NextCloud on Oracle Ampere Compute Shape Not Persisting
    • not sure
    • Oracle Linux 8
    • Podman
    • not sure
    • not sure
    • after initial deployment. can log in and intereact with app, but once window is closed, the connection is refused when i try to navigate back to the application.
    • Oracle VM (Ampere)
i need help troubleshooting a cloud application i recently deployed following this documentation: Deploy Nextcloud on Ampere A1 on Oracle Cloud Infrastructure.
I successfully deployed and installed NextCloud onto the cloud server and was able to log into the application interact with it, however once I close the window and try to navigate back to the application, it says "This site refused to connect. ERR_CONNECTION_REFUSED.
  1. Follow above referenced documentation
  2. Login to Nextcloud
  3. Close browser window
  4. Re-open browser
  5. Navigate back to the application
  6. Should receive “connection_refused” error
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
You still access through http://<your_public_ip>:8080?
Do you have the config.php? Since it is not a standard port, it might tend to use the default one, unless you configure it (perhaps it is done by this image).
If not it can help to check the webserver logs. If the webserver does not receive the request (and refuses the connection), it could be the firewall or something.
Or things like if you don’t specify http for the protocol, it uses https per default…
