Hi and Happy new year!
My current setup
- Nextcloud version:
25.0.2
(obtained viapodman exec <nextcloud-container> printenv NEXTCLOUD_VERSON
since my Nextcloud app is no more accessible) - *Operating system and version:
Ubuntu 22.04.3
- Podman version:
3.4.4
- nginx-proxy version:
nginx-proxy 1.0.3
, based onnginx 1.23.2
(based on the logs frompodman logs <nginx-proxy container>
- PHP version:
PHP 8.1.13
(obtained viapodman exec <nextcloud-container> php -v
) - Docker-compose file: pastebin link
- Dockerfile for nextcloud-app:
FROM nextcloud:apache
RUN apt update && apt install -y smbclient libsmbclient-dev && rm -rf /var/lib/apt/lists/*
RUN pecl install smbclient
RUN docker-php-ext-enable smbclient
- Dockerfile for nginx-proxy:
FROM nginxproxy/nginx-proxy:1.3-alpine
COPY uploadsize.conf /etc/nginx/conf.d/uploadsize.conf
The issue I am facing
Is this the first time you’ve seen this error?: Yes
docker-compose up -d
in the directory that contains the docker-compose file- Try to get to the Nextcloud Web page (nc.mydomain.com): it results in
ERR_CONNECTION_TIMED_OUT
error from the browser.
Description of the issue
It has been working well for months but, suddenly, without changing anything on purpose, Nextcloud is no more accessible from inside or outside the home network.
The browser returns the errorERR_CONNECTION_TIMED_OUT
Logs and traces
The output of your Nextcloud log in Admin > Logging: I can’t access the Web page.
The output of your config.php file: pastebin link
The output of your Apache/nginx/system log in
/var/log/____
: Logs obtained viapodman logs <nextcloud-container>
since apache2 logs are redirected to stdout and stderr:
Configuring Redis as session handler
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 10.89.1.5. Set the 'ServerName' directive globally to suppress this message
[Tue Jan 16 06:12:03.682341 2024] [mpm_prefork:notice] [pid 1] AH00163: Apache/2.4.54 (Debian) PHP/8.1.13 configured -- resuming normal operations
[Tue Jan 16 06:12:03.682570 2024] [core:notice] [pid 1] AH00094: Command line: 'apache2 -D FOREGROUND'
Logs from nginx-proxy container (obtained via
): pastebin link -
Output errors in nextcloud.log in /var/www/ or as admin user in top right menu, filtering for errors: pastebin link here (shortened to the past 2 weeks). I don´t know exactly when it stopped working but it should be less than 1 week.
By looking at these logs, I suspect an issue with connection to the DB. But I’m not sure.
Thank you for your help!
