Nextcloud version: 17 -> 18
Operating system and version : 18.04
Apache or nginx version: 1.17.9
PHP version :PHP 7.3.16
The issue you are facing: Table ‘nextcloud.oc_flow_operations_scope’ doesn’t exist
Is this the first time you’ve seen this error? (Y/N): Yes
- Upgrade NextCloud 16->17->18
logs:
$ sudo -u www-data php /var/www/nextcloud/occ upgrade -vvvv
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
2020-03-23T09:08:36+01:00 Set log level to debug
2020-03-23T09:08:36+01:00 Turned on maintenance mode
2020-03-23T09:08:36+01:00 Repair step: Repair MySQL collation
2020-03-23T09:08:36+01:00 Repair info: All tables already have the correct collation -> nothing to do
2020-03-23T09:08:36+01:00 Repair step: Repair SQLite autoincrement
2020-03-23T09:08:36+01:00 Repair step: Copy data from accounts table when migrating from ownCloud
2020-03-23T09:08:36+01:00 Repair step: Drop account terms table when migrating from ownCloud
2020-03-23T09:08:36+01:00 Updating database schema
2020-03-23T09:08:36+01:00 Updated database
2020-03-23T09:08:36+01:00 Updating …
2020-03-23T09:08:36+01:00 Repair step: Populating added database structures for workflows
2020-03-23T09:08:36+01:00 Doctrine\DBAL\Exception\TableNotFoundException: An exception occurred while executing ‘SELECT o
.id
FROM oc_flow_operations
o
LEFT JOIN oc_flow_operations_scope
s
ON o
.id
= s
.operation_id
WHERE s
.operation_id
IS NULL’:
SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘nextcloud.oc_flow_operations_scope’ doesn’t exist
2020-03-23T09:08:36+01:00 Update failed
2020-03-23T09:08:36+01:00 Maintenance mode is kept active
2020-03-23T09:08:36+01:00 Reset log level
labuser@pkml-server01:/usr/local/src$ sudo -u www-data php /var/www/nextcloud/occ maintenance:repair -vvvv
- Repair MySQL collation
- All tables already have the correct collation -> nothing to do
- Repair mime types
- Clean tags and favorites
- 0 tags of deleted users have been removed.
- 0 tags for delete files have been removed.
- 0 tag entries for deleted tags have been removed.
- 0 tags with no entries have been removed.
- Repair invalid shares
- Move .step file of updater to backup location
- Fix potential broken mount points
- No mounts updated
- Add log rotate job
- Clear frontend caches
- Image cache cleared
- SCSS cache cleared
- JS cache cleared
- Clear every generated avatar on major updates
- Add preview background cleanup job
- Queue a one-time job to cleanup old backups of the updater
- Cleanup invalid photocache files for carddav
- Add background job to cleanup login flow v2 tokens
- Remove potentially over exposing share links
- No need to remove link shares.
- Clear access cache of projects
- Switches from deprecated “production” to “stable” update channel
- Sets the enterprise logo
- Repair step already executed
- Reset generated avatar flag
- Fix component of birthday calendars
- 4 birthday calendars updated.
