today I have updatet mein NC from NC24 to NC 25.0.6.
Debian 11.7 (64-bit)
Apache 2.4.56
PHP 7.4.33 / 8.0.27 for subdomain of NC25 instance
Parallel to the upgrade of the nextcloud version I want to switch from OnlyOffice (+document_server app) to NextCloud-Office (with Collabora Online - Built-in CODE Server app)
In principal the NC is working - expept the NextCloud Office.
After the upgrade to NC25 I have disable and removed the “old apps” OnlyOffice and Docmentation_Server.
Then I installed and activated the Collabora Online - Built-in CODE Server - which was successfully done. During the installation and activation of NextCloud Office I got an error, that the ‘canwrite’ column on talbe ‘oc_richdocuments_wopi’ is not available.
After some reserche I found the hint in the internet (Nextcloud-Office öffnet keine Dateien - #7 von lessi - Nextcloud/Owncloud - linuxmuster.net) that this could be a problem if there are ‘old’ oc_richdocument… tables from older collabora tests availabe. Which could be in my case as well.
So I diabled Collabora and NextCloud-Office App, removed all oc_richdocument… tables, deleted ‘richdocuments’ lines in the oc_migration table and activated ‘Collabora’ and ‘NextCloud Office’ App again.
After these changes the NextCloud Office app startet successfully.
And after entering the correct “Allow list for WOPI requests”.
==> Collabora Online Server ist erreichbar. (green bubble) is shown in the Admin-NextCloudOffice setting page.
Generally it looks successfull. But if I want to open a existing docx / xlsx (or create a new odt file) I see the message “Lade xyz.docx” and the circle is running all the time. But the file will not be opened.
I only can aboard that by logoff and login again in nextcloud.
The mouse-over link shows me following link of one of the files I want to open → https://cloud.mydomain.de/apps/files/?dir=/&fileid=2113
Is that link in principal correct?
Based on the fact that I hat used OnlyOffice before I have done the following to eleimate the ‘old’ entries in the database, but this also not helps to solve the NextCloud Office issue:
DROP TABLE IF EXISTS oc_onlyoffice_filekey
DROP TABLE IF EXISTS oc_onlyoffice_instance
DROP TABLE IF EXISTS oc_onlyoffice_permissions
DELETE from oc_migrations where app=onlyoffice;
DROP TABLE IF EXISTS oc_documentserver_changes
DROP TABLE IF EXISTS oc_documentserver_ipc
DROP TABLE IF EXISTS oc_documentserver_locks
DROP TABLE IF EXISTS oc_documentserver_sess
DELETE from oc_migrations where app=documentserver_community;
Any other idear?
Thanks
Regards
Martin
