example
longer
example
here
Nextcloud version (eg, 18.0.2): 16? (I’M NOT SURE)
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.29
PHP version (eg, 7.1): 7.2.24
I’m new here, I hope the information provided below follow the forum’s rules.
When I try to fire up my nextcloud address on the web-browser I get this error: “Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
More details can be found in the server log.”
There have been no problem for years, I use nextcloud only as my personal cloud but it is now quite important for my work.
I tried to reinstall nextcloud manually with no luck; indeed, when I run the “occ upgrade” command I get a very long error ending with “{“reqId”:“uYhnWAUw7P8IfrBVUNJG”,“level”:3,“time”:“2020-08-30T12:39:08+00:00”,“remoteAddr”:”",“user”:"–",“app”:“PHP”,“method”:"",“url”:"–",“message”:“chmod(): Permission denied at /var/www/nextcloud/lib/private/Log\File.php#141”,“userAgent”:"–",“version”:“16.0.10.2”}
Many thanks for your help!
Angelo
Is this the first time you’ve seen this error? (Y/N): YES
1.I can’t run any occ command
2. I can’t load my nextcloud’s homepage
3.
'instanceid' => '***',
'passwordsalt' => '***',
'secret' => '***',
0 => 'asds.dynu.net',
'datadirectory' => '/home/asds/nextcloud',
'version' => '16.0.10.2',
'overwrite.cli.url' => 'https://***/nextcloud',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'asds',
'dbpassword' => '***',
'theme' => '',
'loglevel' => 2,
[Sun Aug 30 14:14:45.055869 2020] [php7:warn] [pid 31317] [client 127.0.0.1:57006] PHP Warning: fileperms(): stat failed for /home/asds/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.php on line 140
[Sun Aug 30 14:14:45.055936 2020] [php7:notice] [pid 31317] [client 127.0.0.1:57006] {"reqId":"yPzX96YeVoTZhnCDDSZN","level":3,"time":"2020-08-30T12:14:45+00:00","remoteAddr":"127.0.0.1","user":"--","app":"PHP","method":"GET","url":"\\/nextcloud\\/","message":"fileperms(): stat failed for \\/home\\/asds\\/nextcloud\\/nextcloud.log at \\/var\\/www\\/nextcloud\\/lib\\/private\\/Log\\/File.php#140","userAgent":"Mozilla\\/5.0 (X11; Ubuntu; Linux x86_64; rv:80.0) Gecko\\/20100101 Firefox\\/80.0","version":"16.0.10.2"}
[Sun Aug 30 14:14:45.055979 2020] [php7:notice] [pid 31317] [client 127.0.0.1:57006] {"reqId":"yPzX96YeVoTZhnCDDSZN","level":3,"time":"2020-08-30T12:14:45+00:00","remoteAddr":"127.0.0.1","user":"--","app":"no app in context","method":"GET","url":"\\/nextcloud\\/","message":"$absolutePath must be relative to \\"files\\", value is \\"%s\\"","userAgent":"Mozilla\\/5.0 (X11; Ubuntu; Linux x86_64; rv:80.0) Gecko\\/20100101 Firefox\\/80.0","version":"16.0.10.2"}
[Sun Aug 30 14:14:45.057166 2020] [php7:warn] [pid 31317] [client 127.0.0.1:57006] PHP Warning: fileperms(): stat failed for /home/asds/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.php on line 140
[Sun Aug 30 14:14:45.057190 2020] [php7:notice] [pid 31317] [client 127.0.0.1:57006] {"reqId":"yPzX96YeVoTZhnCDDSZN","level":3,"time":"2020-08-30T12:14:45+00:00","remoteAddr":"127.0.0.1","user":"--","app":"PHP","method":"GET","url":"\\/nextcloud\\/","message":"fileperms(): stat failed for \\/home\\/asds\\/nextcloud\\/nextcloud.log at \\/var\\/www\\/nextcloud\\/lib\\/private\\/Log\\/File.php#140","userAgent":"Mozilla\\/5.0 (X11; Ubuntu; Linux x86_64; rv:80.0) Gecko\\/20100101 Firefox\\/80.0","version":"16.0.10.2"}
[Sun Aug 30 14:14:45.057216 2020] [php7:notice] [pid 31317] [client 127.0.0.1:57006] {"reqId":"yPzX96YeVoTZhnCDDSZN","level":3,"time":"2020-08-30T12:14:45+00:00","remoteAddr":"127.0.0.1","user":"--","app":"no app in context","method":"GET","url":"\\/nextcloud\\/","message":{"Exception":"OCP\\\\Lock\\\\LockedException","Message":"\\"\\/files_encryption\\" is