example
longer
example
here
Nextcloud version (eg, 18.0.2): 18.0.4
Operating system and version (eg, Ubuntu 20.04): ARM64 docker container for nextcloud, running document server in docker container amd64, both latest version and running great
Apache or nginx version (eg, Apache 2.4.25): nginx docker container - https ://github.com/staticfloat/docker-nginx-certbot Use’s nginx/1.17.9
PHP version (eg, 7.1): PHP 7.3.17
I had to add spaces in url’s to get this to post. remove the space before : to get links to work. Sorry
This is ultimately my error https ://imgur.com/Wk8q4Ni . I do not know where the relevant error logs are for this error. Please tell me and ill fetch them. Below is more information.
https ://cloud.armory.network -> my nextcloud
https ://office.armory.network -> my document server
http ://mw11:8080 -> my nextcloud
http ://m4:8080 -> my document server
I can reach my nextcloud instance and my onlyoffice instance by domain names over https no problem. Both are reached properly with lets encrypt certs. When configuring the onlyoffice connector, i put the url where i can reach my document server. https ://imgur.com/pzBKdor It accepts the url. When attempting to open a document in nextcloud, i get the following error. https ://imgur.com/Wk8q4Ni . If i change the only office connector settings to use the http private names, and then access my nextcloud over the http url, it works. https ://imgur.com/UysUIiO & https ://imgur.com/5GeDlLp . This however is not a solution, i cant access my nextcloud over http all the time.
nginx config - https ://imgur.com/Xz4UtXI
These logs were generated when i was testing different things, non of these logs are generated when i have the settings i talked about above.
https ://imgur.com/eNOG0Hd
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'passwordsalt' => 'REMOVED',
'secret' => 'REMOVED',
0 => 'localhost',
1 => 'mw11',
'dbtype' => 'pgsql',
'version' => '18.0.4.2',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'REMOVED',
'dbhost' => 'db',
'dbuser' => 'REMOVED',
'dbpassword' => 'REMOVED',
'instanceid' => 'oc6zjjczkcwl',
