Nextcloud - Office not working after changing apache port
Hi!
I was using Nextcloud-aio docker container and everything was working fine. But then I changed Apache port and office stopped working.
sudo docker run -d \
--init \
--sig-proxy=false \
--name nextcloud-aio-mastercontainer \
--restart always \
--publish 8081:8080 \
--env APACHE_PORT=444 \
--env APACHE_IP_BINDING=0.0.0.0 \
--env APACHE_ADDITIONAL_NETWORK="" \
--env SKIP_DOMAIN_VALIDATION=false \
--volume nextcloud_aio_mastercontainer:/mnt/docker-aio-config \
--volume /var/run/docker.sock:/var/run/docker.sock:ro \
ghcr.io/nextcloud-releases/all-in-one:latest
I am getting this error:
I also tried demo server and got this error:
Hi, may I ask why did you change the APACHE_PORT?
This variable is meant for a reverse proxy deployment. See all-in-one/reverse-proxy.md at main · nextcloud/all-in-one · GitHub
Hi there!
Thanks for responding. I made a mistake in configuration, thats why it was not working. I have fixed it now.