locked","Code":0,"Trace":[{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/View.php","line":1149,"function":"changeLock","class":"OC\\\\Files\\\\View","type":"->","args":["\\/files_encryption",2]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/View.php","line":270,"function":"basicOperation","class":"OC\\\\Files\\\\View","type":"->","args":["mkdir","\\/files_encryption",["create","write"]]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Encryption\\/Keys\\/Storage.php","line":372,"function":"mkdir","class":"OC\\\\Files\\\\View","type":"->","args":["\\/files_encryption"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Encryption\\/Keys\\/Storage.php","line":232,"function":"keySetPreparation","class":"OC\\\\Encryption\\\\Keys\\\\Storage","type":"->","args":["\\/files_encryption\\/OC_DEFAULT_MODULE"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Encryption\\/Keys\\/Storage.php","line":133,"function":"setKey","class":"OC\\\\Encryption\\\\Keys\\\\Storage","type":"->","args":["\\/files_encryption\\/OC_DEFAULT_MODULE\\/pubShare_c5c3e263.publicKey","-----BEGIN PUBLIC KEY-----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\\nIsYjEA9hAiEyS21RPZWFyLkCAwEAAQ==\\n-----END PUBLIC KEY-----\\n"]},{"file":"\\/var\\/www\\/nextcloud\\/apps\\/encryption\\/lib\\/KeyManager.php","line":166,"function":"setSystemUserKey","class":"OC\\\\Encryption\\\\Keys\\\\Storage","type":"->","args":["pubShare_c5c3e263.publicKey","-----BEGIN PUBLIC KEY-----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\\nIsYjEA9hAiEyS21RPZWFyLkCAwEAAQ==\\n-----END PUBLIC KEY-----\\n","OC_DEFAULT_MODULE"]},{"file":"\\/var\\/www\\/nextcloud\\/apps\\/encryption\\/lib\\/Users\\/Setup.php","line":86,"function":"validateShareKey","class":"OCA\\\\Encryption\\\\KeyManager","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/apps\\/encryption\\/lib\\/AppInfo\\/Application.php","line":70,"function":"setupSystem","class":"OCA\\\\Encryption\\\\Users\\\\Setup","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/apps\\/encryption\\/appinfo\\/app.php","line":35,"function":"setUp","class":"OCA\\\\Encryption\\\\AppInfo\\\\Application","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/legacy\\/app.php","line":265,"args":["\\/var\\/www\\/nextcloud\\/apps\\/encryption\\/appinfo\\/app.php"],"function":"require_once"},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/legacy\\/app.php","line":155,"function":"requireAppFile","class":"OC_App","type":"::","args":[{"__class__":"OCA\\\\Encryption\\\\AppInfo\\\\Application"}]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/legacy\\/app.php","line":128,"function":"loadApp","class":"OC_App","type":"::","args":["encryption"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/legacy\\/util.php","line":196,"function":"loadApps","class":"OC_App","type":"::","args":[["filesystem"]]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/Filesystem.php","line":266,"function":"setupFS","class":"OC_Util","type":"::","args":[""]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Server.php","line":291,"function":"getMountManager","class":"OC\\\\Files\\\\Filesystem","type":"::","args":[null]},{"file":"\\/var\\/www\\/nextcloud\\/3rdparty\\/pimple\\/pimple\\/src\\/Pimple\\/Container.php","line":118,"function":"OC\\\\{closure}","class":"OC\\\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/ServerContainer.php","line":125,"function":"offsetGet","class":"Pimple\\\\Container","type":"->","args":["RootFolder"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Server.php","line":313,"function":"query","class":"OC\\\\ServerContainer","type":"->","args":["RootFolder"]},{"function":"OC\\\\{closure}","class":"OC\\\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/Node\\/LazyRoot.php","line":61,"function":"call_user_func","args":[{"__class__":"Closure"}]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/Node\\/LazyRoot.php","line":141,"function":"__call","class":"OC\\\\Files\\\\Node\\\\LazyRoot","type":"->","args":["get",["appdata_oczk2tlfgepl\\/js\\/core"]]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/AppData\\/AppData.php","line":140,"function":"get","class":"OC\\\\Files\\\\Node\\\\LazyRoot","type":"->","args":["appdata_oczk2tlfgepl\\/js\\/core"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/JSCombiner.php","line":94,"function":"getFolder","class":"OC\\\\Files\\\\AppData\\\\AppData","type":"->","args":["core"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/JSResourceLocator.php","line":114,"function":"process","class":"OC\\\\Template\\\\JSCombiner","type":"->","args":["\\/var\\/www\\/nextcloud","core\\/js\\/merged-template-prepend.json","core"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/JSResourceLocator.php","line":70,"function":"cacheAndAppendCombineJsonIfExist","class":"OC\\\\Template\\\\JSResourceLocator","type":"->","args":["\\/var\\/www\\/nextcloud","core\\/js\\/merged-template-prepend.json"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/ResourceLocator.php","line":78,"function":"doFind","class":"OC\\\\Template\\\\JSResourceLocator","type":"->","args":["js\\/merged-template-prepend"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/TemplateLayout.php","line":331,"function":"find","class":"OC\\\\Template\\\\ResourceLocator","type":"->","args":[["core\\/js\\/dist\\/main","js\\/merged-template-prepend","search\\/js\\/search","core\\/l10n\\/en","search\\/l10n\\/en","search\\/js\\/searchprovider","js\\/files\\/fileinfo","js\\/files\\/client"]]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/TemplateLayout.php","line":159,"function":"findJavascriptFiles","class":"OC\\\\TemplateLayout","type":"::","args":[["core\\/js\\/dist\\/main","js\\/merged-template-prepend","search\\/js\\/search","core\\/l10n\\/en","search\\/l10n\\/en","search\\/js\\/searchprovider","js\\/files\\/fileinfo","js\\/files\\/client"]]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/legacy\\/template.php","line":183,"function":"__construct","class":"OC\\\\TemplateLayout","type":"->","args":["guest",""]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/Base.php","line":131,"function":"fetchPage","class":"
[Sun Aug 30 14:14:45.085255 2020] [php7:warn] [pid 31317] [client 127.0.0.1:57006] PHP Warning: fileperms(): stat failed for /home/asds/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.php on line 140
[Sun Aug 30 14:14:45.085298 2020] [php7:notice] [pid 31317] [client 127.0.0.1:57006] {"reqId":"yPzX96YeVoTZhnCDDSZN","level":3,"time":"2020-08-30T12:14:45+00:00","remoteAddr":"127.0.0.1","user":"--","app":"PHP","method":"GET","url":"\\/nextcloud\\/","message":"fileperms(): stat failed for \\/home\\/asds\\/nextcloud\\/nextcloud.log at \\/var\\/www\\/nextcloud\\/lib\\/private\\/Log\\/File.php#140","userAgent":"Mozilla\\/5.0 (X11; Ubuntu; Linux x86_64; rv:80.0) Gecko\\/20100101 Firefox\\/80.0","version":"16.0.10.2"}
[Sun Aug 30 14:14:45.085325 2020] [php7:notice] [pid 31317] [client 127.0.0.1:57006] {"reqId":"yPzX96YeVoTZhnCDDSZN","level":3,"time":"2020-08-30T12:14:45+00:00","remoteAddr":"127.0.0.1","user":"--","app":"index","method":"GET","url":"\\/nextcloud\\/","message":{"Exception":"RuntimeException","Message":"Could not get appdata folder","Code":0,"Trace":[{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/AppData\\/AppData.php","line":108,"function":"getAppDataRootFolder","class":"OC\\\\Files\\\\AppData\\\\AppData","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/AppData\\/AppData.php","line":155,"function":"getAppDataFolder","class":"OC\\\\Files\\\\AppData\\\\AppData","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/JSCombiner.php","line":97,"function":"newFolder","class":"OC\\\\Files\\\\AppData\\\\AppData","type":"->","args":["core"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/JSResourceLocator.php","line":114,"function":"process","class":"OC\\\\Template\\\\JSCombiner","type":"->","args":["\\/var\\/www\\/nextcloud","core\\/js\\/merged-template-prepend.json","core"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/JSResourceLocator.php","line":70,"function":"cacheAndAppendCombineJsonIfExist","class":"OC\\\\Template\\\\JSResourceLocator","type":"->","args":["\\/var\\/www\\/nextcloud","core\\/js\\/merged-template-prepend.json"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/ResourceLocator.