I have a fully working install of nextcloud 18.0.3 hosted using docker-compose on a debian linux homeserver (versions etc. below), which I’m trying to migrate from a setup that uses an nginx self-signed certificate to lets-encrypt certificates served by traefik 1.7 (also running in a docker container) as wildcard domains. Traefik is working for a dozen or so other services on this server.
I’ve worked through forums here, on https://community.containo.us and on discourse.linuxserver.io and am fairly confident I’m working with the agreed correct docker-compose settings for my configuration.
It seems like something is going haywire with the forwarding. From what I can tell, traffic is getting passed from traefik to nginx, but not beyond to nextcloud for some reason. But I am really at a loss to tell what about this configuration is causing it. Any suggestions would be most welcome! Also happy to post additional logs/troubleshooting as needed.
Traefik config using docker-compose:
traefik:
# Note: upgrade to traefik 2 requires major migration, so holding at 1.7 for now
image: traefik:v1.7.19 # The official Traefik docker image
container_name: traefik
restart: always
command: --api --docker --configFile=/traefik.toml # Enables the web UI and tells Traefik to listen to docker
restart: unless-stopped
networks:
traefik_proxy:
ports:
- "80:80" # The HTTP port
- "443:443" # HTTPS
labels:
- "traefik.enable=true"
- "traefik.backend=traefik"
- "traefik.frontend.rule=Host:traefik.mydns"
- "traefik.port=8080"
volumes:
- /var/run/docker.sock:/var/run/docker.sock # So that Traefik can listen to the Docker events
- /opt/appdata/traefik/traefik.toml:/traefik.toml
- /opt/appdata/traefik/acme.json:/acme.json
- /opt/appdata/traefik/log:/log
env_file:
- /opt/traefik.env
nextcloud-mariadb:
image: linuxserver/mariadb
container_name: nextcloud-mariadb
labels:
- "traefik.enable=false"
networks:
nextcloud:
volumes:
- /opt/appdata/mariadb:/config
restart: always
environment:
- MYSQL_ROOT_PASSWORD=blahblahblah
nextcloud:
image: linuxserver/nextcloud
networks:
nextcloud:
traefik_proxy:
labels:
- "traefik.backend=nextcloud"
- "traefik.docker.network=traefik_proxy"
- "traefik.frontend.rule=Host:[myNextcloudDomain]"
- "traefik.port=80"
- "traefik.protocol=http"
- "traefik.frontend.headers.referrerPolicy=no-referrer"
- "traefik.frontend.headers.SSLRedirect=true"
- "traefik.frontend.headers.STSSeconds=315360000"
- "traefik.frontend.headers.browserXSSFilter=true"
- "traefik.frontend.headers.contentTypeNosniff=true"
- "traefik.frontend.headers.forceSTSHeader=true"
- "traefik.frontend.headers.SSLHost=[myNextcloudDomain]"
- "traefik.frontend.headers.SSLForceHost=true"
- "traefik.frontend.headers.STSIncludeSubdomains=true"
- "traefik.frontend.headers.STSPreload=true"
- "traefik.frontend.headers.customFrameOptionsValue=SAMEORIGIN"
volumes:
- /opt/appdata/nextcloud:/config
- /mnt/disk1/nextcloud:/data
ports:
- "4003:443"
restart: always
depends_on:
- nextcloud-mariadb
links:
- nextcloud-mariadb:mariadb
environment:
- PUID=${PUID}
- PGID=${PGID}
The trouble is that whilst configured in this way, I can access the nextcloud server at https://192.168.1.x:4003 but attempting to access it at nextcloud.traefik.mydns fails with a 301 error.
