Nextcloud podman container/host system permission/ownership mismatch. Would like to align
    • 32.0.1
    • Debian GNU/Linux 13.1 (trixie)
    • Server version: Apache/2.4.65 (Debian)
      Server built: 2025-07-29T17:52:31
    • nginx version: openresty/1.27.1.1
    • PHP 8.3.27 (cli) (built: Oct 24 2025 19:16:28) (NTS)
      Copyright (c) The PHP Group
      Zend Engine v4.3.27, Copyright (c) Zend Technologies
      with Zend OPcache v8.3.27, Copyright (c), by Zend Technologies
    • Yes, its been there since then
    • idk, whenever I first installed it, been there forever
    • podman commands (container)
    • Yes, but this has nothing to do with the issue itself
Context:
- I have a raspberry-pi server running Debian (Raspberry-pi OS, doesn’t matter)
- main Linux “default” user is named server-user
- am running Nextcloud inside of the PODMAN CONTAINER
- Nextcloud podman container has the following mounts/folder mappings:
-v {$PWD}/container_share/nextcloud/html:/var/www/html
-v {$PWD}/container_share/nextcloud/data:/var/www/html/data
-v {$PWD}/container_share/nextcloud/config:/var/www/html/config
-v {$PWD}/container_share/nextcloud/nx-share:/var/www/nx-share
-v {$PWD}/container_share/media:/var/www/media-share
-v /media/server-user/extend256:/extend256
- When the Nextcloud conatiner writes files to the filesystem, they apper (on the host system) as though they are owned by a user ID 100032 + GID 100032. Exact output for one example file that has been uploaded through nextcloud client:
-rw-r--r-- 1 100032 100032 5755776 Oct 29 10:36 PXL_20251029_083636954.jpg
Same file, but from within the container looks like this:
-rw-r--r-- 1 www-data www-data 5755776 Oct 29 08:36 PXL_20251029_083636954.jpg
- www-data user has ID 33 inside of the container
The issue here is:
- that when I write a file to this share ON A HOST it is owned by server-user (ID 1000 GID 1000) which creates a permission conflict whenever I try to edit/delete files that have been created on the host via a web server (typically on my android phone).
My task is:
- to make files created BY THE CONTAINER (via the Nextcloud’s web interface) appear as though they are owned NOT by the user ID 100032 (which doesn’t even exist on the host system), but server-user (ID 1000 GID 1000) to avoid perm conflicts.
  1. Install Nextcloud server app inside of the podman container.
  2. Connect external storage to the server.
  3. Create a file on this external storage via Nextcloud a web interface.
  4. Create a file on disk using the OS methods (either touch or via GUI File > New).
  5. Try to edit/delete file/folder that has been created BY THE MEANS OF THE HOST OS ITSELF via Nextcloud web interface (or an Android/iOS app, it is irrelevant).
  6. Witness error that has something to do with the denial of permissions (I don’t remember its exact text).
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "overwriteprotocol": "https",
        "upgrade.disable-web": true,
            "localhost",
            "***REMOVED SENSITIVE VALUE***",
            "192.168.1.102"
        "dbtype": "pgsql",
        "version": "32.0.1.2",
        "overwrite.cli.url": "https:\/\/localhost",
        "dbport": "",
        "allow_web_updater": true,
        "loglevel": 2,
        "filelocking.enabled": false
- activity: 5.0.0-dev.0
- app_api: 32.0.0
- calendar: 6.0.2
- circles: 32.0.0
- comments: 1.22.0
- contactsinteraction: 1.13.1
- dashboard: 7.12.0
- dav: 1.34.2
- deck: 1.16.0
- federation: 1.22.0
- files: 2.4.0
- files_external: 1.24.0
- files_reminders: 1.5.0
- files_sharing: 1.24.0
- files_trashbin: 1.22.0
- files_versions: 1.25.0
- firstrunwizard: 5.0.0-dev.0
- integration_giphy: 2.1.0
- logreader: 5.0.0-dev.0
- news: 27.0.1
- notes: 4.12.3
- notifications: 5.0.0-dev.0
- oauth2: 1.20.0
- photos: 5.0.0-dev.1
- privacy: 4.0.0-dev.0
- profile: 1.1.0
- provisioning_api: 1.22.0
- recognize: 10.0.4
- serverinfo: 4.0.0-dev.0
- settings: 1.15.1
- sharebymail: 1.22.0
- support: 4.0.0-dev.0
- survey_client: 4.0.0-dev.0
- systemtags: 1.22.0
- text: 6.0.1
- theming: 2.7.0
- updatenotification: 1.22.0
- user_status: 1.12.0
- viewer: 5.0.0-dev.0
- weather_status: 1.12.0
- webhook_listeners: 1.3.0
- workflowengine: 2.14.0
- admin_audit: 1.22.0
- encryption: 2.20.0
- twofactor_totp: 14.0.0
- user_ldap: 1.23.0
I managed to do what you’re trying to do by adding the following lines to my podman compose:
x-podman:
    in_pod: false
services:
    data:
        image: docker.io/library/nextcloud:31.0.12
        userns_mode: "keep-id:uid=33,gid=33"
        sysctls:
            - net.ipv4.ip_unprivileged_port_start=0
        ports:
            - "8091:80"
        volumes:
Apparently what this does (notice userns_mode and sysctls lines) is map your local user running podman to the specified user inside the container; nextcloud uses www-data which has UID/GID 33/33. So I mapped my user to that UID GID and the only problem is that when setting x-podman: in_pod to false my container was acting as my local user and needed permission to bind to port 80 (inside the container), which I fixed with the sysctls line.
After that you just need to chown the folders set up in your volume to your local user and it works.
I want to clarify that I am by no means an expert and I’m running this locally behind a VPN for me and my wife and I haven’t done the proper work to check how insecure this is.
See Running as an arbitrary user / file permissions / changing the default container user
I believe this does not work, as simply using --user: uid/gid will make your container’s root (id 0) your user, but www-data (user 33) still exists inside the container, which creates a new pseudo-user in your host machine that goes something like 100032 (and your user doesn’t have read access to the files written by that user)
No. user changes the default uid/gid used by the container (which is root 0:0 by default). If you set user to anything other than that, the entrypoint defects that and does not use anything requiring root privileges. Even Apache ends up running under that user.