php","line":78,"function":"doFind","class":"OC\\\\Template\\\\JSResourceLocator","type":"->","args":["js\\/merged-template-prepend"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/TemplateLayout.php","line":331,"function":"find","class":"OC\\\\Template\\\\ResourceLocator","type":"->","args":[["core\\/js\\/dist\\/main","js\\/merged-template-prepend","search\\/js\\/search","core\\/l10n\\/en","search\\/l10n\\/en","search\\/js\\/searchprovider","js\\/files\\/fileinfo","js\\/files\\/client"]]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/TemplateLayout.php","line":159,"function":"findJavascriptFiles","class":"OC\\\\TemplateLayout","type":"::","args":[["core\\/js\\/dist\\/main","js\\/merged-template-prepend","search\\/js\\/search","core\\/l10n\\/en","search\\/l10n\\/en","search\\/js\\/searchprovider","js\\/files\\/fileinfo","js\\/files\\/client"]]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/legacy\\/template.php","line":183,"function":"__construct","class":"OC\\\\TemplateLayout","type":"->","args":["guest",""]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/Base.php","line":131,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/legacy\\/template.php","line":273,"function":"printPage","class":"OC\\\\Template\\\\Base","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/base.php","line":676,"function":"printGuestPage","class":"OC_Template","type":"::","args":["","error",{"errors":[{"error":"Your data directory is invalid","hint":"Ensure there is a file called \\".ocdata\\" in the root of the data directory."},{"error":"Cannot create \\"data\\" directory","hint":"This can usually be fixed by giving the webserver write access to the root directory. See https:\\/\\/docs.nextcloud.com\\/server\\/16\\/go.php?to=admin-dir_permissions"}]}]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/base.php","line":1053,"function":"init","class":"OC","type":"::","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/index.php","line":40,"args":["\\/var\\/www\\/nextcloud\\/lib\\/base.php"],"function":"require_once"}],"File":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/AppData\\/AppData.php","Line":92,"CustomMessage":"--"},"userAgent":"Mozilla\\/5.0 (X11; Ubuntu; Linux x86_64; rv:80.0) Gecko\\/20100101 Firefox\\/80.0","version":"16.0.10.2"}
[Sun Aug 30 14:14:45.087462 2020] [php7:warn] [pid 31317] [client 127.0.0.1:57006] PHP Warning: fileperms(): stat failed for /home/asds/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.php on line 140
[Sun Aug 30 14:14:45.087492 2020] [php7:notice] [pid 31317] [client 127.0.0.1:57006] {"reqId":"yPzX96YeVoTZhnCDDSZN","level":3,"time":"2020-08-30T12:14:45+00:00","remoteAddr":"127.0.0.1","user":"--","app":"PHP","method":"GET","url":"\\/nextcloud\\/","message":"fileperms(): stat failed for \\/home\\/asds\\/nextcloud\\/nextcloud.log at \\/var\\/www\\/nextcloud\\/lib\\/private\\/Log\\/File.php#140","userAgent":"Mozilla\\/5.0 (X11; Ubuntu; Linux x86_64; rv:80.0) Gecko\\/20100101 Firefox\\/80.0","version":"16.0.10.2"}
[Sun Aug 30 14:14:45.087518 2020] [php7:notice] [pid 31317] [client 127.0.0.1:57006] {"reqId":"yPzX96YeVoTZhnCDDSZN","level":3,"time":"2020-08-30T12:14:45+00:00","remoteAddr":"127.0.0.1","user":"--","app":"core","method":"GET","url":"\\/nextcloud\\/","message":{"Exception":"RuntimeException","Message":"Could not get appdata folder","Code":0,"Trace":[{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/AppData\\/AppData.php","line":108,"function":"getAppDataRootFolder","class":"OC\\\\Files\\\\AppData\\\\AppData","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/AppData\\/AppData.php","line":155,"function":"getAppDataFolder","class":"OC\\\\Files\\\\AppData\\\\AppData","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/JSCombiner.php","line":97,"function":"newFolder","class":"OC\\\\Files\\\\AppData\\\\AppData","type":"->","args":["core"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/JSResourceLocator.php","line":114,"function":"process","class":"OC\\\\Template