- Regenerating birthday calendars to use new icons and fix old birthday events without year
- Fix broken values of calendar objects
0 [>---------------------------] < 1 sec 22.0 MiB - Registering building of calendar search index as background job
- Registering background jobs to update cache for webcal calendars
- Added 0 background jobs to update webcal calendars
- Registering building of calendar reminder index as background job
- Clean up orphan event and contact data
- 0 events without a calendar have been cleaned up
- 0 properties without an events have been cleaned up
- 0 changes without a calendar have been cleaned up
- 0 cached events without a calendar subscription have been cleaned up
- 0 changes without a calendar subscription have been cleaned up
- 0 contacts without an addressbook have been cleaned up
- 0 properties without a contact have been cleaned up
- 0 changes without an addressbook have been cleaned up
- Remove activity entries of private events
- Removed 0 activity entries
- Fix the share type of guest shares when migrating from ownCloud
- Copy the share password into the dedicated column
- Set existing shares as accepted
- Update OAuth token expiration times
- Add background job to check for backup codes
- Populating added database structures for workflows
In AbstractMySQLDriver.php line 42:
[Doctrine\DBAL\Exception\TableNotFoundException]
.id
o
s
ON o
.id
= s
.operation_id
WHERE s
.operation _id
IS NULL’:
Exception trace:
at /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php:42
Doctrine\DBAL\Driver\AbstractMySQLDriver->convertException() at /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php:169
Doctrine\DBAL\DBALException::wrapException() at /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php:145
Doctrine\DBAL\DBALException::driverExceptionDuringQuery() at /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php:911
Doctrine\DBAL\Connection->executeQuery() at /var/www/nextcloud/lib/private/DB/Connection.php:199
OC\DB\Connection->executeQuery() at /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php:200
Doctrine\DBAL\Query\QueryBuilder->execute() at /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php:215
OC\DB\QueryBuilder\QueryBuilder->execute() at /var/www/nextcloud/apps/workflowengine/lib/Migration/PopulateNewlyIntroducedDatabaseFields.php:86
OCA\WorkflowEngine\Migration\PopulateNewlyIntroducedDatabaseFields->getIdsWithoutScope() at /var/www/nextcloud/apps/workflowengine/lib/Migration/PopulateNewlyIntroducedDatabaseFields.php:48
OCA\WorkflowEngine\Migration\PopulateNewlyIntroducedDatabaseFields->run() at /var/www/nextcloud/lib/private/Repair.php:104
OC\Repair->run() at /var/www/nextcloud/core/Command/Maintenance/Repair.php:126
OC\Core\Command\Maintenance\Repair->execute() at /var/www/nextcloud/3rdparty/symfony/console/Command/Command.php:255
Symfony\Component\Console\Command\Command->run() at /var/www/nextcloud/3rdparty/symfony/console/Application.php:915
Symfony\Component\Console\Application->doRunCommand() at /var/www/nextcloud/3rdparty/symfony/console/Application.php:272
Symfony\Component\Console\Application->doRun() at /var/www/nextcloud/3rdparty/symfony/console/Application.php:148
Symfony\Component\Console\Application->run() at /var/www/nextcloud/lib/private/Console/Application.php:214
OC\Console\Application->run() at /var/www/nextcloud/console.php:99
require_once() at /var/www/nextcloud/occ:11
In PDOConnection.php line 90:
[Doctrine\DBAL\Driver\PDOException (42S02)]
Exception trace:
at /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:90
Doctrine\DBAL\Driver\PDOConnection->query() at /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php:908
In PDOConnection.php line 88:
[PDOException (42S02)]
Exception trace:
at /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:88
PDO->query() at /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:88
maintenance:repair [–include-expensive]
sudo -u www-data php /var/www/nextcloud/occ migrations:status workflowengine -vvv
In MigrationService.php line 453:
[InvalidArgumentException]
Migration step ‘OCA\WorkflowEngine\Migration\Version2000Date20190808074233’ is unknown
Exception trace:
at /var/www/nextcloud/lib/private/DB/MigrationService.php:453
OC\DB\MigrationService->createInstance() at /var/www/nextcloud/lib/private/DB/MigrationService.php:428
OC\DB\MigrationService->describeMigrationStep() at /var/www/nextcloud/core/Command/Db/Migrations/StatusCommand.php:107
OC\Core\Command\Db\Migrations\StatusCommand->getMigrationsInfos() at /var/www/nextcloud/core/Command/Db/Migrations/StatusCommand.php:60
OC\Core\Command\Db\Migrations\StatusCommand->execute() at /var/www/nextcloud/3rdparty/symfony/console/Command/Command.php:255
sudo -u www-data php /var/www/nextcloud/occ status
- installed: true
- version: 18.0.2.2
- versionstring: 18.0.2
- edition:
######## Solution ############
Found a solution that helped me to get 18.02 up and running. cheers /Pedro
cp apps/workflowengine/appinfo/database.xml ~/
rm -f apps/workflowengine/appinfo/database.xml
