I’m having trouble getting the built-in Collabora CODE server working with my Nextcloud installation. When I try to open a .docx document, I receive this error:
Failed to establish socket connection or socket connection closed unexpectedly. The reverse proxy might be misconfigured.
My setup
Nextcloud hosted in a TurnKey Linux (Debian) LXC container.
Container IP:
192.168.1.122. -
Public hostname:
nextcloud.logicalunit.net. -
Apache handles HTTPS and serves Nextcloud.
Using the built-in Nextcloud Office CODE app (
richdocumentscode), version 26.04.5.2. -
CODE’s
coolwsdlistens locally on127.0.0.1:9983.
What I’ve confirmed and tried
curl http://127.0.0.1:9983/hosting/capabilitiesreturns HTTP 200 with valid JSON. -
/hosting/discoveryalso returns valid XML, and confirms that.docxfiles are supported. -
The discovery XML advertises browser endpoints through Nextcloud’s own
apps/richdocumentscode/proxy.phproute. -
Enabled Apache modules
proxy,proxy_httpandproxy_wstunnel. -
Restarted Apache and confirmed these modules are loaded.
The Apache configuration currently has a basic HTTPS virtual host serving
/var/www/nextcloud/, but no specific Collabora reverse-proxy rules.
What I’m trying to establish
Is the failure likely to be caused by Apache’s handling of WebSocket connections, or is there something else that needs configuring when using the built-in CODE app?
In particular, should the Apache virtual host contain additional reverse-proxy directives for this setup, or should the built-in richdocumentscode proxy handle all of that?
I’d appreciate any suggestions, particularly from anyone running the built-in CODE app behind Apache on TurnKey Linux or a similar Debian setup.
Thanks!