\\\\JSCombiner","type":"->","args":["\\/var\\/www\\/nextcloud","core\\/js\\/merged-template-prepend.json","core"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/JSResourceLocator.php","line":70,"function":"cacheAndAppendCombineJsonIfExist","class":"OC\\\\Template\\\\JSResourceLocator","type":"->","args":["\\/var\\/www\\/nextcloud","core\\/js\\/merged-template-prepend.json"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/ResourceLocator.php","line":78,"function":"doFind","class":"OC\\\\Template\\\\JSResourceLocator","type":"->","args":["js\\/merged-template-prepend"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/TemplateLayout.php","line":331,"function":"find","class":"OC\\\\Template\\\\ResourceLocator","type":"->","args":[["core\\/js\\/dist\\/main","js\\/merged-template-prepend","search\\/js\\/search","core\\/l10n\\/en","search\\/l10n\\/en","search\\/js\\/searchprovider","js\\/files\\/fileinfo","js\\/files\\/client"]]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/TemplateLayout.php","line":159,"function":"findJavascriptFiles","class":"OC\\\\TemplateLayout","type":"::","args":[["core\\/js\\/dist\\/main","js\\/merged-template-prepend","search\\/js\\/search","core\\/l10n\\/en","search\\/l10n\\/en","search\\/js\\/searchprovider","js\\/files\\/fileinfo","js\\/files\\/client"]]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/legacy\\/template.php","line":183,"function":"__construct","class":"OC\\\\TemplateLayout","type":"->","args":["guest",""]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/Base.php","line":131,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/legacy\\/template.php","line":273,"function":"printPage","class":"OC\\\\Template\\\\Base","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/base.php","line":676,"function":"printGuestPage","class":"OC_Template","type":"::","args":["","error",{"errors":[{"error":"Your data directory is invalid","hint":"Ensure there is a file called \\".ocdata\\" in the root of the data directory."},{"error":"Cannot create \\"data\\" directory","hint":"This can usually be fixed by giving the webserver write access to the root directory. See https:\\/\\/docs.nextcloud.com\\/server\\/16\\/go.php?to=admin-dir_permissions"}]}]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/base.php","line":1053,"function":"init","class":"OC","type":"::","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/index.php","line":40,"args":["\\/var\\/www\\/nextcloud\\/lib\\/base.php"],"function":"require_once"}],"File":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/AppData\\/AppData.php","Line":92,"CustomMessage":"--"},"userAgent":"Mozilla\\/5.0 (X11; Ubuntu; Linux x86_64; rv:80.0) Gecko\\/20100101 Firefox\\/80.0","version":"16.0.10.2"}
[Sun Aug 30 14:14:45.087832 2020] [php7:warn] [pid 31317] [client 127.0.0.1:57006] PHP Warning: fileperms(): stat failed for /home/asds/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.php on line 140
[Sun Aug 30 14:14:45.087850 2020] [php7:notice] [pid 31317] [client 127.0.0.1:57006] {"reqId":"yPzX96YeVoTZhnCDDSZN","level":3,"time":"2020-08-30T12:14:45+00:00","remoteAddr":"127.0.0.1","user":"--","app":"PHP","method":"GET","url":"\\/nextcloud\\/","message":"fileperms(): stat failed for \\/home\\/asds\\/nextcloud\\/nextcloud.log at \\/var\\/www\\/nextcloud\\/lib\\/private\\/Log\\/File.php#140","userAgent":"Mozilla\\/5.0 (X11; Ubuntu; Linux x86_64; rv:80.0) Gecko\\/20100101 Firefox\\/80.0","version":"16.0.10.2"}
