example
longer
example
here
Nextcloud version (eg, 12.0.2): 16.0.1
Operating system and version (eg, Ubuntu 17.04): Debian GNU/Linux 10 (buster)
Apache or nginx version (eg, Apache 2.4.25): 2.4.38
PHP version (eg, 7.1): 7.3.4-2
The issue you are facing: I had to wipe one of my computer’s hard drive and download my Nextcloud backup back to the fresh hard drive, but the client isn’t syncing anything from the server to the hard drive. The operating system & nextcloud client install hasn’t been changed as it’s on a different hard drive.
- Wiped data store hard drive on Linux client (Linux Mint 19.1 Cinnamon) (other hard drives containing OS and Nextcloud client still intact)
- Try to restore data from Nextcloud back to the wiped hard drive using the Linux Nextcloud client version 2.5.2git
- Nextcloud client seems to say “Sync successful” but nothing got copied back to the client from the server, even though the client shows a list of folders and total file size is 618GB.
Warning files_versions D0 is not a valid value for minimal versions retention obligation. Check versions_retention_obligation in your config.php. Falling back to auto.
2019-10-05T13:27:39+0100
Fatal webdav Doctrine\DBAL\Exception\DeadlockException: An exception occurred while executing 'UPDATE `oc_filecache` SET `storage` = ?, `path_hash` = MD5(CONCAT(?, SUBSTR(`path`, ?))), `path` = CONCAT(?, SUBSTR(`path`, ?)) WHERE (`storage` = ?) AND (`path` LIKE ?)' with params [3, "files_encryption\/keys\/files_trashbin\/files\/monero-blockchain-export.d1570278449", 100, "files_encryption\/keys\/files_trashbin\/files\/monero-blockchain-export.d1570278449", 100, 3, "files\\_encryption\/keys\/files\/Downloads\/monero-wallet-gui.app\/Contents\/MacOS\/monero-blockchain-export\/%"]: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction
2019-10-05T13:27:37+0100
Error PHP imagecreatefromstring(): Empty string or invalid image at /var/www/html/nextcloud/lib/private/legacy/image.php#622
2019-10-05T13:23:33+0100
Error PHP file_get_contents(/media/cloud/sync/kit/files/tmp/oc_tmp_OlOL3X-.gif): failed to open stream: No such file or directory at /var/www/html/nextcloud/lib/private/Files/Storage/Local.php#216
Fatal webdav Sabre\DAV\Exception\ServiceUnavailable: Could not open file
2019-10-05T13:17:46+0100
Error PHP fopen(/media/cloud/sync/kit/files/.fseventsd/00000000023df214): failed to open stream: No such file or directory at /var/www/html/nextcloud/lib/private/Files/Storage/Local.php#284
Error PHP fopen(/media/cloud/sync/kit/files/.fseventsd/00000000023df213): failed to open stream: No such file or directory at /var/www/html/nextcloud/lib/private/Files/Storage/Local.php#284
Error PHP fopen(/media/cloud/sync/kit/files/.fseventsd/0000000002283c89): failed to open stream: No such file or directory at /var/www/html/nextcloud/lib/private/Files/Storage/Local.php#284
Error PHP fopen(/media/cloud/sync/kit/files/.fseventsd/0000000002283c88): failed to open stream: No such file or directory at /var/www/html/nextcloud/lib/private/Files/Storage/Local.php#284
Error PHP fopen(/media/cloud/sync/kit/files/.fseventsd/0000000001b14e55): failed to open stream: No such file or directory at /var/www/html/nextcloud/lib/private/Files/Storage/Local.php#284
Error PHP fopen(/media/cloud/sync/kit/files/.fseventsd/0000000001b14e54): failed to open stream: No such file or directory at /var/www/html/nextcloud/lib/private/Files/Storage/Local.php#284
2019-10-05T13:05:11+0100
2019-10-05T11:58:38+0100
2019-10-05T11:49:50+0100
2019-10-05T11:49:08+0100
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => '192.168.1.6',
'datadirectory' => '/media/cloud/sync/',
'version' => '16.0.1.1',
'overwrite.cli.url' => 'https://192.168.1.6/nextcloud',
'dbname' => 'nextclouddb',
'dbhost' => 'localhost',
'dbuser' => '',
'dbpassword' => '',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => '',
'mail_domain' => '',
'mail_smtpauth' => 1,
'mail_smtphost' => '',
'mail_smtpname' => '',
'mail_smtppassword' => '',
'mail_smtpauthtype' => 'PLAIN',
'trashbin_retention_obligation' => 'D0, auto',
'versions_retention_obligation' => 'D0, auto',
'memcache.local' => '\OC\Memcache\Redis',
'redis' => array(
'host' => 'localhost',
'port' => 6379,),
'memcache.locking' => '\OC\Memcache\Redis',
: (just the error log)
[Sat Oct 05 00:00:01.847431 2019] [ssl:warn] [pid 18975] AH01909: 127.0.1.1:443:0 server certificate does NOT include an ID which matches the server name
[Sat Oct 05 00:00:01.847626 2019] [mpm_prefork:notice] [pid 18975] AH00163: Apache/2.4.38 (Debian) OpenSSL/1.1.1c configured -- resuming normal operations
[Sat Oct 05 00:00:01.847635 2019] [core:notice] [pid 18975] AH00094: Command line: '/usr/sbin/apache2'
