Hello everyone,
i’m kinda new of nextcloud and i’m facing a little problem…
i have set up a working nextcloud docker, created a folder on the web interface, and it appeared on the local server. That’s perfect.
the problem start when i put some file in the local folder, it gets written, but when i go to the web interface i cant see the file…
as shown in the picture, left is my FTP program that shows the right path to nextcloud folder, right it’s the web interfaces that shows No File…
In the future i will have a third party program write stuff in that folder, and i would like to get it working so i can share that folder… am i missing something? is there a way to make it working reliably?
Thanks in advance for your help
The problem is that i cant use a client, file are generated in 1 folder of the server, and moved in that one… so there is no way to use a client, and the solution then is to add a cronjob to scan the folder every 15 min, or i need to find another program that allows me to do that…
my nextcloud installation is in docker, and my third party program that is gonna save file in that folder is another docker, is there a way to do it? i’ve read that article but it’s not talking about servers, only windows linux and mac client