Working from outside in:
Connections are registering in traefik logs:
/opt/appdata/traefik/log/traefik.log:time="2020-04-24T09:38:21Z" level=debug msg="vulcand/oxy/forward/http: Round trip: http://172.26.0.12:80, code: 301, Length: 169, duration: 167.469µs tls:version: 303, tls:resume:false, tls:csuite:c02f, tls:server:nextcloud.traefik.mydns"
/opt/appdata/traefik/log/traefik.log:time="2020-04-24T09:38:21Z" level=debug msg="vulcand/oxy/forward/http: completed ServeHttp on request" Request="{\"Method\":\"GET\",\"URL\":{\"Scheme\":\"http\",\"Opaque\":\"\",\"User\":null,\"Host\":\"172.26.0.12:80\",\"Path\":\"\",\"RawPath\":\"\",\"ForceQuery\":false,\"RawQuery\":\"\",\"Fragment\":\"\"},\"Proto\":\"HTTP/1.1\",\"ProtoMajor\":1,\"ProtoMinor\":1,\"Header\":{\"Accept\":[\"text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8\"],\"Accept-Encoding\":[\"gzip\"],\"Accept-Language\":[\"en-US,en;q=0.5\"],\"Cdn-Loop\":[\"cloudflare\"],\"Cf-Connecting-Ip\":[\"87.75.107.138\"],\"Cf-Ipcountry\":[\"GB\"],\"Cf-Ray\":[\"588ed9d24fa7d21c-MAN\"],\"Cf-Request-Id\":[\"024d2677680000d21c2a268200000001\"],\"Cf-Visitor\":[\"{\\\"scheme\\\":\\\"https\\\"}\"],\"Connection\":[\"Keep-Alive\"],\"Cookie\":[\"__cfduid=db3762c0b7533d5ad1ecebf0ac937e4ba1566377128; _ga=GA1.2.616866650.1585847692; _gid=GA1.2.112496847.1587719409\"],\"Dnt\":[\"1\"],\"Upgrade-Insecure-Requests\":[\"1\"],\"User-Agent\":[\"Mozilla/5.0 (Macintosh; Intel Mac OS X 10.14; rv:75.0) Gecko/20100101 Firefox/75.0\"],\"X-Forwarded-For\":[\"87.75.107.138\"],\"X-Forwarded-Proto\":[\"https\"]},\"ContentLength\":0,\"TransferEncoding\":null,\"Host\":\"nextcloud.traefik.mydns\",\"Form\":null,\"PostForm\":null,\"MultipartForm\":null,\"Trailer\":null,\"RemoteAddr\":\"162.158.34.115:41264\",\"RequestURI\":\"/\",\"TLS\":null}"
/opt/appdata/traefik/log/traefik.log:time="2020-04-24T09:38:21Z" level=debug msg="vulcand/oxy/forward: completed ServeHttp on request" Request="{\"Method\":\"GET\",\"URL\":{\"Scheme\":\"http\",\"Opaque\":\"\",\"User\":null,\"Host\":\"172.26.0.12:80\",\"Path\":\"\",\"RawPath\":\"\",\"ForceQuery\":false,\"RawQuery\":\"\",\"Fragment\":\"\"},\"Proto\":\"HTTP/1.1\",\"ProtoMajor\":1,\"ProtoMinor\":1,\"Header\":{\"Accept\":[\"text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8\"],\"Accept-Encoding\":[\"gzip\"],\"Accept-Language\":[\"en-US,en;q=0.5\"],\"Cdn-Loop\":[\"cloudflare\"],\"Cf-Connecting-Ip\":[\"87.75.107.138\"],\"Cf-Ipcountry\":[\"GB\"],\"Cf-Ray\":[\"588ed9d24fa7d21c-MAN\"],\"Cf-Request-Id\":[\"024d2677680000d21c2a268200000001\"],\"Cf-Visitor\":[\"{\\\"scheme\\\":\\\"https\\\"}\"],\"Connection\":[\"Keep-Alive\"],\"Cookie\":[\"__cfduid=db3762c0b7533d5ad1ecebf0ac937e4ba1566377128; _ga=GA1.2.616866650.1585847692; _gid=GA1.2.112496847.1587719409\"],\"Dnt\":[\"1\"],\"Upgrade-Insecure-Requests\":[\"1\"],\"User-Agent\":[\"Mozilla/5.0 (Macintosh; Intel Mac OS X 10.14; rv:75.0) Gecko/20100101 Firefox/75.0\"],\"X-Forwarded-For\":[\"87.75.107.138\"],\"X-Forwarded-Proto\":[\"https\"]},\"ContentLength\":0,\"TransferEncoding\":null,\"Host\":\"nextcloud.traefik.mydns\",\"Form\":null,\"PostForm\":null,\"MultipartForm\":null,\"Trailer\":null,\"RemoteAddr\":\"162.158.34.115:41264\",\"RequestURI\":\"/\",\"TLS\":null}"
/opt/appdata/traefik/log/traefik.log:time="2020-04-24T09:38:21Z" level=debug msg="vulcand/oxy/roundrobin/rr: completed ServeHttp on request" Request="{\"Method\":\"GET\",\"URL\":{\"Scheme\":\"\",\"Opaque\":\"\",\"User\":null,\"Host\":\"\",\"Path\":\"/\",\"RawPath\":\"\",\"ForceQuery\":false,\"RawQuery\":\"\",\"Fragment\":\"\"},\"Proto\":\"HTTP/1.1\",\"ProtoMajor\":1,\"ProtoMinor\":1,\"Header\":{\"Accept\":[\"text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8\"],\"Accept-Encoding\":[\"gzip\"],\"Accept-Language\":[\"en-US,en;q=0.5\"],\"Cdn-Loop\":[\"cloudflare\"],\"Cf-Connecting-Ip\":[\"87.75.107.138\"],\"Cf-Ipcountry\":[\"GB\"],\"Cf-Ray\":[\"588ed9d24fa7d21c-MAN\"],\"Cf-Request-Id\":[\"024d2677680000d21c2a268200000001\"],\"Cf-Visitor\":[\"{\\\"scheme\\\":\\\"https\\\"}\"],\"Connection\":[\"Keep-Alive\"],\"Cookie\":[\"__cfduid=db3762c0b7533d5ad1ecebf0ac937e4ba1566377128; _ga=GA1.2.616866650.1585847692; _gid=GA1.2.112496847.1587719409\"],\"Dnt\":[\"1\"],\"Upgrade-Insecure-Requests\":[\"1\"],\"User-Agent\":[\"Mozilla/5.0 (Macintosh; Intel Mac OS X 10.14; rv:75.0) Gecko/20100101 Firefox/75.0\"],\"X-Forwarded-For\":[\"87.75.107.138\"],\"X-Forwarded-Proto\":[\"https\"]},\"ContentLength\":0,\"TransferEncoding\":null,\"Host\":\"nextcloud.traefik.mydns\",\"Form\":null,\"PostForm\":null,\"MultipartForm\":null,\"Trailer\":null,\"RemoteAddr\":\"162.158.34.115:41264\",\"RequestURI\":\"/\",\"TLS\":null}"
(note I am obfuscating IP and DNS as best practice here)
You can see docker config above.
