin -p 8081:8080 -v /storage/.kodi/userdata/addon_data/docker.linuxserver.nextcloud/config:/config -v /storage/.kodi/userdata/docker.linuxserver.nextcloud/data:/data --restart unless-stopped linuxserver/nextcloud
But when trying to access nextcloud “site not found” When curling it i get:
LibreELEC:~ # curl -v -k https://neno.ddns.net 8081
- Trying 95.208.200.213:443…
- TCP_NODELAY set
- connect to 11.111.200.213 port 443 failed: Connection refused
- Failed to connect to mysite.ddns.net port 443: Connection refused
- Closing connection 0
curl: (7) Failed to connect to mysite.ddns.net port 443: Connection refused - Trying 0.0.31.145:80…
- TCP_NODELAY set
- Immediate connect fail for 0.0.31.145: Invalid argument
- Closing connection 1
curl: (7) Couldn’t connect to server
The nginx.log shows:
#4 {main}
thrown in /config/www/nextcloud/lib/private/AllConfig.php on line 76" while reading response header from upstream, client: 192.168.0.17, server: _, request: “GET / HTTP/2.0”, upstream: “fastcgi://127.0.0.1:9000”, host: “192.168.0.10”
2021/01/12 16:17:50 [error] 375#375: *1 FastCGI sent in stderr: “PHP message: PHP Warning: include(/config/www/nextcloud/lib/composer/composer/…/…/…/lib/private/Cache/CappedMemoryCache.php): failed to open stream: No such file or directory in /config/www/nextcloud/lib/composer/composer/ClassLoader.php on line 444PHP message: PHP Warning: include(): Failed opening ‘/config/www/nextcloud/lib/composer/composer/…/…/…/lib/private/Cache/CappedMemoryCache.php’ for inclusion (include_path=’.:/usr/share/php7’) in /config/www/nextcloud/lib/composer/composer/ClassLoader.php on line 444PHP message: PHP Fatal error: Uncaught Error: Class ‘OC\Cache\CappedMemoryCache’ not found in /config/www/nextcloud/lib/private/AllConfig.php:76
Stack trace:
#0 /config/www/nextcloud/lib/base.php(162): OC\AllConfig->__construct(Object(OC\SystemConfig))
#1 /config/www/nextcloud/lib/base.php(576): OC::initPaths()
#2 /config/www/nextcloud/lib/base.php(1091): OC::init()
#3 /config/www/nextcloud/index.php(35): require_once(’/config/www/nex…’)
#4 {main}
thrown in /config/www/nextcloud/lib/private/AllConfig.php on line 76” while reading response header from upstream, client: 192.168.0.17, server: _, request: “GET / HTTP/2.0”, upstream: “fastcgi://127.0.0.1:9000”, host: “192.168.0.10”
The config.php:
<?php $CONFIG = array ( 'memcache.local' => '\\OC\\Memcache\\APCu', 'datadirectory' => '/data/storage', 'instanceid' => '', 'passwordsalt' => '', 'secret' => '', 'trusted_domains' => array ( 0 => '192.168.0.10', ), 'dbtype' => 'pgsql', 'version' => '20.0.3.2', 'overwrite.cli.url' => 'https://192.168.0.10', 'dbname' => 'nextcloud', 'dbhost' => 'db', 'dbport' => '', 'dbtableprefix' => 'oc_', 'dbuser' => 'nextcloud', 'dbpassword' => '1111111111', ); Can anyone help out?????
