Hello everybody! I need your help,please! I am almost exhausted trying to get rid of the problem described below. Google couldn’t help me((
I am running NC+MariaDB+Nginx in docker contatiners and everything works fine if I use HTTP.
However, I need to move on HTTPS. And it almost works as well. Except of one small but critical thing - port number is lost in web links. I am not sure for 100% who is guilty, ngingx or nextcloud, but I suspect nextcloud.
In a nushell - when I type
https://localhost:51623
it shows me login screen and when I enter my credentials and press enter, the link changes to just
https://localhost/index.php/apps/dashboard/
port is missing. Okay, I add port number manually in a browser and it works again when I click on some links inside NC, BUT except of link with logo of NC. When I click on it - port disappears again. It makes impossible to login from outside, for example, as all the answers fly back without port number.
My docker-compose:
1 version: '1'
2
3 services:
4 reverse_proxy:
5 image: nginx:latest
6 restart: always
7 ports:
8 - "51623:443"
9 container_name: nginx-reverse
10 depends_on:
11 - database
12 - nextcloud
13 volumes:
14 - /home/observer/BKP/nextcloud/nginx:/etc/nginx/conf.d
15 networks:
16 - nextcloud-net
17
18 database:
19 image: mariadb
20 command: --transaction-isolation=READ-COMMITTED --binlog-format=ROW --skip-innodb-read-only-compressed
21 restart: always
22 volumes:
23 - /home/observer/BKP/nextcloud/mariadb:/var/lib/mysql
24 container_name: mariadb-docker
25 environment:
26 - MYSQL_ROOT_PASSWORD=ABC123
27 - MYSQL_PASSWORD=DEF456
28 - MYSQL_DATABASE=nextcloud
29 - MYSQL_USER=nextcloud
30 networks:
31 - nextcloud-net
32
33 nextcloud:
34 image: nextcloud
35 restart: always
36 container_name: nextcloud-docker
37 volumes:
38 - /home/observer/BKP/nextcloud/apps:/var/www/html/apps
39 - /home/observer/BKP/nextcloud/config:/var/www/html/config
40 - /home/observer/BKP/nextcloud/data:/var/www/html/data
41 networks:
42 - nextcloud-net
43
44 networks:
45 nextcloud-net:
default.conf on NGINX is :
server {
listen 443 ssl http2;
server_name cloud.example.com;
ssl_certificate /etc/nginx/conf.d/nginx-selfsigned.crt;
ssl_certificate_key /etc/nginx/conf.d/nginx-selfsigned.key;
location / {
# root /var/www/localhost/htdocs;
proxy_pass http://nextcloud-docker/;
proxy_set_header Host $host;
add_header Front-End-Https on;
proxy_redirect default;
and config.php is:
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'occpfusc1bg7',
'passwordsalt' => '8UbBfHEu/UIepRLq+XT9ooa2MMLfIs',
'secret' => 'i6iXTsI8hC1zH2H8aoA8DnvGwPZwZCSl+akntkE/ZagJ5IHg',
0 => 'localhost',
1 => '192.168.0.111',
'version' => '25.0.3.2',
'overwrite.cli.url' => '',
'dbname' => 'nextcloud',
'dbhost' => 'mariadb-docker',
'dbuser' => 'nextcloud',
'dbpassword' => 'DEF456',
Does anybody have an idea why it happens?
I send you back rays of luck and happiness.
Thank you in advance.