Nextcloud log shows no entries at all relating to my attempts to connect whilst in this new configuration.
Output of config.php file in /nginx
## Version 2018/08/16 - Changelog: https://github.com/linuxserver/docker-baseimage-alpine-nginx/commits/master/root/defaults/nginx.conf
user abc;
worker_processes 4;
pid /run/nginx.pid;
include /etc/nginx/modules/*.conf;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# server_names_hash_bucket_size 64;
# server_name_in_redirect off;
client_max_body_size 0;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# Logging Settings
access_log /config/log/nginx/access.log;
error_log /config/log/nginx/error.log;
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/x-javascript text/xml application/xml application/xml+rss text/javascript;
#upstream php-handler {
# server nextcloud:9000;
# nginx-naxsi config
# Uncomment it if you installed nginx-naxsi
#include /etc/nginx/naxsi_core.rules;
# nginx-passenger config
# Uncomment it if you installed nginx-passenger
#passenger_root /usr;
#passenger_ruby /usr/bin/ruby;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /config/nginx/site-confs/*;
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
daemon off;
And nginx/site-confs/default
server 127.0.0.1:9000;
server {
listen 80;
listen [::]:80;
server_name _;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name _;
ssl_certificate /config/keys/cert.crt;
ssl_certificate_key /config/keys/cert.key;
add_header X-Robots-Tag none;
add_header X-Frame-Options "SAMEORIGIN";
add_header Referrer-Policy no-referrer;
root /config/www/nextcloud/;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
# The following rule is only needed for the Social app.
#rewrite ^/.well-known/webfinger /public.php?service=webfinger last;
return 301 $scheme://$host:$server_port/remote.php/dav;
client_max_body_size 10G;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
location / {
rewrite ^ /index.php;
location ~ ^\/(?:build|tests|config|lib|3rdparty|templates|data)\/ {
deny all;
location ~ ^\/(?:\.|autotest|occ|issue|indie|db_|console) {
deny all;
location ~ ^\/(?:index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|ocs-provider\/.+|ocm-provider\/.+)\.php(?:$|\/) {
fastcgi_split_path_info ^(.+?\.php)(\/.*|)$;
include /etc/nginx/fastcgi_params;
fastcgi_param HTTPS on;
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ ^\/(?:updater|ocs-provider|ocm-provider)(?:$|\/) {
try_files $uri/ =404;
index index.php;
location ~ \.(?:css|js|woff2?|svg|gif|map)$ {
add_header Cache-Control "public, max-age=15778463";
access_log off;
location ~ \.(?:png|html|ttf|ico|jpg|jpeg|bcmap)$ {
access_log off;
The output of your nginx access log:
172.26.0.4 - - [24/Apr/2020:12:53:14 +0000] "GET / HTTP/1.1" 301 169 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.14; rv:75.0) Gecko/20100101 Firefox/75.0"
172.26.0.4 - - [24/Apr/2020:12:53:15 +0000] "GET / HTTP/1.1" 301 169 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.14; rv:75.0) Gecko/20100101 Firefox/75.0"
No relevant entries in nginx error log.
Basic system properties:
Nextcloud version: 18.0.3
Operating system and version: Debian 4.9.130-2
Docker version 19.03.8, build afacb8b7f0
docker-compose version 1.23.2, build 1110ad01
Using linuxserver.io container here: https://hub.docker.com/r/linuxserver/nextcloud
Also worth noting that this seems to be an issue that others are experiencing: See traefik forum post here and linuxserver-io post here.
