Nextcloud Office (Collabora) blocks WOPI requests via IPv6 – How to make IPv4 and IPv6 work together without disabling IPv6?
  • Nextcloud Server version:
    • 32.0.6
    • Debian 13.3
  • Web server and version:
    • Apache 2.4.66
  • Reverse proxy and version
    • Apache 2.4.66 for Collabora and Nginx 1.26.3 for AppApi
  • PHP version:
    • 8.4.16
  • Is this the first time you’ve seen this error?:
    • no
    • about three monthe ago
  • Installation method
    • Bare Metal
    • no
I am running both Nextcloud and Nextcloud Office on the same server under Debian 13. I installed Collabora by adding the package sources to Debian. As long as I do not fill in the ‘allow list for WOPI requests,’ it works. However, if I enter the public IPv4 address of my server in this list, I get the following error message:
WOPI request denied from fe80::1:40ff:fe75:99e%ens6 as it does not match the configured ranges: 78.53.221.23, 1b23:137:128:e138::3
The IP addresses for the WOPI allow list are changed when creating this ticket.
I eventually got the combination of Nextcloud Office and Nextcloud working with the public IPv4 address in the ‘allow list for WOPI requests’ by disabling IPv6 on the server. However, I would prefer not to do that. Can anyone give me tips on how to adjust the configuration so that the combination of Nextcloud Office and Nextcloud works with IPv6 enabled and the IPv4 address listed in the ‘allow list for WOPI requests’?
  1. Install Nextcloud Bare Metal using André / Nextcloud installscript for Debian 13 · GitLab (Nextcloud install on Debian within 10 minutes)
  2. Install Collabora using that you also can find in André / Nextcloud installscript for Debian 13 · GitLab . You need to replace the contents for variables DOMAIN and DOMAIN_COLLABORA
  3. Login in Nextcloud and try to open an Office Document. Document will not be opened, In nextcloud.log you will see a the message as pasted under ‘log entries’.
{"reqId":"fQt9ef7AvuRvssNDFmCJ","level":2,"time":"2026-02-14T09:33:12+00:00","remoteAddr":"fe80::1:40ff:fe75:99e%ens6","user":"--","app":"richdocuments","method":"GET","url":"/index.php/apps/richdocuments/wopi/files/7_oc2i20txxi87?access_token=3VIHVC9kGdpvwi42pFXt0gNL9mfbZaur&access_token_ttl=0&permission=edit","scriptName":"/index.php","message":"WOPI request denied from fe80::1:40ff:fe75:99e%ens6 as it does not match the configured ranges: 78.53.221.23, 1b23:137:128:e138::3","userAgent":"COOLWSD HTTP Agent 25.04.8.3","version":"32.0.6.1","data":{"app":"richdocuments"},"id":"6990418040e25"}
There is no problem with the web browser
Apache did not make a log entry after I tried to open an office document in Nextcloud.
        "overwrite.cli.url": "https:\/\/my.nextcloudserver.org/",
        "htaccess.RewriteBase": "\/",
            "localhost",
            "my.nextcloudserver.org"
        "dbtype": "mysql",
        "version": "32.0.6.1",
        "dbport": "",
        "mysql.utf8mb4": true,
        "twofactor_enforced": "true",
        "twofactor_enforced_groups": [],
        "twofactor_enforced_excluded_groups": [
            "Basicusers"
        "default_phone_region": "NL",
        "redis": {
            "port": "6379"
        "forbidden_filename_basenames": [
            "con",
            "prn",
            "aux",
            "nul",
            "com0",
            "com1",
            "com2",
            "com3",
            "com4",
            "com5",
            "com6",
            "com7",
            "com8",
            "com9",
            "com\u00b9",
            "com\u00b2",
            "com\u00b3",
            "lpt0",
            "lpt1",
            "lpt2",
            "lpt3",
            "lpt4",
            "lpt5",
            "lpt6",
            "lpt7",
            "lpt8",
            "lpt9",
            "lpt\u00b9",
            "lpt\u00b2",
            "lpt\u00b3"
        "forbidden_filename_characters": [
        "forbidden_filename_extensions": [
            ".filepart",
            ".part"
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "587",
        "mail_smtpauth": true,
        "log_rotate_size": 349175808,
        "theme": "",
        "loglevel": 0,
        "app_install_overwrite": [],
        "updater.secret": "***REMOVED SENSITIVE VALUE***"
  • activity: 5.0.0
  • admin_audit: 1.22.0
  • announcementcenter: 7.3.0
  • app_api: 32.0.0
  • bruteforcesettings: 5.0.0
  • circles: 32.0.0
  • comments: 1.22.0
  • contactsinteraction: 1.13.1
  • dashboard: 7.12.0
  • dav: 1.34.2
  • deck: 1.16.3
  • federation: 1.22.0
  • files: 2.4.0
  • files_pdfviewer: 5.0.0
  • files_reminders: 1.5.0
  • files_sharing: 1.24.1
  • files_trashbin: 1.22.0
  • files_versions: 1.25.0
  • firstrunwizard: 5.0.0
  • groupfolders: 20.1.10
  • logreader: 5.0.0
  • mail: 5.6.12
  • notifications: 5.0.0
  • oauth2: 1.20.0
  • password_policy: 4.0.0
  • photos: 5.0.0
  • privacy: 4.0.0
  • profile: 1.1.0
  • provisioning_api: 1.22.0
  • recommendations: 5.0.0
  • related_resources: 3.0.0
  • richdocuments: 9.0.2
  • serverinfo: 4.0.0
  • settings: 1.15.1
  • sharebymail: 1.22.0
  • support: 4.0.0
  • survey_client: 4.0.0
  • systemtags: 1.22.0
  • text: 6.0.1
  • theming: 2.7.0
  • twofactor_admin: 4.9.0
  • twofactor_totp: 14.0.0
  • updatenotification: 1.22.0
  • user_status: 1.12.0
  • viewer: 5.0.0
  • weather_status: 1.12.0
  • workflowengine: 2.14.0
  • encryption: 2.20.0
  • files_external: 1.24.1
  • nextcloud_announcements: 4.0.0 (installed 4.0.0-dev.0)
  • suspicious_login: 10.0.0
  • twofactor_nextcloud_notification: 6.0.0
  • user_ldap: 1.23.0
  • webhook_listeners: 1.3.0 (installed 1.2.0)
