Nextcloud not working after proxmox lxc container backup restore
    30.0.4.1
    Proxmox LXC container
    Apache/2.4.62 (Debian)
    • replace me
    PHP 8.1.17
    yes
    After reapply of a lxc container backup onto a new ssd
  • followed youtube instructions
    no
Ive created a backup of my lxc container running nextcloud.
Then i replaced my ssd drive to install a bigger one.
Reapplied the lxc container onto the new ssd.
Container in proxmox is starting without any troubble like the other VMs and containers ive moved (Openhab, unifi and Shinobi, just as info).
But i cant get any informations of the nextcloud itself, the webapp is not loaded at all.
IP’s etc. seems like to be the same.
Webapp under https// is dead.
Also autosync on android does not find the host.
Looks like nextcloud is not “running” at all.
Searched in google. Apache2 is running.
Configuration is unchanged due to the backup of the container.
Trusted domains etc are correct. Also tried disabling fail2ban, just to be sure.
The hole nextcloud is down.
What do the container logs indicate?
What appears when you exec into the container?
Etc.
The container itself does not indicate anything wrong i would say.
But im also not a skilled person on this stuff. I can login als “root” and all files, configs etc are available. Systemctl claims a lot of running threads (apache2, mariadb etc)
Im also able to run the confconsole from NC.
My guess is that something with the webapp/interface is wrong.
Is there something where Nextcloud is a bit pitty when moving to an other drive? Something like hostnames, zertifikates or similar?
Thanks :slight_smile:
What helped me:
I was drigging arround and found in the apache2 error logs the message:
localhost:443:0 server certificate does NOT include an ID which matches the server name
I cant say why that error now forces the nextcloud down (maybe some can?) but i found in my nextcloud config.php a trusted domain entry that was called
www.example.com
That config was running for month before, now it crashed.
Ive removed it and, :scream_cat:, there is nextcloud again.
Webinterface, access via Android “Autosync”, everything.