[Sun Aug 30 14:14:45.087874 2020] [php7:notice] [pid 31317] [client 127.0.0.1:57006] {"reqId":"yPzX96YeVoTZhnCDDSZN","level":3,"time":"2020-08-30T12:14:45+00:00","remoteAddr":"127.0.0.1","user":"--","app":"core","method":"GET","url":"\\/nextcloud\\/","message":{"Exception":"RuntimeException","Message":"Could not get appdata folder","Code":0,"Trace":[{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/AppData\\/AppData.php","line":108,"function":"getAppDataRootFolder","class":"OC\\\\Files\\\\AppData\\\\AppData","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/AppData\\/AppData.php","line":155,"function":"getAppDataFolder","class":"OC\\\\Files\\\\AppData\\\\AppData","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/JSCombiner.php","line":97,"function":"newFolder","class":"OC\\\\Files\\\\AppData\\\\AppData","type":"->","args":["core"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/JSResourceLocator.php","line":114,"function":"process","class":"OC\\\\Template\\\\JSCombiner","type":"->","args":["\\/var\\/www\\/nextcloud","core\\/js\\/merged-template-prepend.json","core"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/JSResourceLocator.php","line":70,"function":"cacheAndAppendCombineJsonIfExist","class":"OC\\\\Template\\\\JSResourceLocator","type":"->","args":["\\/var\\/www\\/nextcloud","core\\/js\\/merged-template-prepend.json"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/ResourceLocator.php","line":78,"function":"doFind","class":"OC\\\\Template\\\\JSResourceLocator","type":"->","args":["js\\/merged-template-prepend"]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/TemplateLayout.php","line":331,"function":"find","class":"OC\\\\Template\\\\ResourceLocator","type":"->","args":[["core\\/js\\/dist\\/main","js\\/merged-template-prepend","search\\/js\\/search","core\\/l10n\\/en","search\\/l10n\\/en","search\\/js\\/searchprovider","js\\/files\\/fileinfo","js\\/files\\/client","encryption\\/l10n\\/en","encryption\\/js\\/encryption","core\\/js\\/dist\\/share_backend"]]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/TemplateLayout.php","line":159,"function":"findJavascriptFiles","class":"OC\\\\TemplateLayout","type":"::","args":[["core\\/js\\/dist\\/main","js\\/merged-template-prepend","search\\/js\\/search","core\\/l10n\\/en","search\\/l10n\\/en","search\\/js\\/searchprovider","js\\/files\\/fileinfo","js\\/files\\/client","encryption\\/l10n\\/en","encryption\\/js\\/encryption","core\\/js\\/dist\\/share_backend"]]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/legacy\\/template.php","line":183,"function":"__construct","class":"OC\\\\TemplateLayout","type":"->","args":["error",""]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Template\\/Base.php","line":131,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/legacy\\/template.php","line":332,"function":"printPage","class":"OC\\\\Template\\\\Base","type":"->","args":[]},{"file":"\\/var\\/www\\/nextcloud\\/index.php","line":69,"function":"printExceptionErrorPage","class":"OC_Template","type":"::","args":[{"__class__":"RuntimeException"},500]}],"File":"\\/var\\/www\\/nextcloud\\/lib\\/private\\/Files\\/AppData\\/AppData.php","Line":92,"CustomMessage":"--"},"userAgent":"Mozilla\\/5.0 (X11; Ubuntu; Linux x86_64; rv:80.0) Gecko\\/20100101 Firefox\\/80.0","version":"16.0.10.2"}
[Sun Aug 30 14:14:45.088131 2020] [php7:warn] [pid 31317] [client 127.0.0.1:57006] PHP Warning: fileperms(): stat failed for /home/asds/nextcloud/nextcloud.log in /var/www/nextcloud/lib/private/Log/File.php on line 140
[Sun Aug 30 14:14:45.088149 2020] [php7:notice] [pid 31317] [client 127.0.0.1:57006] {"reqId":"yPzX96YeVoTZhnCDDSZN","level":3,"time":"2020-08-30T12:14:45+00:00","remoteAddr":"127.0.0.1","user":"--","app":"PHP","method":"GET","url":"\\/nextcloud\\/","message":"fileperms(): stat failed for \\/home\\/asds\\/nextcloud\\/nextcloud.log at \\/var\\/www\\/nextcloud\\/lib\\/private\\/Log\\/File.php#140","userAgent":"Mozilla\\/5.0 (X11; Ubuntu; Linux x86_64; rv:80.0) Gecko\\/20100101 Firefox\\/80.0","version":"16.0.10.2"}
[Sun Aug 30 14:14:45.088173 2020] [php7:notice] [pid 31317] [client 127.0.0.1:57006] {"reqId":"yPzX96YeVoTZhnCDDSZN","level":3,"time":"2020-08-30T12:14:45+00:00","remoteAddr":"127.0.0.1","user":"--","app":"PHP","method":"GET","url":"\\/nextcloud\\/","message":"chmod(): Permission denied at \\/var\\/www\\/nextcloud\\/lib\\/private\\/Log\\/File.php#141","userAgent":"Mozilla\\/5.0 (X11; Ubuntu; Linux x86_64; rv:80.0) Gecko\\/20100101 Firefox\\/80.0","version":"16.0.10.2"}
