Hey Everyone,
I have a “little” Problem with my Nextcloud instance.
It Runs in my TrueNas VM and worked Perfectly, recently TrueNas migrated from Kubernetes to Docker and since then the Login Page doesn’t work / is not Reachable.
If I Type in “nextcloud.example-domain.com” it redirects to “nextcloud.example-domain.com:9001/login” and then says “The response from nextcloud.example-domain.com took too long.”
If I Type “nextcloud.example-domain.com/apps/dashboard” everything works as Normal. I use Nginx Proxy Manager on a different Docker instances as Proxy.
Has anyone a Idea I could try?
Sorry for my probable Bad English ![]()
